Considering long travel? Read here first.
Discussion in 'Long Travel Suspension' started by Mxpatriot, Oct 2, 2011.
  1. Apr 7, 2016 at 5:47 PM
    #161
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I absolutely love hydro bumps and it makes it ride so much better through the big stuff.
    Cr250jumper likes this.
  2. Apr 7, 2016 at 5:49 PM
    #162
    bigredT07
    bigredT07 Member
    2007 Tundra Crewmax
    12" bulletproof lift
    what are superbumps?
  3. Apr 7, 2016 at 5:50 PM
    #163
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Damnit. Stop it. I didn't put in provisions for bumps up front. Sigh.
  4. Apr 7, 2016 at 5:50 PM
    #164
    VolcomTacoma
    Jeff
    NorCal
    Wheelers offroad.
  5. Apr 7, 2016 at 5:54 PM
    #165
    bigredT07
    bigredT07 Member
    2007 Tundra Crewmax
    ok well theyre cheaper and easier to install! and probably all i'll really need
  6. Apr 8, 2016 at 9:53 AM
    #166
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Plus you can "tune" them easily with air pressure
  7. Apr 13, 2016 at 11:45 AM
    #167
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    We put 2.0 Fox bumps on my buddy's 4x4 FJ with Total Chaos. We cut out the factory bump stop just enough to put the cans in the same spot. I did the same on my prerunner.
  8. Apr 13, 2016 at 11:50 AM
    #168
    VolcomTacoma
    Jeff
    NorCal
    Prerunners can do it all day long because there's no CV Axle in the way. 4x4s are a bit cramped. Didn't say it cant be done, where theres a will theres a way, but Its just not recommended
  9. Apr 14, 2016 at 9:10 AM
    #169
    mahaloTaco
    mahaloTaco TcBob's BFFL
    Max
    Los Angeles
    13 RC 4x4 S/C'd lockers 4.88's Airflow Snorkel McNeil Glass
  10. Apr 16, 2016 at 11:15 AM
    #170
    _SoggySenpai
    _SoggySenpai New Member
    Mark
    Anyone have any recommended books/websites/small jobs I can do to my car to get a better handle on independent car work? I'm not too knowledgeable and would like to be able to do small work like you said is necessary
  11. Apr 16, 2016 at 11:23 AM
    #171
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I have never heard that it is not reccommended ? When you remove the entire OE bump perch from the frame there is plenty of room to fit a bump even if you have a bypass...it simply occupies the same space as the OE bump
  12. Apr 16, 2016 at 12:27 PM
    #172
    VolcomTacoma
    Jeff
    NorCal
    Well, read the Camburg website, its recommend against, plus most fabricators recommend against bumping off the LCA anyways for LT
  13. Apr 16, 2016 at 4:37 PM
    #173
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    That's really only when you have a full on race kit that allows you to bump off of the upper...what 3.5" kit even has a horizontal uniball with an UCA that you could bump off of ? but then you also need a full engine cage to mount that bump to. Almost all of the kits have a reinforced bump pad on the LCA ...why would they put it there if they didn't want you to use it ?
  14. Apr 16, 2016 at 8:22 PM
    #174
    VolcomTacoma
    Jeff
    NorCal
    All I said is that Camburg recommends against 2nd gen 4x4 LT kits running all 3. You wanna do it, go for it. When a company that designed the product recommends against something, its usually smart to listen to it.
  15. Apr 16, 2016 at 9:06 PM
    #175
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    What is their exact reason for stating that, do they provide any details ? Is it simply that too many people make the mistake of running 2.5" stroke bumps and riding their bumps during 90% of the compression stroke thereby killing any of the valving of the CO or bypass ?
  16. Apr 16, 2016 at 9:11 PM
    #176
    jakebray
    jakebray Well-Known Member
    jake
    SoCal
    13 PreRunner
    Locked DCLB with Kings and crap
    That's true
  17. Apr 16, 2016 at 11:35 PM
    #177
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Dirt designs 3.5 kit has horizontal uniballs. TC is ok with bumping off the lower arms. The downside to bumping off the lower arms is you'll be into the bumps for more of your bump travel if you plan on using the full stroke of the bump do you how close the bumps are in relation to the pivot point of the arms. Bumping off the uca allows a 1 to 1 ration on bump stop travel. I see no issue on bumping off the lowers on camburg arms. In fact I have a truck sitting in my shop that was previously set up that way by another shop.
  18. Apr 18, 2016 at 12:50 PM
    #178
    Y2kbaja
    Sacramento
    Total Chaos
    If you strike the arm in the same place as the bump stop what's the difference? Now instead of slamming into the rubber bump stop is slowing the arm down with the bump stop.
  19. Jun 29, 2016 at 10:13 AM
    #179
    toyo522
    toyo522 Lost
    Nick
    LandNav
    12 Prerunner DCSB
    Not Much
    this is good information has helped me a lot, but I still have one question. I have notice on some trucks have the standard rod end on their coilovers and others have extended rod ends, is there any type of advantage to having the extended vs. standard? I ask because I found where if I build my own coilovers it comes out to be a little cheaper and the rod end was one of the options on the website.
  20. Jun 29, 2016 at 11:17 AM
    #180
    glorifiedwelder
    jason
    Santa Clarita, ca
    The extended rod ends are used on cap over coilover configuration to allow clearance for the front axles
