Control arms
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alexlopez123, Feb 24, 2020.
  1. Feb 24, 2020 at 7:13 AM
    Alexlopez123
    Alexlopez123 [OP] Well-Known Member
    Alex
    2006 silver Tacoma 4x4
    Hello I was wondering I need a little more clearance on the upper control arms but do I have to change both the top and the bottom one or can I just change the upper control arms I have a 2006 Tacoma
  2. Feb 24, 2020 at 7:15 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    You can change just the upper but if you are running big tires on a small really positive offset wheel you could still have some clearance issues. Getting a UCA with a uniball will give you the most clearance possible.
  3. Feb 24, 2020 at 7:15 AM
    Alexlopez123
    Alex
    I’m running 35s on a 4 inch lift
  4. Feb 24, 2020 at 7:17 AM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I run spc UCAS no complaints
  5. Feb 24, 2020 at 7:43 AM
    Alexlopez123
    Alex
    What’s the longest upper arm I get without changing the bottom arm
  6. Feb 24, 2020 at 7:46 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    You aren't getting them any longer they are the same stock length. They change caster and are more compact at the ball joint area for clearance.
    Why do you want to go longer?
  7. Feb 24, 2020 at 7:50 AM
    Alexlopez123
    Alex
    Cause my upper arm is right there all most touching my strut
  8. Feb 24, 2020 at 7:54 AM
    08BajaBoy
    08BajaBoy Well-Known Member
    Brian
    Southern Cal
    08 Rugged Trail PreRunner
    AFE Pro Dry S air filter, Magnaflow muffler, FabTech DirtLogic UCA, FabTech 2.5 remote resi (front) and 2.25 remote resi (rear)
    Almost touching your strut when the wheels are on the ground or when you have the truck jacked up and the wheels are off the ground (full droop)?
    DG92071 likes this.
  9. Feb 24, 2020 at 7:58 AM
    Alexlopez123
    Alex
    On the ground
  10. Feb 24, 2020 at 7:59 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    The aftermarket UCAs give more space around the strut too. Just get some Camburgs, Total Choas, etc it'll be fine. You can't go longer without going longer lowers otherwise you jack the geometry all up.
  11. Feb 24, 2020 at 7:59 AM
    DG92071
    DG92071 Well-Known Member
    Uniballs require more maintenance than a ball joint and they wear out quicker than a ball joint. Don't worry about keeping track of uniball maintenance because they'll squeak like hell when they need more grease.
  12. Feb 24, 2020 at 8:27 AM
    Alexlopez123
    Alex
    Ok that’s probably what i do than thanks
  13. Feb 24, 2020 at 8:53 AM
    ImMrCrash
    ImMrCrash Intermittent Error
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Bilstein 5100’s Dakar CS047R Supreme Suspension U-Bolt flip kit Sumo Springs Blue ADV Fiberglass Fenders 1st Gen Snorkel DV8 Apex Plate Bumper X-Bull 13k Winch KC HiLiTES 6x9 Trail-Gear Sliders 4x Innovations LCA Skids Spidertrax 1.25” Eagle Alloy 16x8 4” BS Fierce Attitude M/T 315/75R16 Bearcat 980SSB CB
    4 inch lift with a drop bracket?
    Or are you maxing out the stock suspension? Which would explain why the upper control arms are almost touching the coil at ride height.
    Muddinfun likes this.
