Considering a 2005 SR5, What Should I Watch For?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by AeroCooper, Mar 9, 2014.
  1. Mar 9, 2014 at 5:58 AM
    AeroCooper
    AeroCooper [OP] Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    I am looking at a 2005 SR5 4x4 with around 105k miles. Is there anything I should watch out for on this year? I've owned 2 new Tacomas before, a '10 and '13, so I know the basics, but I'm wondering about the '05 since it was the first year 2nd gen. So, growing pains for the Tacoma, rust, etc.
    Any insight is appreciated.
  2. Mar 9, 2014 at 6:09 AM
    ST3VE
    ST3VE IG: @fishsohard
    MD --> SC
    Tint, car seat, baby wipes
    From my personal experience id check. Wheel bearings and the drive shaft u-joints. I have 150,000 miles on mine and that's really the only issues I've had.
  3. Mar 9, 2014 at 6:14 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    There were some 05's that had motor mount issues...
  4. Mar 9, 2014 at 6:38 AM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    ^^x2. Make sure motor mounts aren't cracked/collapsed. check for rust on frame. If it has LSD rearend, ask about maintenance. check u-joints too
  5. Mar 10, 2014 at 1:45 PM
    AeroCooper
    NH
    Was rust a big problem on the '05?
  6. Mar 10, 2014 at 1:52 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Yes, Toyota has already replaced some frames on the older models.
    Check the motor mounts and expect it to have a weak tailgate. If it's on the original suspension, you know the springs will be shot. Other than that, the normal wear and tear, wheel bearings, u-joints, carrier bearing, seals (check for signs of leaks).
  7. Mar 10, 2014 at 9:39 PM
    J.R
    J.R New Member
    J.R.
    Arkansas
    2010 green TRD 4x4
    rigid led lights,rugged bed cover
    seen horrible rusted frames on em
  8. Mar 11, 2014 at 1:45 PM
    AeroCooper
    NH
    I'm aware of the rusty frames issue on 1st gens, but didn't realize '05s had an issue as well. What about something like 2008? Still an issue?
  9. Mar 11, 2014 at 2:40 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 2021 WRX STI
    Building a Broja
    Honestly, it's not one specific year that's worse than the others, until at least the frame part number changed, which I recall was in 2009 (don't quote me on that).
    Just take a good hard look at the frame before you even look at anything else on the truck.
  10. Mar 11, 2014 at 3:02 PM
    Pugga
    Massachusetts
    x2, not year specific, 2nd Gen frames are just prone to the same rust BS that the first gens went through. They're just finally getting old enough and getting enough wear to where they're having issues. If it was maintained (washed), then you should be fine. The 2008 should be better but depends on where it was kept.
