Constant Rattle
Discussion in '1st Gen. Tacomas (1995-2004)' started by morse764, May 20, 2008.
  1. May 20, 2008 at 8:35 PM
    morse764
    morse764 [OP] Member
    03 Sr5 4x4 3.4L v6 tacoma
    sport TRD clutch, 77 series K&N intake, Trac-Rac, Borla exhaust, Air-Raid throttle body, T-ko BF goodrich tires, 7ft fischer plow
    I have a 2003 sr5 tacoma and recently when you hit any bump or slight dip in the road there is rattling noise that sounds like a dragging chain on the road or coins vibrating. I have found that it has also increased over time and is coming from under the cab. Any solutions?
  2. May 20, 2008 at 8:53 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Hey 764- the only thing I can offer is you're there and have the advantage of climbing under the truck and just poke around at stuff that would obviously make that noise with that particular characteristic. Running board mounts, exhaust shields (HOT) shackle mounts (leafsprings) stuff like that. Take some time. Hope you locate it-let us know:)
  3. May 20, 2008 at 8:58 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    definitely get under there and poke around like ridge said.....sounds like maybe an exhaust shroud/heat shield or so. hope you find it quickly man!!
  4. May 21, 2008 at 4:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    That is EXACTILLY what I would do! Use gloves and, if you have one, a rubber mallet. I did this on my 2000 when I heard a rattle, and sure enough, the heat sheild was hitting the exhaust. Gave it a quick bend and never heard from it again. :)
  5. May 25, 2008 at 10:31 PM
    LVaught1
    LVaught1 Member
    Northern California
    03 tacoma SR5
    If your truck is running roughly, too. It could be your catalytic converter is going or shot. that's what it sounded like when I had a different make truck and my converter went out.
