Considering a '13
Discussion in '2nd Gen. Tacomas (2005-2015)' started by journeymanjohn, Oct 1, 2016.
  1. Oct 1, 2016 at 3:11 AM
    journeymanjohn
    journeymanjohn [OP] New Member
    Am just looking for a bit of info on what are the most common issues for the 2013 Tacomas (AC Sr5). Have browsed a number of pages here, trying to get a feel of what issues are most common, and thought it may be beneficial to try to collect the info in one thread, with direct feedback from owners, rather than countless hours of sifting through post.
    Had a mechanic look at it. Over all, it seemed like a good vehicle. Had three issues we found.
    1) Looking under it, he knew it was from a cold weather state, from rust. He didn't state that it was terrible, just that it was present. Have those serious frame rust issues that I've read about been fixed by the 2013 model year?
    2) Smelled some coolant. He didn't find any coolant. DID find some build up on the engine oil cooler in the form of a crusty build up, that he said was from a current or prior coolant leak. Is this a typical or re-occurring issue with the '13 model.
    3) The fuel fill door had an issue with opening completely. Seems it had been "over-opened" at some point, and the hinge is bent.
    Anyway, when it comes to 2000 Jeep Cherokees, I can tell you the main issues to expect or look out for.... hairline cracks between the 3 & 4 cylinder on both the 00 & 01 models, driver side window auto down "gear" stripping out, engine cooling issues, etc. These are experienced by most, if not all owners.
    What can be expected from the later year 2nd generation Tacomas?
  2. Oct 1, 2016 at 3:37 AM
    jpereira2
    jpereira2 Well-Known Member
    Massachusetts
    2013 double cab trd off road
    Bilstein 6112 4th notch Bilstein 5160 rear Camburg ball joint UCAs Old man emu dakar leafs 265/75R16 Cooper ST Maxx Crux stereo a/v interface UltraGauge ARE fiberglass cap Wet okole seat covers Retro fit source Led fog lights Superbrightled pods in rear bumper Superbrightled light bar in grill Rock blokz mud flaps SOS Rock Sliders RCI Skid Plates (to be painted and mounted)
    Possibly low transmission fluid, and usually the stock leaf springs suck. Possible weatherstripping leaks in windshield. The rubber seal between grill and hood can make a noise, there are some easy fixes for this. Also possible bad needle bearing on driver side cv.
    journeymanjohn[OP] likes this.
  3. Oct 1, 2016 at 3:49 AM
    journeymanjohn
    We did not find a dip stick for the tranny fluid. Did we just miss it, or does it lack one? If there isn't one, how does one monitor the level. Also, I am assuming "low transmission fluid" is a kind way of saying transmission fluid leaks?
  4. Oct 1, 2016 at 3:55 AM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    Rotting frames are still an issue. It's no an "all or most owners" problem, but if you live in the rust belt it's of concern.
    Toyota replaced alot of frames in a recall already for early second gen
    Norton and journeymanjohn[OP] like this.
  5. Oct 1, 2016 at 4:09 AM
    jpereira2
    Massachusetts
    It's sealed unit. You would know by how it's acting.
  6. Oct 1, 2016 at 5:37 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Things to check:
    1) Frame rust - a change was made in suppliers of the frame to Toyota but the jury is still out if the rusting issue is solved. Fluid film or similar treatment would certainly help. The AC drain empties out onto the frame in the passengers side. Add an extension hose.
    2) wind noise from the windshield is possible on some trucks. I didn't have it on mine. From memory, I think the trim needed to be re-sealed or the trim replaced.
    3) wind noise from the grill gap with the hood. Toyota designed a whistle into the gap... 1/4" plastic tube slid into the rubber gasket at the top of the grill eliminates the noise.
    4) pinging when hot. Some trucks will ping and there's a TSB to have the ECU reprogrammed. I had mine done and the pinging went away but you'll loose a little mpg (I did).
    5) SR5 - If it has the flip down seat, it'll probably rattle going over bumps.
    6) dashboard rattle from the defroster duct or dash at the windshield. Haven't figured out a fix for that yet.
    7) 4x4? Make sure it goes into & out of 4wd without issue. It can be an expensive fix if the electrical controls need to be replaced.
    8) recent reports of the secondary air pump failures are being reported. There's an air pump on the pass side fender that has a foam filter in it. Some (including me) have removed the foam and replaced it with an external filter. Foam deteriorates and gets into the pump breaking the vanes. Expensive fix if that happens. The valves can also get stuck in that system. There a bypass some have used.
    9) auto transmissions may be low from the factory. There's a procedure written on here to check.
    10) some trucks have had driveline vibrations. There's a TSB. If it's lifted you might have front diff vibes that is fixed by replacing a roller bearing with a sleeve bearing.
    That's all I can think of right now. All in all, they are decent trucks. If you plan on towing heavy loads or hauling a lot of weight - consider a larger truck. Rear springs (stockers) on these squat easily. People do tow near the max but you won't get there fast and it'll burn a lot of fuel doing it.
  7. Oct 1, 2016 at 7:06 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
  8. Oct 1, 2016 at 7:41 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    Start it up cold for the first time in the morning and listen for piston slap. Tough to tell this time of the year, it's worse <50 degrees. This was extreme on my '13 and resulted in a new short block and eventually a lemon buy back.
    If you have the noise, you will hear it the loudest around the lower drivers front of the engine. Some cases were related to bad oil pumps too, it is located in that same drivers front lower area.
  9. Oct 1, 2016 at 8:28 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    On my 13 the only thing ive had is the cross wind noise at the top of the door. Had a TSB performed. I do have some engine ping with lower octane fuel. 92 octane for me gets rid of it.
  10. Oct 1, 2016 at 1:05 PM
    Tiberius
    Tiberius Well-Known Member
    Aurora, CO
    Nautical Blue v6 SR5 4x4 Access Cab
    47,000 on my '13. I had the whistle between 45-60 and read about using drip line on these forums. I used about 2 feet and placed it inside the front hood weatherstripping. Took it to dealer and they did the TSB anyway and replaced it for free (so either way your probably good after a few bucks).
    The only rattle I had was the driver side window switch which dealer put some tape on (only hear it with heavy bass). Passenger seat is fold-down (SR5) and doesn't rattle but it does jiggle around.
    I had some coolant leaking from the (overflow) hose for the radiator so slow it doesn't matter (I bought some pink coolant and put like 1 cup in a few weeks ago to fill her back up to spec - I guess I could have bought a hose clamp or something but whatever.
    I had them do the "knock" flash for the computer, and it quieted it down a bit for me in very cold weather especially with 92 octane and synthetic oil instead of conventional. But it still sounds like a finely tuned sewing machine so I know its Japanese.
    No problems with the CV or anything yet, but the back springs are crap. You have about 1100 pounds total load, so like 800-900 lbs depending how fat you are. Fully loaded it sags like crazy but I've only hit the bump stops on highway a few times and it did great offroad anyway - you just can tell its fully laden.
    I have the factory tow package with the transmission cooler, which people highly recommend, but people worry about transmission fluid level. I'm planning to have em drain and fill at 50,000 which should get it topped off if it was a little low. It shifts just fine although I feel the chatter of the lockup (forget what its called in the transmission) on the highway sometimes.
    I changed the rear diff fluid at 30,000 and it looked pretty good with a pea size collection of shavings, if that. Haven't done front or transfer case yet.
    Never had any problems. I plugged in the code reader and the only one its ever thrown was a false start or something one time (I don't remember anything weird).
    Everything has been great enjoy your rear-view backup camera and temperature/compass. I think only the 12 and 13 have em. And the nice steering wheel.
  11. Oct 2, 2016 at 1:12 AM
    journeymanjohn
    Thanks everyone!! I definitely have a better grasp on what to have my mechanic look close at!!
  12. Oct 2, 2016 at 3:23 AM
    LennyTheLip
    LennyTheLip Well-Known Member
    Long Branch, NJ.
    2013 SR5 DCSB
    Tint and tonneau for now
    Great truck. I haven't experienced any of he above issues. Only problem I've had is the double sided tape that holds the roof rack channels in place gave up the ghost. Occasionally vibrates and makes noise in certain crosswinds on the highway. Have to be doing over 65 though. I haven't done the diff oils yet, but it's up next, -along with a mother set of plugs, filters, etc. I just rolled 74k on it this morning. No pinging, engine noise, etc. I am pretty meticulous about changing the oil on schedule. I switched to synthetic around 50k. I'm not a big wheeler, and I don't tow a ton. Mostly small boats that max about 5k pounds and a monster snowblower in the winter. Best of luck with it!
  13. Oct 2, 2016 at 5:25 AM
    journeymanjohn
    I decided against the one I was currently looking at. Still am considering a later model Tacoma though.
    I am a bit confused by the tow ratings. I don't tow much, however I do move some large gang boxes with tools occasionally. Not sure of the total weight. Probably pushing over 1000 lbs, definitely over adding the weight of the 10' trailer I have.
    I read somewhere that without brakes on the trailer (and mine does not have them), the tow rating is only 1000 lbs, even with the tow package. I am not sure where I read this. Can anyone here confirm tow ratings without brakes on the trailer?
    My other question concerns adding a remote start. Is this possible, should the Tacoma have the remote keyless entry, or other security features that are becoming more common?
    Another question would be availability of headache racks or ladder racks. What are some good sources to investigate the styles and cost?
    Thanks again!!
  14. Oct 2, 2016 at 5:49 AM
    Two Tall
    Two Tall Well-Known Member
    Jim
    Ohio
    2018 TRD Off Road DCSB 4x4
    Retrax MXPro bed cover, Gentex Homelink mirror, TRD exhaust
    Regarding the fuel door not opening completely, I've had this issue on my '12. The door was replaced under warranty for me at about 60K (I've got 100K Platinum coverage.) Now at about 85K, it seems to have the same behavior - not opening all the way and not closing "flush." I'll probably take it back again to the dealer.
  15. Oct 2, 2016 at 6:46 AM
    LennyTheLip
    Long Branch, NJ.
    2013 SR5 DCSB
    Truck is rated to pull 6500 pounds if I recall, when equipped with the tow package. I've never heard the 1000 pound number. There are also a bunch of remote start options.
  16. Oct 2, 2016 at 9:59 AM
    Fulton246
    Fulton246 Well-Known Member
    NC
    2019 TRD Sport 4x4 DCLB
    The only issue I have with my 2013 is a slight whistle in heavy crosswinds. Otherwise, it is a great truck. I think most of the kinks from ealier 2nd gens were worked out by the time the '13s hit the market.
  17. Oct 2, 2016 at 5:59 PM
    hotrod53
    Lynd
    Pittsburgh, PA
    Fulton246, you probably need the stuff 1/4" OD tubing through the hood gasket fix. I did both my '13 and '14 to fix it. Windshields sometimes cause that too.
    I'm surprised that the Platinum warranty covered the gas door. Mine broke off on my '06 and all that was covered was the door spring that pops it open, not the door or the hinge. Fuel filling nozzles usually over extend the door and damage the hinge or lack of lubrication causes the hinge to break.
  18. Oct 2, 2016 at 7:06 PM
    moondeath
    Pa, Gardners
    The issue youre having with the fuel door is the hinge is drying up. If you read under the general maintenance in the owners manual is states to lube the fuel door cover hinges. Along with all the other hinges on the truck.
    As for towing, with the tow package the the truck is rated for 6500 lbs. If equipped with the tow package from the factory it comes with a connection for a trailer brake controller.
    1Shifter likes this.
  19. Oct 2, 2016 at 7:06 PM
    Wolftaco0503
    Wolftaco0503 Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Go for it I love mine
  20. Nov 27, 2016 at 4:12 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Would Fluid Film be a good choice to lube the hinges? I've never done this but I'd like to include it when I do oil changes and PM.
