Continued Issues with ABS light, Brake Lights, and STOP 10A Fuse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JAH5280, Jun 12, 2024.
  1. Jun 12, 2024 at 9:13 AM
    JAH5280
    JAH5280 [OP] Member
    Jay
    2013 Silver Tacoma SR5, Long bed
    Hello:
    My 2013 V6 Tacoma continues to have These issues:
    Brake lights not working
    My STOP fuse keeps blowing (under the hood area)
    ABS and Traction Control Lights stay on.
    Have to push button to get it into reverse
    Autozone did a diagnostic showing Error Code C1422
    and Stoplight Switch (which I replaced)
    Actions taken:
    Replaced Stoplight switch and 10A Fuse. Everything works for a couple of minutes and then
    STOP fuse gets blown and warning lights come back on.
    Any ideas on what is causing this? I am guessing a short somewhere or grounding issue?
    All input is appreciated.
  2. Jun 12, 2024 at 11:48 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would check the trailer connector for damaged wires. connector etc...This is a common failure point either from damage to the connector or corrosion.
    Here is a good read on the pinout.
    https://www.tacomaworld.com/threads/2020-tacoma-tow-hitch-wiring-harness-diagram.715537/
    One quick check would be to locate the connection between the Trailer Harness and the truck harness and disconnect it. Replace the fuse and see if it holds. If it does you found the problem in the trailer harness. If it continues to blow you have a wiring issue closer to the fuse panel.
    SR-71A and Too Stroked like this.
