Continue the brake saga....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vincehutchison, Jul 15, 2020.
  1. Jul 15, 2020 at 1:47 PM
    Vincehutchison
    Vincehutchison [OP] Member
    Vince
    2006 Toyota Tacoma prerunner
    So to continue my saga. Bad new brake booster was replaced. The 2nd one seemed to work very well. Park my truck last night, so let’s fast forward to this morning. I went to drive off and my truck brakes are locked up frontwards and backwards. Thoughts??
    Thanks again.....
  2. Jul 15, 2020 at 1:54 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    this don't sound good[​IMG]
  3. Jul 15, 2020 at 1:59 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Can you pull the vacuum hose off the booster and see if the brakes unlock?
    Make sure the parking brake is ON, and in park. When the hose is disconnected the brakes will be much harder to apply.
    Have you confirmed that it’s all wheels locked up?
    And is the parking brake on? (I know, I have to ask)
    Jimmyh likes this.
  4. Jul 15, 2020 at 2:11 PM
    TnShooter
    Deogee
    STOCK
    There may also be a check valve in the vacuum hose to the booster.
    You might as well check it if you Pull the vacuum line?
    Also, is this a 4.0 or 2.7?
    DG92071 and whatstcp like this.
