Considering lifting my truck, have questions!
Discussion in '1st Gen. Tacomas (1995-2004)' started by cdavi060, Mar 21, 2011.
  1. Mar 21, 2011 at 12:13 PM
    cdavi060
    cdavi060 [OP] Well-Known Member
    Virginia Beach, VA
    2016 TRD Sport 4X4 DCSB
    Full OME Lift (887), 275/70/17 BFG KO2
    I have a 2001 Tacoma double cab 4x4 and will be in need of new tires soon so figured now is the best time, if any, to consider a lift. I have been looking at getting Bilstein 5100s set at 2.5 and had some questions.
    First, I understand the front can use different notches to raise the truck, but what raises the rear? Will it require a shackle or add-a-leaf? Can I use stock springs up front with the new shocks? Secondly, I wanted to know what it would look like lifted with the stock wheels and either (275/70/16) or (265/75/16) size tires on it. Does anyone happen to have photos? Any and all help is appreciated. I have done quite a bit of searching, and these are the questions I have left.
  2. Mar 21, 2011 at 12:24 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    tint, dents, scratches, two blown speakers and trying to pay her off...
    use the search button up there ^. it has millions of answers to everyone of your questions. simple answers, if you lift the front more than a little over an inch, yes you will have to do shocks, springs or both in the back. as for the wheels, and tires, that's your opinion. . . . .like i said, search, millions of answers and pics.
  3. Mar 21, 2011 at 12:53 PM
    cdavi060
    Virginia Beach, VA
    Can I use the stock springs with the Bilstein 5100s and what should I use to keep the rear the same height? And yes I know it is my opinion, which is why I am requesting photos.
  4. Mar 21, 2011 at 3:15 PM
    davidpick
    davidpick NWXPDTN
    David
    Snohomish, WA
    2004 Xcab 4x4 TRD
    yes, you can use stock springs with the bilstein 5100s. to keep the rear the same height, do nothing. 5100s in the rear provide no lift.
  5. Mar 21, 2011 at 4:23 PM
    cdavi060
    Virginia Beach, VA
    david, thanks, okay, and if I use the stock springs on the 2.5in lift notch on the front 5100s, I will need to get 2.5in shackles or add-a-leafs to even out the rear correct?
  6. Mar 21, 2011 at 8:38 PM
    CHPTR11
    CHPTR11 Team Impulse Red
    Dan
    Pacific NW
    2004 TRD Tacoma
    OME, Hankook, ARB, SCS
    It seems most people who run the 5100 @ 2.5 run a 1.5" AAL or new leaf pack in the rear.
  7. Mar 24, 2011 at 11:32 AM
    cdavi060
    Virginia Beach, VA
    any pics of this lift on stock wheels/tires?
