Considering getting a 2023 TRD pro w/ 6 speed manual
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ccrowe323, Sep 2, 2022.
  1. Sep 16, 2022 at 5:38 AM
    #61
    Horseshoez
    Horseshoez Well-Known Member
    Dale
    Maryland
    I just took a look-see at the latest KissMyGrits spreadsheet and see there are only 72 TRD Pros inbound at the moment, and of them a whopping 38 are 6MT models; that equates to 52.777% with manual transmissions!
    shakerhood and doublethebass like this.
  2. Sep 16, 2022 at 6:50 AM
    #62
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    5th gives you better torque without needing 4th too often.
  3. Sep 16, 2022 at 6:52 AM
    #63
    specter208
    California
    The TRD Pro knob is actually shaped like most knobs on big commercial trucks with Eaton and Spicers
    Canadian Caber likes this.
  4. Sep 16, 2022 at 7:13 AM
    #64
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    Sort of. The ones I've driven still had a more pronounced knob than the Toyota. I never thought twice about them. The Toyota feels like a block comparatively. It's a truly minor annoyance but it's an easy enough swap.
    It's also ugly with needless designs on it. Ha.
  5. Sep 16, 2022 at 8:00 AM
    #65
    LunarTeal
    LunarTeal Rarely interested....
    I ordered a TRD knob off an FJ. Light grey, TRD on the side with the shift pattern in the top. Just a nicely weighted big round cue ball of a knob.
    tcaustin likes this.
  6. Sep 16, 2022 at 9:31 AM
    #66
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    Doesn't change my opinion that it's a terrible knob shape, and know I know two other transmission manufacturers that don't understand the human hand.
  7. Oct 8, 2022 at 1:00 PM
    #67
    Edslittleworld
    Edslittleworld Well-Known Member
    Tucson
    2011 Tacoma TRD/OR (6MT)
    None
    Do you actually have $60K to blow on a pickup?
  8. Oct 8, 2022 at 1:08 PM
    #68
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    How does 4H help tho ?
  9. Oct 8, 2022 at 1:30 PM
    #69
    Firn
    Firn Well-Known Member
    White OR
    16k on mine now.
    A bit noisy, almost sounds like a rear end whine. Only happens occasionally and I don't mind it. If it's bothersome for some reason usually just a different throttle position or slightly different speed has it go away.
    Get the aclutch accumulator delete, really smoothes out the clutch feel, big improvement.
    You do feel how crappy the engine tune is though. Toyota really screwed up here and the power delivery is chunky and throttle response is inconsistent. You really feel it with the manual.
    Reverse is tall. Fine for day to day use but if you tow or use reverse for more than your average parking lot or driveway then get the 2lo mod.
  10. Oct 8, 2022 at 1:40 PM
    #70
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    I've only got 600 miles on my Pro 6MT and it's all smiles every time I drive it. The clutch engagement is vague but bypassing the accumulator should fix that. Clutch effort is light and I never have to think about it. It's very easy to drive and I don't mind the shift throws; after all it's a pick-up. I enjoy heel/toe downshifting (apparently a sensitive topic here) but the pedals aren't spaced appropriately for that. There's a forum member makes a spacer kit that brings the gas and brake pedals closer together.
    I found the gearing between 1st and 2nd to be too far apart, just means you want to rev out 1st gear a bit longer if you don't want to bog 2nd gear too much. Like others have mentioned, reverse is too tall but all the other gears seem fine for normal use. Some don't like the shift knob but it works for my shifting style. Some use the same grip no matter what gear they're shifting into or from. My grip changes from 1st to 2nd to 3rd, etc.
  11. Oct 8, 2022 at 2:15 PM
    #71
    GatorBodine
    GatorBodine Well-Known Member
    Jay
    23' 4 cyl.
    It gave some extra pushing power and grip while backing up the slope. I was on grass so there was slipping along with useless reverse gearing
  12. Oct 8, 2022 at 2:22 PM
    #72
    GatorBodine
    Jay
    23' 4 cyl.
    So far w/ my pro I find shifting into 2nd at about 15mph is the sweet spot, about 30mph for 3rd..... Generally shifting at 2500-3000 rpm gives the best shifts and no bogging it seems.
  13. Oct 8, 2022 at 2:28 PM
    #73
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    OP, I have a '16 6MT and an '05 5MT. They drive differently. I did own a 2000 5MT for 2 years before getting my '02 Tundra. I remember hating the suspension but enjoying the shifter and transmission.
    My bro in law who owns a horse farm and drives lots of machinery including a 10 spd Freightliner when hauling horses prefers the '05 which I find interesting.
    I like all 3 of my trucks for different reasons. As others have said, finding an MT Tacoma is hard enough, finding a Pro is harder, but at least if you do find a pro, 50/50 chance it's MT. Good luck to you.
    And, yeah, you'll want to consider 2 low and accumulator delete, then if you don't manage to get a pro, replacing the stock OffRoad suspension. Of all the mods I've done, getting Fox 2.5's with DSC is the most enjoyable.
    If you can find one, get behind the wheel. I didn't before buying (since I bought out of state and had it shipped) but now that I can drive mine back to back I really notice things. Third gen is just different. Not in a bad way.
  14. Oct 8, 2022 at 2:47 PM
    #74
    duckytw
    duckytw Well-Known Member
    Buy one and you won't regret it. You can always find/buy an auto especially as we go towards electrification.
  15. Oct 8, 2022 at 4:14 PM
    #75
    Sinister184
    Sinister184 Well-Known Member
    23 Tacoma TRD OR 4x4
    I had a first gen 2.7 5 speed about 10 years ago, and drove it for quite a while. I've had a myriad of manual cars since then (WRX, GLI, Si, GTI), and just recently got a 22' OR manual. Obviously it doesn't drive like a sports car, but i find the clutch engagement and shifting to be just fine for a truck. Reverse doesn't seem too tall to me, and i tend to shift pretty leisurely so the light rev hang suits me just fine for day-to-day driving. The AT tune in this truck is trash (had a 17' AT), so the manual was a must when I was thinking of getting back in one.
    My only gripe so far is how prominent the farm truck rattle is. I don't recall my first gen exhibiting the same behavior. There's a lot of slop somewhere in the driveline that causes a pretty noticeable rattle/clunking when going over bumpy terrain in neautral or while the clutch is down. Doesn't seem like a reliability issue, but it is annoying.
    doublethebass likes this.
  16. Oct 8, 2022 at 4:25 PM
    #76
    duplicateg
    duplicateg Member
    2004 Tacoma Offroad
    I'm reading the online specs for the 6MT pro in Canada, and there's no sign of the locker or atrac. :( Anyone know if these have been removed in 2023?
  17. Oct 8, 2022 at 4:59 PM
    #77
    GatorBodine
    Jay
    23' 4 cyl.
    Anyone know the "brand" of the MT in these trucks. Is it Toyotas or do they use another brand? Like how the Tremec is used in some mustangs, Dodges, etc...
  18. Oct 8, 2022 at 5:21 PM
    #78
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    It doesn't, 4WD low does I use it alot with my camper and the 6 speed.
  19. Oct 8, 2022 at 5:25 PM
    #79
    tcaustin
    tcaustin Well-Known Member
    Tom
    Columbia, SC
    2022 Electric Lime Pro 6MT
    TRD cue ball shift knob is so much better than the stock knob.
  20. Oct 8, 2022 at 5:35 PM
    #80
    GatorBodine
    Jay
    23' 4 cyl.
    I got the same one. Love it
    pushgears and tcaustin[QUOTED] like this.
