Continuous Power Steering Issues...
Discussion in '1st Gen. Tacomas (1995-2004)' started by AlphaEcho2k5, Jul 19, 2012.
  1. Jul 19, 2012 at 9:03 PM
    AlphaEcho2k5
    AlphaEcho2k5 [OP] Well-Known Member
    Adam
    F.E. Warren AFB, WY
    '02 4Runner
    BLUF:
    I've purchased one Power Steering pump already as a replacement. I've since rebuild that pump and also added a cooler in the return line.
    I've noticed the reservoir gets extremely hot and there is some seeping right below the reservoir. A few spots of fluid will end up on the side of my airbox and on the underside of the hood directly above the pump. I have 275/75/16 tires and understand that may put strain on the system; however I'm really getting tired of having to replace / rebuild a pump every 4-6 months. I've read of issues with some 1st Gens and the P.S system, you guys have any recommendations? As always appreciate any ideas.
    Edit: I've been using Mobil 1 ATF in the system.
  2. Jul 21, 2012 at 2:06 AM
    tsab916
    tsab916 Well-Known Member
    Sacramento
    02 DC 4x4
    Maybe bad rack and pinion? You've already changed/rebuild the pump a few times already.
