Constant 12Volt Hot in Bed of Gen 3.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gotmilktaco, May 9, 2019.
  1. May 9, 2019 at 9:39 AM
    gotmilktaco
    gotmilktaco [OP] New Member
    Los Angeles
    Gen 3 White Tacoma TRD Off-Road
    Magnaflow Custom Exhaust with Re-route around T-Case. 4x4sPod HD Power distribution system for auxiliary lighting and systems. RCI skid plates, Relentless Fab tailgate reinforcement. Prinsu Designs Rack and CBI Overland Bars. Cali Raised bed stiffeners. Bilstein 5100 Struts with set 1.55", using factory coils, Bilstein 5100 rear shocks and Pro-Comp AAL and wheels 32” wranglers A/T. ARB CKMA12 Air Compressor. Relentless Fab Stingray Lo-Pro Winch bumper, Smittybilt X2O 10,000lb Winch. Communications: Uniden CMX-660 CB Radio, Yaesu FT08800R HAM
    Hey All,
    I have a Rigid Ignite that i have set up to a set of Cali Raised Bed Stiffeners and i want power it but i am a little lost on how to get a wiring harness up to the Blue Sea Fuse panel in the engine, or if there is a Constant 12 Volt Source in that back of the truck that i can tap in to. The light is wired through a marine toggle switch in the bed. The Ignite Series Lights are Rated at 12W, so they only pull 1A or less depending on voltage potential provided so im not too concerned with run length or drawing off of another circuit, the light will not be used while im drive
    I tried the search function but all i found was constant to the trailer harness, any guidance would be very much appreciated. Cheers.
  2. May 9, 2019 at 9:41 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
  3. May 9, 2019 at 9:42 AM
    monkeyevil
    monkeyevil Victory 4x4
    Daryl
    Kalamazoo, MI
    Run a wire up the driver frame rail to the battery (in loom if you like), connect to the battery with a fuse. You can either run a ground to the frame back there, or run the ground to the battery too. I use an 8 gauage wire then split it behind the driver taillamp for my Dometic, Blue Sea panel, and bed lights.
    tonered likes this.
  4. May 9, 2019 at 9:45 AM
    gotmilktaco
    Los Angeles
    i was working on this yesterday and have got stuck at the gas tank, is there a trick for routing the loom down the frame past the tank?
  5. May 9, 2019 at 9:49 AM
    monkeyevil
    Daryl
    Kalamazoo, MI
    Run it above it, and zip tie it to what you can.
  6. May 9, 2019 at 9:50 AM
    gotmilktaco
    Los Angeles
    Copy that, ill give it a try, thank you!
