Considering long travel? Read here first.
Discussion in 'Long Travel Suspension' started by Mxpatriot, Oct 2, 2011.
  1. Nov 7, 2013 at 9:56 AM
    #101
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Wat
    Soa-spring over axle
    Sac-solid axle conversion
  2. Nov 7, 2013 at 10:04 AM
    #102
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    We got a troll
  3. Nov 7, 2013 at 3:43 PM
    #103
    C.R. FAB
    C.R. FAB New Member
    CHRISTIAN
    SHERBROOKE,Qc. CANADA
    TACOMA TRD.4X4
    3 inches suspension lift,home made front bumper,kind of roll bar.modified front grill,33 inches nitto tires,and a 1o2 inches cb antenna.
    Thank's for the nick name! I like it
  4. Nov 7, 2013 at 3:57 PM
    #104
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    :D
  5. Nov 13, 2013 at 1:08 PM
    #105
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    Awesome write up here! Cant wait to start looking into a LT kit myself.
    Sub'd!
  6. Feb 18, 2014 at 11:29 AM
    #106
    2012tacoma603
    2012tacoma603 Member
    Any idea on how much lift a total chaos +3.5 kit will give you? It says 3.5 on their web page but that doesn't seem like a lot. Not looking for huge lift but....
  7. Feb 18, 2014 at 11:31 AM
    #107
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    A lift is not really the point of a LT kit, typically 3-4 for a 3.5 over is normal for 4x4, perhaps a bit more for 2wd depending on setup.
  8. Feb 18, 2014 at 3:44 PM
    #108
    2012tacoma603
    So then what's the best way to get a couple more inches out of it is like to have like 6 inches total up front
  9. Mar 11, 2014 at 4:45 PM
    #109
    Sandrail
    Sandrail Member
    Paul
    San Antonio
    08 Tacoma 4dr 4wd
    3inch lift winch mount spot lights bed mounted spare roof rack lt285 75r r16 tires cb radio
    Thanks for the info.was considering going with lt kit,but that is not gonna happen. I will be happy with my 3 inch toy tech lift.but still would like to go with double shock,on the front end.
  10. Apr 12, 2014 at 9:33 PM
    #110
    cmyersgo
    cmyersgo Well-Known Member
    Carter
    Queen Creek AZ
    So I am looking at buying a truck that has been built out already for long travel and plan on using it as a toy truck not my DD but just the weekend truck. How extensive doesn't maintenance get when you are only taking the truck out every once in a while. Looking for some local help possibly in AZ.
  11. Apr 13, 2014 at 9:17 AM
    #111
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Quite a few guys in AZ, what part? Any pics of the truck?
  12. Apr 13, 2014 at 9:56 AM
    #112
    cmyersgo
    Carter
    Queen Creek AZ
    I'm in Gilbert. The truck is in Tempe. The guy doesn't have a whole lot of information on the truck and I looked at it at night plus I don't know a whole lot about the trucks yet. Seems like a good deal to me based on all the pricing I've been finding so far on here. It's a t100 4x4 with the 4 cylinder engine. The 4x4 isn't hooked up though and the engine is re geared so it gets up and goes. The cab is caged as well and has an engine cage. As far as I could tell it looked to be all custom fabbed by the first owner.
  13. Apr 13, 2014 at 10:03 AM
    #113
    cmyersgo
    Carter
    Queen Creek AZ
    It would be cool to maybe find the previous owner of this truck to get some good info on it. Maybe they are a member here
  14. Apr 29, 2014 at 12:46 PM
    #114
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Looking forward to going LT. A lot of home work to do.
  15. Aug 10, 2014 at 11:57 PM
    #115
    UncleOrmo
    UncleOrmo Rookie
    Justin
    Rossland
    2010 TRD Off-Road AC
    Stock
    So much great information here. Thanks for paving the way. :)
  16. Sep 4, 2014 at 2:30 PM
    #116
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    What are your guys's thoughts on going LT for low speed/crawling type stuff? I've seen pics and vid of allpro's LT and T/C's +2" kit being used for low speed stuff.
    Currently running Camburg C/O's and UCA upfront.
  17. Sep 4, 2014 at 4:51 PM
    #117
    noSKills858
    noSKills858 battlescars
    Alex
    Poway, CA
    2003 5-lug Prerunner
    Couple shocks, some old tires, and a bad paint job
    Only problem with LT for that kind of thing is track width, everything else is a plus.
  18. Sep 4, 2014 at 5:16 PM
    #118
    numbah57
    kahai
    Maui, Hawaii
    That's why I was looking at the +2 kits.
  19. Sep 4, 2014 at 5:17 PM
    #119
    numbah57
    kahai
    Maui, Hawaii
    How do the extended 4x4 axles hold up with lockers?
  20. Sep 4, 2014 at 5:26 PM
    #120
    noSKills858
    Alex
    Poway, CA
    Not sure what the +2 folks use to match the front as far as thickness on wheel spacers go, but when it comes to the axles they will be fine. Only mistake some make is not limiting the travel in the front causing the cv's to bind and eventually break.
