Contemplating trading 03 tacoma in due to axlewrap
Discussion in '1st Gen. Tacomas (1995-2004)' started by Matthewlost, Apr 14, 2011.
  1. Apr 14, 2011 at 2:17 PM
    Matthewlost
    Matthewlost [OP] Active Member
    Louisiana
    2003 Prerunner SR5 X-Cab, V6
    It bothers the shi* out of me - the thump/jolt/axlewrap madness. I find myself cursing my car everytime it happens, which is many times a day. I know most of you love your trucks and thats really great, but will aal or replacing the leafs really help. I'm skeptical. I'd like to hear from people who have had trouble fixing the issue, and what definitively fixed it for good.
    Work completed since purchase:
    Timing Belt
    Fuel Pump
    Throttle body clean (made axle wrap worse somehow)
    cleaned battery terminals
    replaced spark plugs and boot harness
    oil change
    transmission fluid drain and refill (twice)
    differential fluid change
    air filter change
    front rotors and pads change
    rear brake adjustment
    completely lubed all zirk fittings
    I spent alot of time and money getting this all done, and I'd really like to have a vehicle that doesn't go thump in the night - if you get my drift.
  2. Apr 14, 2011 at 2:20 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Replace your leaf packs and you shouldn't have this problem. I have aftermarket leafs with custom shock mounts and I don't feel and axle wrap.
  3. Apr 14, 2011 at 2:27 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Do you have a lift at all? If it's stock im going to assume that your leaf's are really tired, they normally have a bit of axle wrap but it shouldn't be that much. Or you could get a trac bar but that seem's kind of overkill not to mention expensive. an AAL probably will only bandaid the problem. Like he^ said a thicker leaf pack will definalty fix the issue. Wheeler's makes one that has gotten good review's and wont lift it much higher so you won't even need to lift the front:cool:
  4. Apr 14, 2011 at 2:27 PM
    Matthewlost
    Louisiana
    Says you drive a manual. I'd like to hear that new leaf springs fixes the problem from someone who drives an auto, since from what I've read its much more common with the auto. What type of leaf springs - oem, aftermarket? What's the cost? Do it yourself 'able' ?
  5. Apr 14, 2011 at 2:28 PM
    Matthewlost
    Louisiana
    no lift. original leaf's I assume. Purchased vehicle with 119k
  6. Apr 14, 2011 at 2:31 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Aftermarket will be cheaper. New spring's are do it yourself able if you have basic tool's. You most likley will need grinder to cut old bolts. I drive a stick so idk the auto may be worse. If your not sure the only way to delete axle wrap permantly 100% is a trac bar. Although i am pretty certain that a thicker pack will fix your problem.
    Spring's.
    Trac bar
    http://www.budbuilt.com/new/traction_bars.html
  7. Apr 14, 2011 at 2:32 PM
    Matthewlost
    Louisiana
    See pictures...
  8. Apr 14, 2011 at 2:33 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Mine did it bad when I first got the truck. I put the lift leafs in and it doesn't do it at all anymore.
    edit: yea your springs are wore out.
  9. Apr 14, 2011 at 2:34 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    It may be the pic's but it looks like your pass side leaf is a bit flat.:notsure:
  10. Apr 14, 2011 at 2:35 PM
    JLee
    Jerry
    Benicia, CA
    I do have a manual and i would think that axle wrap would be worse in a manual due the a power transfer being greater. I have AllPro Expo leafs but they are 4" over stock. You might want to go with wheelers to stay closer to stock. Don't get OEM they are crap and cost way to much. and it is simple to do yourself with simple hand tools and some know how. And that's what we are here for to give you that know how :D
  11. Apr 14, 2011 at 2:36 PM
    JLee
    Jerry
    Benicia, CA
    Toast :infantry:time to retire those.
  12. Apr 14, 2011 at 2:39 PM
    Matthewlost
    Louisiana
    more pics. hard to get a good angle on it. i'm at work.
  13. Apr 14, 2011 at 2:40 PM
    Southern01Taco
    Sean
    Holden, La
    They are definitely shot.
  14. Apr 14, 2011 at 2:45 PM
    Matthewlost
    Louisiana
    If they need to be replaced, wouldn't I notice other symptoms, besides the axle wrap? Anyway, I don't want to have to lift the front if I put in new springs, and I definitely don't want an uneven looking truck. What are my options? Rock Auto?
  15. Apr 14, 2011 at 2:46 PM
    JLee
    Jerry
    Benicia, CA
    Does your truck sit level with no lift?!
  16. Apr 14, 2011 at 2:49 PM
    Southern01Taco
    Sean
    Holden, La
    With your springs like they are, you can't haul as much weight because they are very weak.
  17. Apr 14, 2011 at 2:49 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Price wise yea, but the link i posted has beefier pack (stock hieght) but it probably cost's twice as much.
  18. Apr 14, 2011 at 2:49 PM
    Matthewlost
    Louisiana
    Yes it sits very level, from a visual standpoint.
  19. Apr 14, 2011 at 2:52 PM
    JLee
    Jerry
    Benicia, CA
    It shouldn't that right there tells you there shot. even replacing your leaf packs with OEM replacements your rear end will sit higher then the front. i would recommenced doing what capetaco12 said and get the wheelers packs they are way better then stock.
  20. Apr 14, 2011 at 2:52 PM
    Southern01Taco
    Sean
    Holden, La
    Its suppose to have a slight rake to the front from the factory.
    edit: ^^^^beat me to it.
