Considering long travel? Read here first.
Discussion in 'Long Travel Suspension' started by Mxpatriot, Oct 2, 2011.
  1. Apr 7, 2016 at 2:42 PM
    #141
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    The AP kit is a +2 kit that only has provisions for a coilover. I'm getting my camburg kit installed next week with dual shocks, TC or Camburg, they are both tried and true, so you can't go wrong with either. But Camburg only has a +3.5" kit while TC has a +2" and a +3.5" kit, all of which can run dual shocks. TC also has a stock length race kit that can run dual shocks if you're worried about width.
  2. Apr 7, 2016 at 3:09 PM
    #142
    bigredT07
    bigredT07 Member
    2007 Tundra Crewmax
    12" bulletproof lift
    How much did the Camburg kit run you in total? Including shocks
  3. Apr 7, 2016 at 3:17 PM
    #143
    VolcomTacoma
    Jeff
    NorCal
    uhhhhh, well I ended up swooping up on a deal for a brand new kit local, but a new Camburg Kit plus secondary mounts with 4x4 axles will probably run you around $3500 if You can find a deal? Maybe cheaper? Maybe More? And then shocks are all up to you, what brand, where you get them. I think I ended up paying about $2500 or so for coilovers and bypasses?
  4. Apr 7, 2016 at 3:19 PM
    #144
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Do not et the all pro kit. Many issues. Go camburg
    bigredT07 likes this.
  5. Apr 7, 2016 at 3:20 PM
    #145
    VolcomTacoma
    Jeff
    NorCal
    This. Apparently.
  6. Apr 7, 2016 at 4:23 PM
    #146
    bigredT07
    bigredT07 Member
    2007 Tundra Crewmax
    Well that clears that up haha.. how did you manage to get both sets of shocks for $2500?
  7. Apr 7, 2016 at 5:05 PM
    #147
    VolcomTacoma
    Jeff
    NorCal
    Downsouthmotorsports.com
    I buy all my shocks through them, those guys are great
    Thats off the top of my head. 2.5 8" coilovers and 2.5 8" triple bypasses. Should come out around $2500
  8. Apr 7, 2016 at 5:07 PM
    #148
    bigredT07
    bigredT07 Member
    2007 Tundra Crewmax
    Can you fit bump stops on a 4X4?
  9. Apr 7, 2016 at 5:11 PM
    #149
    VolcomTacoma
    Jeff
    NorCal
    You possibly could. Alot of guys go with a coilover and a bump. Camburg recommends one or the other because its alot of shit to fit in there and with your CV axle there its hard to fit. I've been told where theres a will theres a way, but I think most peolpe just use one of the bypass tubes as a bump zone. Im still learning all of this myself so I'm no where near the expert on the matter.
  10. Apr 7, 2016 at 5:16 PM
    #150
    bigredT07
    bigredT07 Member
    2007 Tundra Crewmax
    Wouldnt that damage the bypass shock?
  11. Apr 7, 2016 at 5:24 PM
    #151
    VolcomTacoma
    Jeff
    NorCal
    Don't quote me on this, but the way O understand it is that you are making one of the compression tubes act as a bump by increasing the compression for that tube. Not a perfect bump, but if you blow through it all, you're valving is off anyways and/or you are hitting stuff way harder than you arw capable of. And then my Superbumps can handle the rest.
    @LTDSC
    @12TRDTacoma :rofl:
    LTDSC likes this.
  12. Apr 7, 2016 at 5:26 PM
    #152
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Piss off Jeff. :rofl:
  13. Apr 7, 2016 at 5:26 PM
    #153
    bigredT07
    bigredT07 Member
    2007 Tundra Crewmax
    That makes sense.. i probably wont be beating on it that hard anyways.. good stuff man thank you!
  14. Apr 7, 2016 at 5:30 PM
    #154
    VolcomTacoma
    Jeff
    NorCal
    Hey anytime, that's what we're here for!
  15. Apr 7, 2016 at 5:41 PM
    #155
    anthony250f
    Anthony
    San Diego, CA
    I have bypass bump coilovers and 4wd
    Willbeck likes this.
  16. Apr 7, 2016 at 5:43 PM
    #156
    VolcomTacoma
    Jeff
    NorCal
    1st gens can do it. 2nd gens can not. Well, like I said, Camburg doesn't recommend it.
  17. Apr 7, 2016 at 5:45 PM
    #157
    VolcomTacoma
    Jeff
    NorCal
    Maaaaaaaybe right there, but it seems pretty cramped right there.
  18. Apr 7, 2016 at 5:45 PM
    #158
    anthony250f
    Anthony
    San Diego, CA
    1st gen ftw
  19. Apr 7, 2016 at 5:45 PM
    #159
    anthony250f
    Anthony
    San Diego, CA
    When I had a 2nd gen that's where I put the bumps
  20. Apr 7, 2016 at 5:46 PM
    #160
    VolcomTacoma
    Jeff
    NorCal
    Yeah we'll see how I like it with Superbumps lol. I think once it's tuned right, I won't need bumps that much unless I'm hucking all the time
