considering swapping my icons due to rough ride
Discussion in 'Suspension' started by highflyinmechanic, Nov 20, 2014.
  1. Nov 20, 2014 at 6:29 PM
    highflyinmechanic
    highflyinmechanic [OP] Well-Known Member
    Justin
    GA
    12 DBL CAB MGM 4x4 TRD OFFROAD
    So I have Icons currently but they ride pretty rough on road highway, interstate, slow city roads in my opinion. They ride pretty good on dirt but thats hauling ass down a dirt road. They are set at 3 inches.I live in Georgia and there arnt any deserts or whoops nearby lol to blast through.
    I'm leaning towards OME 887's and either the new OME 9021 nitrocharger shocks or bilstein 5100's. The 887 are the same spring rate as 885's but 5mm longer so no spacers needed. What do you guys think?
  2. Nov 20, 2014 at 6:38 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Rides rough where? Streets, offroad? I love my Icons, maybe you should try setting them down near 2" and adjusting your tire psi.
  3. Nov 20, 2014 at 6:42 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    No way man! Keep your icons! They're great. I love mine. I agree with TacoBrah Maybe you have yours set a little too high. Lower them an inch and lower Psi when you're wheeling and it should feel great whether you're rock crawling or going high speed.
  4. Nov 20, 2014 at 6:44 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    Interesting...
    I was considering going to icons. I wish I would have gone the 887's instead of the top plates. I really like the ride right now though.
  5. Nov 20, 2014 at 6:46 PM
    highflyinmechanic
    Justin
    GA
    To me they ride rough on the road and off. I have Dakars in the rear. I have a pretty good rake as it sits now. So I'm afraid it's going to look real goofy if I go any lower up front. I have had them for about 6 months and it bugs the crap out of me feeling every imperfection in the road.
  6. Nov 20, 2014 at 7:00 PM
    teneighty
    Maybe it's more your tires? What load range?
  7. Nov 20, 2014 at 7:06 PM
    highflyinmechanic
    Justin
    GA
    True. E. Cooper ST Max 285/75/16. I have played with the psi. I have not ran them at 32 psi though bc it just seems too low to me?
  8. Nov 20, 2014 at 7:16 PM
    teneighty
    I'm running mine at 32. They ride great and are wearing very well.
    They are still going to be stiff.
  9. Nov 20, 2014 at 7:24 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    I've got Icons set to 2", and when I first installed them I was running P metric street tires at 32 psi. They definitely ride stiffer than the factory coil overs, but not unbearably harsh. Then I got E rated BFGs and ran them at 30 psi for a while, it rode about the same as my P metrics. I have since started running them at 35 psi for gas mileage purposes. And the ride doesn't bother me too much. The wife hates it tho. I think ur problem is that u have them cranked to 3". Dial em down a bit and get a lift spindle...? Unless ur 4x4
  10. Nov 20, 2014 at 7:44 PM
    teneighty
    Sucks they ride rough at 3". If I buy some I want the full 3"... :anonymous:
    Carl_z33 likes this.
  11. Nov 20, 2014 at 7:45 PM
    TacoBrah
    Sean
    Try 32 psi it should make a difference, other than that if you want super plush on road you may wanna go back to stock.
  12. Nov 20, 2014 at 9:28 PM
    Reeves
    Reeves Well-Known Member
    Colorado Springs, CO
    08 TRD Rugged Trail
    Take them off and send them to me. I will in return send you my 5100s/885s. Problem solved
  13. Nov 20, 2014 at 9:37 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    I had good luck running the nitrogen psi in the shocks down 25 psi from the 250 they're supposed to be. After breaking in the springs I raised the pressure back up.
  14. Nov 20, 2014 at 10:26 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    You can always revalve them for slow speed but you can't crank them all the way up (0 down travel). I personally don't like E rated tires on this light of a truck. On another note I've been in a truck with OME and it rode stiff as hell due to tires.
  15. Nov 21, 2014 at 5:38 AM
    highflyinmechanic
    Justin
    GA
    It may be my E rated tires then. I guess I may be in for a new tire search now lol. I do agree the E rated tires are a bit overkill. Mine weigh 60 lbs each.
  16. Nov 21, 2014 at 6:49 AM
    catattacksdog
    catattacksdog Well-Known Member
    Not Steve
    Not Kentucky
    07 dc
    I pulled Kings to run Icons instead. Definitely the superior shock I have tried so far. I would look at other solutions before pulling them for other shocks. I run my tires at 36 and don't have any problems.
  17. Nov 21, 2014 at 3:37 PM
    highflyinmechanic
    Justin
    GA
    Well the culprit was tire psi. I had them at 50 psi lol now they are at 32psi and its night and day difference. Thanks for all the info guys. I feel kind of dumb now lol sometimes it's the simplest things....
  18. Nov 21, 2014 at 3:42 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    yep i love my icons too i run my psi at 35..glad you figured it out op
  19. Nov 21, 2014 at 4:39 PM
    teneighty
    Nice :thumbsup:
  20. Dec 5, 2014 at 7:47 AM
    TimberLandTaco
    TimberLandTaco Well-Known Member
    Mason
    Northeast Oklahoma
    2012 Timberland Mica TRD Offroad
    Light, Bumpers, and lots of switches.
    I'm about to drop my tires down to 25 psi for a smoother ride. I'm not running icons though.
