Control arms made stance narrower
Discussion in 'Suspension' started by @glass_truck, Jan 8, 2022.
  1. Jan 8, 2022 at 6:53 PM
    @glass_truck
    @glass_truck [OP] Member
    2006 tacoma trd
    5100's, top notch. coils from 2018 trd. Rough country uca's ECGs bushing Carrier bearing drop Diff drop 2" add a leafs
    Hopefully someone has had experienced this. So I did the moog LCA’s. At the same time I did 6112 struts on the tall setting and spc UCA’s. After the install it seems to have a narrower stance. I’m a bit confused because I measured the lower a arms and the seemed to be the same.
    Am I missing something?
  2. Jan 9, 2022 at 12:27 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I suggest measuring it.
  3. Jan 9, 2022 at 12:31 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Have you had an alignment done since everything was installed? An improper alignment can make all kinds of things look out of place.
    Key-Rei likes this.
  4. Jan 9, 2022 at 12:34 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    did you drive the truck or just eyeballed it after lowering the truck off of the floorjack when the install was complete. The suspension needs to settle by going forward or back some..
  5. Jan 10, 2022 at 9:26 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Any lift passed the control arm being level will narrow the stance. The more lift, the more the Lcas get "sucked" in. Another variable is your cam bolt settings and Uca settings. Depending on your alignment, that can suck the A arms in even more.
  6. Jan 12, 2022 at 5:06 PM
    CadCamMan
    CadCamMan Well-Known Member
    Mission Viejo, California
    2011 DCSB, 4WD TRD OR, 2.5 Kings
    TRD SC, suspension
    Your front wheels move in an arc throughout it's range of motion, not vertically. The front wheels are at it's maximum width when the ball joints and LCA bushings are horizontal to each other, which means the suspension is in compression on our trucks. As the suspension is uncompressed the wheels move back through that arc and are closer to each other.
    When you increase suspension travel with longer shocks the wheels move even further, so that's what you are seeing.
  7. Jan 20, 2022 at 3:12 PM
    @glass_truck
    2006 tacoma trd
    Copy that, I’ve been playing around with the height settings and have noticed this changing on me. Thank you for the wisdom.
    Key-Rei likes this.
