Continuously Variable Transmission
Discussion in 'General Automotive' started by VanGo3, Jun 1, 2022.
  1. Jun 1, 2022 at 5:33 PM
    VanGo3
    VanGo3 [OP] Modern vehicles are ugly.
    Northern California
    20 SX AC 4x4
    Mostly dust and dirt.
    Thought some here might be interested in what an automotive CVT looks like. I know that Toyota uses this in the Corolla but I'm not sure what other models.91B27851-31C5-438E-8DD9-E822B1B269ED.jpg 1DA79366-D089-4182-B422-184EFEBDF634.jpg
    CJREX and Rock Lobster like this.
  2. Jun 1, 2022 at 5:44 PM
    Cereal_killer
    Cereal_killer Well-Known Member
    Dan
    '18 Off-road, ‘96 V6
    Yeah
    What’s the belt material and how’s it assembled?
    skeletron likes this.
  3. Jun 1, 2022 at 5:48 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I always had an oversimplified understanding of a CVT as a belt over a conical shaft. I'm just wondering what part moves to create the "V" part. :anonymous:
  4. Jun 1, 2022 at 5:53 PM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Pretty cool to see! I think it is Continuously Variable Transmission though. Constant velocity is for CV axles. Never torn one of those apart
    VanGo3[OP] and danbow like this.
  5. Jun 1, 2022 at 5:53 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Interesting...I always heard it called a Continuously Variable Transmission though, which honestly makes more sense than constant velocity.
    EDIT... @AJKlug1 beat me to it
    VanGo3[OP] and AJKlug1 like this.
  6. Jun 1, 2022 at 10:00 PM
    VanGo3
    Northern California
    20 SX AC 4x4
    You
    You are correct about the name. Thanks for pointing that out.
  7. Jun 2, 2022 at 6:47 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    I'm more familiar with snowmobile ones but they should operate pretty much the same. Think of them like gears on a bike. Low gear will be with the primary clutch (one on the right in first pic) with the belt/chain deep in the V (like small sprocket on the front of the bike). The secondary clutch (one on the left) will be opposite with the belt/chain high up (like a big sprocket on the rear of the bike). This is like first gear in your car or low gear on bike.
    To "shift" it will work just like you would on your bike. One side of the primary clutch face (called a sheave) will twist and close the gap making the belt ride higher up the clutch face changing the ratio (like move to bigger front sprocket on bike). The opposite will happen on the secondary. It will open allowing the belt to move down again changing the ratio (like going to smaller rear sprocket on bike).
    b_r_o, VanGo3[OP] and danbow like this.
  8. Aug 10, 2022 at 2:19 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    And I'm guessing (?) that metal band slipping on that pulley makes a LOT of heat?
  9. Aug 10, 2022 at 2:35 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    In the provided picture, there is 2 sets of plates, a top and bottom “plate” over and under the belt. When one set of plates open, the corresponding set of plates closes.
  10. Aug 12, 2022 at 5:49 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pretty sure all the hybrids use them
    VanGo3[QUOTED][OP] likes this.
  11. Aug 12, 2022 at 6:49 PM
    Taco16LB
    Taco16LB Well-Known Member
    VanGo3[OP] and b_r_o[QUOTED] like this.
