Control Arm Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoshell03, Jan 13, 2013.
  1. Jan 13, 2013 at 8:14 PM
    Tacoshell03
    Tacoshell03 [OP] Member
    Gentry
    Amarillo, TX
    Black '01 plain jane
    Which would be more important to upgrade first, Upper or Lower control arm? Why do some only upgrade the upper? I'm guessing it's just a $$$ issue.
    Benefits of new control arms other than just heavier duty: Longer travel or what?
  2. Jan 13, 2013 at 8:20 PM
    dlooney
    dlooney Well-Known Member
    Dennis
    Wilmington NC
    07 TRD Sport PreRunner
    Satoshi w/ hella 500s mounted behind, 20% tint, 6K HID retro headlights, 4300k HID fog lights, DTRLs, plastidipped front valence, cb mount
    Only reason you would need to upgrade your lower control arms is if you're going long travel. Upper control arms are upgraded to keep alignment in spec after installing a lift.
  3. Jan 13, 2013 at 8:26 PM
    Tacoshell03
    Gentry
    Amarillo, TX
    Great. Thank you. Is it also necessary to get new spindles when a lift is added? Or will the UCA do the trick by itself?
  4. Jan 13, 2013 at 11:58 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    no reason to change the spindles.
