Constant beeping in 4-Lo
Discussion in '4 Cylinder' started by TPMO, Sep 24, 2017.
  1. Sep 24, 2017 at 7:12 PM
    TPMO
    TPMO [OP] Well-Known Member
    2017 Tacoma SR Utility 4x4 MT
    I have a question regarding 4-Lo. 5 speed manual trans. Why does it constantly beep in 4-Lo? I thought possibly it wasn't engaged. Drove 1/2 mile and never stopped beeping. I also never felt a change in the gearing.
    Am I not being patient enough? What gives?
  2. Sep 24, 2017 at 7:41 PM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    The beep means it hasn't actually switched into low range.
    >>This is also why you didn't feel a change in the gearing
  3. Sep 24, 2017 at 7:56 PM
    ElBlancoTaco
    ElBlancoTaco Well-Known Member
    Ron
    Scottsdale, AZ
    2014 SR5 DCSB 4x4
    You would have definitely known if it had engaged. You would have been able to about 5 mph in 1st gear and the rev's would have been over 4k.
  4. Sep 24, 2017 at 8:02 PM
    TPMO
    Exactly! Thanks! Possibly user error. As I did not go into neutral before shifting to Lo. Ill get back out and try proper procedure>
  5. Sep 24, 2017 at 8:06 PM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    When it's beeping like that, switch back to 4hi real quick and try again. Neutral, clutch to the floor, be at a dead stop.
    Hartford likes this.
  6. Sep 25, 2017 at 5:22 PM
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    ^ what he said. Only you don't have to have the stick in neutral position. Just clutch to the floor and dead stop. They say you can do it at less than 3mph or something like that, but I tried it once for shits and giggles, would never do it again.
  7. Sep 25, 2017 at 5:35 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Don't try to go straight from 2hi to 4lo. Shift into 4hi 1st and drive at least far enough to be certain it is engaged. Shift to neutral or press clutch in and then shift to 4lo. You can be moving VERY slowly, but it is generally best if completely stopped. Wait until the light comes on and stays on before placing the transmission in gear or letting out on the clutch.
    Getting out of 4lo can be tricky. Come to a complete stop, press in clutch or shift to neutral. Go to 4hi, don't try to go straight to 2hi. If it doesn't shift out of 4lo put it in reverse and back up 10-15' and retry. You may have to do the 10-15' backwards and forward dance several times until it shifts into 4hi. But most of the time it isn't much of an issue. Once in 4hi start driving and then shift on the fly to 2hi.
    aarongue and Hartford like this.
  8. Sep 25, 2017 at 7:48 PM
    TPMO
    Great advise! I'm a lazy old jeep driver. These techniques worked perfectly! I'm thinking these new trucks may need a little babying. Thank all of you for helping me thru
