Constant Humming Noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Southpawag, Jan 3, 2017.
  1. Jan 3, 2017 at 12:23 PM
    Southpawag
    Southpawag [OP] Member
    Andy
    2008 Taco
    My 2008 Taco has a constant humming noise when rolling. Good Treads and have rotated religiously. When I rap it up, the engine sounds solid. 98K on the motor. Full synthetic done every 6500K. Any thoughts?
  2. Jan 3, 2017 at 12:32 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Wheel bearing is bad
  3. Jan 3, 2017 at 12:34 PM
    Southpawag
    Andy
    2008 Taco
    No shit? Easy fix?
  4. Jan 3, 2017 at 12:37 PM
    TexasWhiteIce
    Texas
    Nice reply....
  5. Jan 3, 2017 at 12:39 PM
    Southpawag
    Andy
    2008 Taco
    Yeah that was bad. Thank you for the advice. I work in Agriculture and wrench on equipment daily. Never done a wheel bearing on a truck, only implements like disks, plows and such.
  6. Jan 3, 2017 at 12:41 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Could be any number of things in theory. Sticking brake caliper/pad. Wheel bearing. Differential issue. Drive line issue.
    Can you tell where the humming is coming from?
  7. Jan 3, 2017 at 12:47 PM
    Southpawag
    Andy
    2008 Taco
    Sounds like it's coming from the motor. Just a steady low hum. Truck seems to be running tip top.
  8. Jan 3, 2017 at 12:49 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Does the humming sound change at all with engine speed, or with vehicle speed? Important distinction here.
    Or maybe it's the same all the time regardless of changing RPMs or vehicle speed...?
    Kyitty likes this.
  9. Jan 3, 2017 at 12:50 PM
    Southpawag
    Andy
    2008 Taco
    It stays constant with the engine speed. When I rap it up, the motor sounds solid.
  10. Jan 3, 2017 at 12:52 PM
    DGXR
    Friend
    Sacramento, CA
    So you can sit there in neutral and rev the engine, and the humming sound will change along with the RPMs?
