Control arm bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco2.74X2, Apr 5, 2023.
  1. Apr 5, 2023 at 10:52 AM
    Taco2.74X2
    Taco2.74X2 [OP] New Member
    2006 Toyota Tacoma
    2” leveling kit
    Good afternoon all!
    I am replacing most of my front end on my truck and can’t seem to take out the bolts that hold in the lower control arm and I would like to use them again if I’m able. Any advice on how to remove them and or where to buy new ones, I can’t seem to find them anywhere.
    I have a 2006 Toyota Tacoma 2.7L RWD
    Thanks!
  2. Apr 5, 2023 at 10:57 AM
    10YSON
    10YSON Well-Known Member
    GREG
    TACOMA & 4RUNNER
    TOTAL CHAOS / KING / DEAVER / PRP / DIRTKING
    I also have an 06 and when I replaced the front end on my truck the shop had to cut half the bolts to get them off.
  3. Apr 5, 2023 at 12:28 PM
    JKD
    JKD Well-Known Member
    They're probably frozen with the adjusters. Search the forum, there's info on LCA bolts, specifically how to cut the tube/bolt so you can replace them.
    If they're stuck, salvaging them is not going to be an option unless you figure out some way to press them out. Which nobody does, because the bolts are relatively cheap.
    Taco2.74X2[OP] likes this.
  4. Apr 5, 2023 at 1:03 PM
    Taco2.74X2
    2006 Toyota Tacoma
    2” leveling kit
    Thanks I appreciate it. Do you know where I might be able to find replacement bolts? I talked to all my local parts stores but nobody has them and they tell me they aren’t able to order them.
  5. Apr 5, 2023 at 1:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Did you try at the Toyota Dealer?
  6. Apr 5, 2023 at 1:43 PM
    Taco2.74X2
    2006 Toyota Tacoma
    2” leveling kit
    I have not. I’m sure they can get them for me, I just didn’t know if I could find them elsewhere and save some $$$
    Thank you for the suggestion!
    Jimmyh likes this.
  7. Apr 5, 2023 at 3:27 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    When I did mine, I bought the bushings at a parts store but I bought the replacement hardware from a Toyota dealership. I can't recommend this enough.
