Continuing issue with my 2tr-fe
Discussion in '2nd Gen. Tacomas (2005-2015)' started by smeagle, Mar 20, 2022.
  1. Mar 21, 2022 at 6:39 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Probably, most cheap generic scan tools will not show you live misfire data.
    TnShooter likes this.
  2. Mar 21, 2022 at 6:50 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m pretty sure the one that’s like $200 from Harbor Freight would read them. Or at least on a Ford.
    I no longer have that scanner. So I can’t confirm if it would on a Tacoma.
    I’m a bum. I know a guy with a Snap-On scanner.
    If I need to use a “good” scanner, I borrow his. :anonymous:
  3. Mar 21, 2022 at 7:20 PM
    smeagle
    smeagle [OP] Well-Known Member
    Justin
    Chicago, IL
    2006 2.7l 2TR-FE Tacoma
    Ahhh.. ok.. yeah, the nice one def did.. ill exchange it tomorrow.. I managed to get truck home which is nice because I've been riding my bike 7miles each way to it. Haha.
    I pulled codes when I got back and it threw p0304 (4th cylinder) and p0117 coolant temp sensor low voltage
  4. Mar 21, 2022 at 7:22 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Interesting so it sounds like the miss moved, still need to see about the coolant temp sensor circuit though.
    b_r_o likes this.
  5. Mar 21, 2022 at 7:26 PM
    smeagle
    Justin
    Chicago, IL
    Any suggestion on how to go about that.. I just replaced the ect.. that's how this all started.
  6. Mar 21, 2022 at 7:31 PM
    TnShooter
    Deogee
    STOCK
    If you disconnect the ECT and turn the truck on.
    It should read about -40c/-40f
    What does the scan tool say your ECT is while plugged in with key on/currently?
    Dm93 likes this.
  7. Mar 21, 2022 at 7:31 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If you get a scanner that can read live data you can test circuit integrity quite easily by looking at the ECT voltage, with the sensor unplugged it should read about 5v, if you short the 2 pins together it should read 0v.
    If it fails either of those 2 tests you have a wiring problem.
  8. Mar 21, 2022 at 7:40 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I will add that a problem with the coolant temp sensor can greatly affect engine performance and driveabilty since it factors heavily into base fuel calculation.
  9. Mar 21, 2022 at 8:19 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are you sure you replaced the right sensor? Coolant temp for the pcm? Some cars have 2 sensors, one for fuel calculation, one for the gauge. Not sure about those toyota engines
    Have you checked all the fuses related to the efi system? Bent pins in the connector? You might have to dig into the pcm connectors, unplug them and do some resistance tests along those wires, see if they're open or shorted
    That smell you mentioned in the first post sounds like a super lean mixture out the exhaust
  10. Mar 21, 2022 at 8:31 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    2nd gens only have 1 coolant sensor for the ECM, the ECM communicates the temp to the gauge.
    That's why I suggested a circuit integrity check using a scan tool.
  11. Mar 21, 2022 at 8:35 PM
    TnShooter
    Deogee
    STOCK
    I believe the 5VZ in the 1st Gen had 2 sensors.
    I don’t any of the 2 Gen trucks utilized 2 sensors.
  12. Mar 21, 2022 at 8:44 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes 1st gens (and many older vehicles) had a separate sensor for the gauge, when high speed module to module communications became mainstream in vehicles most went to single sensors that were read by one module and the data transmitted to the other relevant modules.
    TnShooter[QUOTED] likes this.
  13. Mar 22, 2022 at 5:25 AM
    smeagle
    Justin
    Chicago, IL
    Just to get clarification.. I would remove the resonator box, run the truck and disconnect coils while the truck is running, correct? By 'set coil circuit codes' you those are the codes that can be reset, correct?
  14. Mar 22, 2022 at 7:23 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Yes, depending on where the MAF sensor is you may have to unplug it for the truck to run with the intake hose off.
    The idea is to see which cylinders are contributing and which ones aren't.
    You should notice a pretty significant drop in engine speed when each one is unplugged, the one(s) that don't change when unplugged are your misfiring cylinder(s).
    Yes you can clear any codes that may be set when done.
    Did you also see my post about testing the ECT circuit using scan data?
  15. Mar 22, 2022 at 10:21 AM
    #35
    smeagle
    Justin
    Chicago, IL
    I did.. would that be a similar situation.. the intake manifold will need to be off for me to get to the ect
  16. Mar 22, 2022 at 10:22 AM
    #36
    smeagle
    Justin
    Chicago, IL
    I did.. would that be a similar situation.. the intake manifold will need to be off for me to get to the ect?
  17. Mar 22, 2022 at 10:33 AM
    #37
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Oh I didn't know you had to have the intake off to access the ECT connector (never had to work on a 2TR), but the engine doesn't need to be running to do any verification tests on that.
    You can look at your scan data with the engine cold and see if the coolant temp looks plausible, if it does you may try wiggling on wires while watching it and see if you have a connection issue.
  18. Mar 22, 2022 at 12:51 PM
    #38
    smeagle
    Justin
    Chicago, IL
  19. Mar 22, 2022 at 1:01 PM
    #39
    TnShooter
    Deogee
    STOCK
    The manual says it has a misfire monitor.
    How extensive it it is, such as each cylinder? I don’t know.
    The cheaper scanners are hit and miss.
    Some makes and models have more data support.
    If I were you, I would make a separate post and ask “what scanner do you have and will it show individual cylinder misfires?”
    I bet there are a bunch of people with different scanners that might help you out.
    smeagle[OP] likes this.
  20. Feb 18, 2025 at 2:43 PM
    #40
    jem122594
    jem122594 Active Member
    Joseph
    2007 Tacoma 2.7 auto 2wd
    I know this is old but what was your symptoms from coolant temp sensor going bad?
