Considering buying an AR
Discussion in 'Guns & Hunting' started by Desiel, Sep 14, 2010.
  1. Sep 15, 2010 at 12:38 PM
    #41
    sgrappone
    sgrappone Well-Known Member
    Scott
    Moncks Corner, SC
    04 AC 4X4
    There are many good manufacturers available but Bushmaster AR's come standard w/a chrome lined barrel and are mil spec. That is why I purchased a Bushmaster myself and love it. From what I've seen many of the other manufacturers offer chrome moly barrels which are cheaper to make but if you don't plan on putting a large number of rounds through it or if you can even afford that many rounds then save a little green and purchase one w/a chrome moly barrel and apply that $ else where. A chrome lined barrel is better for longevity. Just check all your options.
  2. Sep 15, 2010 at 1:27 PM
    #42
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    thanks, I was gonna post all that but didnt want to make it too lengthy
  3. Sep 15, 2010 at 2:18 PM
    #43
    sgrappone
    Scott
    Moncks Corner, SC
    04 AC 4X4
    You also need to consider if you are not familiar with an AR and how to CLEAN it properly which can be a PITA until you learn it. The key to having a functional AR is keeping it CLEAN! You may want to consider a gas piston operated type AR that has been proven to be a more reliable system and easier to clean than the standard gas operating system. Just food for thought!
  4. Sep 16, 2010 at 2:31 AM
    #44
    SpaceGoat
    SpaceGoat Active Member
    Hawaii
    07DoubleCabSR5
    Bilstien5100s all around, 1 inch blocks rear, Total Chaos UCAs, Body Cab mounts, Pioneer Head unit, 8 inch sub, Wet Okoles
    I semi-built these for about 1,100.00 each and they are as "top-tier" as any IMHO. Well the 16inch costs more that 1,100 now after scope, handguard, comp and trigger. But I got tired of sharing it with my girlfriend at the range so I had to build her one for herself, thus the 14.5 with pinned FH was born.
    -$860.00 Noveske N-4 14.5 inch pinned MOE upper CHF chrome lined 1-7 barrel-promo currently comes with free cosmetic blemish 2nd lower receiver
    -$50.00 ffl fees
    -$40.00 White Oak Armament lower parts kit-no grip
    -$56.00 true mil-spec buffer tube kit with H-2 buffer and spring
    -$56.00 MagPul MOE stock and grip
    -$30.00 misc shipping
    Total-$1,092.00
    I have an ASAP, you don't need to mount one, you could skip the MOE furniture, and use standard-save 40.00. you could get a cheaper buffer tube kit, save 17.00. You could choose another upper receiver group and buy you own lower receiver, maybe save 200.00 bucks there-for example, Bravo Co. makes good stuff-375.00 for upper assembly, 150.00 for BCG/handle, etc.
    Assembling a lower receiver is fairly simple, there are many sources of info/instructions on the web and all that is needed are simple hand tools. All I am saying is that you should take some time to look around...you would not after all buy 2011 double cab tacoma with only a 3 inch spacer lift on 285s straight from a dealer for over $40,000 now would you?? You may be suprised what your 1,000 could buy you, or even 1,100.00:)
  5. Sep 16, 2010 at 5:38 AM
    #45
    Desiel
    Desiel [OP] Well-Known Member
    Kyle
    Morristown, TN
    01 Tacoma XtraCab SR5 4x4
    So far: Tint American Racing Wheels with 265/75-15
    Thx for the info... Are you suggesting yours is for sale? lol
  6. Sep 16, 2010 at 5:49 AM
    #46
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    since when are bushmasters mil spec?
  7. Sep 16, 2010 at 6:25 AM
    #47
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    :ohsnap:
  8. Sep 16, 2010 at 6:25 AM
    #48
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    No one makes a true commercial mil spec rifle. Not even colt. There might be parts on the rifle including the phosphate manganese coatings, trigger groups, bolt carriers and such but non are completely 100% milspec.
  9. Sep 16, 2010 at 7:26 AM
    #49
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    change your mind? :p
  10. Sep 16, 2010 at 7:28 AM
    #50
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Lol *shakes head*
  11. Sep 16, 2010 at 7:33 AM
    #51
    Packman73
    2007 TRD Off Road
    Time for some truth
    [​IMG]rob_s M4carbine.net
  12. Sep 16, 2010 at 7:33 AM
    #52
    Matic
    Tricky Dick
    Easley, SC
    No.
    Mil spec is all hype. I repeat "There are no commercial 100% milspec rifles on the market".
    All of the guns I listed from those manufacturers have some degree of "mil spec" to them. If I worded it wrong and you didn't fully understand what I meant, then I apologize.
    In the best case, it means that all the parts in the rifle's assembly are either actual G.I. parts (modified as required by BATF for semi-auto where necessary), or "virtually" the same, and, that they were assembled in a manner consistant with those levels of quality equal to, or better, than that found in "contract" rifles. By parts that are "virtually" the same, I mean made by the same contractor, the same way, as the mil part.
    In the worst case, it's pure hype.
    Normally, it's in between these two.
    In virtually every case, a part made by a G.I. contractor is vastly superior to a part made by a non-contractor. Many part suppliers/rifle builders/manufacturers actively seek out "cheaper" parts supliers in lieu of the current, higher priced contractors.
    We see lots of crapola parts in rifles sent to the shop for repair. Lots. However, current Armalite and Bushmaster rifles are typically just fine, though in serious need of lubrication--but that's another story!
    Hope this helps!
    --Clint McKee
  13. Sep 16, 2010 at 7:40 AM
    #53
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Finally :thumbsup:
    lol I just read that exact same thing from a site i found on google...
    http://m4carbine.net/showthread.php?t=56063
    but for the average joe. "mil spec" is not that big a deal, you probably wont be using your gun as hard as they guys over in the desert ;)
  14. Sep 16, 2010 at 7:54 AM
    #54
    Matic
    Tricky Dick
    Easley, SC
    Back on topic.
    I still think the OP (based off his knowledge of weapons) would be content with just picking up a run of the mill $900 AR15 and being totally happy with it, whichever manufacturer he chooses.
    Let us know what you get OP!
  15. Sep 16, 2010 at 7:57 AM
    #55
    Matic
    Tricky Dick
    Easley, SC
    Oh...the post I read was dated 8-5-09. I think lmt is now added to the official TDP for the military.
  16. Sep 16, 2010 at 7:58 AM
    #56
    Desiel
    Kyle
    Morristown, TN
    K going to the gun shop today, see what he has. I wish I could just find someone to do some trading on this 1911.
  17. Sep 16, 2010 at 7:59 AM
    #57
    Masada
    Taylor
    Laveen, AZ
    lol this thread is funny now...
  18. Sep 16, 2010 at 8:04 AM
    #58
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    i bet your gun shop would. or wait until there is a gun show in your area.
    do a google search for used gun classifieds. i know dallas has one and when I was in idaho there was a site called Zidaho.com and there were always people trading and selling/buying.
    :laugh:
  19. Sep 16, 2010 at 8:10 AM
    #59
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Well, when I play Call of Duty I like to use an ACR or SCAR-H. Just my 2 cents!
  20. Sep 16, 2010 at 8:13 AM
    #60
    Masada
    Taylor
    Laveen, AZ
    Oh the ACR is where it's at baby! :D
