Convenient breakdown thanks to Pedal Commander?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Two4Runner, Apr 30, 2021.
  1. Apr 30, 2021 at 8:28 PM
    Two4Runner
    Two4Runner [OP] Well-Known Member
    LD
    Shreveport
    2017 DCSB TRD Offroad 4x4
    On a 250 mile road trip from Louisiana to Texas my Tacoma went into limp mode with brake malfunction and CEL lights on right at the entrance of a Toyota dealer! Diagnosis is my pedal commander caused the issue and I need a throttle body assembly. They did get everything reset and driving normal but I didn't go for the new throttle body. Anybody have a similar experience and what was your solution? ....yes I know about Ovtune but haven't done that yet
    Wixo likes this.
  2. Apr 30, 2021 at 8:35 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Stay stock .. even with a ov tune you might run into issues . I did a tune on my old mustang and ended up having to replace the timing chain and had the vehicle reprogrammed by the dealer luckily the dealership replaced everything under warranty. Never again I stay away from all the aftermarket tunes ...commanders and so on . It’s not worth it .
    MJTH and Mully like this.
  3. Apr 30, 2021 at 8:36 PM
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
    KDMAX 6.0
    Nuff Said
  4. Apr 30, 2021 at 8:38 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    How did the tune lead to timing chain failure? :confused:
  5. Apr 30, 2021 at 8:38 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    This is the way.
  6. Apr 30, 2021 at 8:43 PM
    Two4Runner
    LD
    Shreveport
    Yes thanks, looking into KDMAX but my question is more about other's experience with the Pedal commander side effects and solutions
  7. Apr 30, 2021 at 8:46 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Curious what the codes were. Do u still have the paperwork?
  8. Apr 30, 2021 at 8:47 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    i'm curious how the pc managed to lead to a new throttle body. Did they do some testing or is it just a guess?
  9. Apr 30, 2021 at 8:49 PM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    That thing is junk, just step on the skinny pedal faster, it does the same thing.
    Grossomotto likes this.
  10. Apr 30, 2021 at 8:56 PM
    GOTSAND?18
    stock
    No clue ... all I know I lost power and engine started making a rattling noise . Shut it down right away and towed to dealer . Dealer diagnosed it caused by the tune . Improper tune for the engine my best guess . And it was legitimate tune by Bama. Luckily the dealership overlooked the tune and fixed it anyways .
  11. Apr 30, 2021 at 8:59 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    I am the pedal commander.
    Tacotoast, hiPSI, Mully and 2 others like this.
  12. Apr 30, 2021 at 9:02 PM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    The pedal commander did not cause this, the dealer just took the easy way out and you bought it.
    SandyTaco4x4, Mully and Vlady like this.
  13. Apr 30, 2021 at 9:02 PM
    Two4Runner
    LD
    Shreveport
    No codes listed. Don't understand why I would need a throttle body assembly.IMG_20210430_225752003.jpg
  14. Apr 30, 2021 at 9:13 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    So how did the topic of the throttle body emerge than?
  15. Apr 30, 2021 at 9:16 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Those fuckers! MIL on but no codes listed :annoyed:
    Methinks it was a u-code (failure to communicate), based on the myriad of issues, abs, trans, ECU etc. After unplugging and clearing it probably went away.
    shakerhood likes this.
  16. Apr 30, 2021 at 9:38 PM
    Two4Runner
    LD
    Shreveport
    Tech said he unplugged the PC, cleared codes but no throttle response with stock throttle then plugged PC back in and cycled ignition several times and it drives normal. PC is plugged in but not turned on. Will investigate in the morning if not raining here. Don't understand the need for a new throttle body....but all this modern stuff confounds me!
    Skydvrr likes this.
  17. Apr 30, 2021 at 9:39 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    U have a code reader? Might be sime history codes stored.
  18. Apr 30, 2021 at 9:40 PM
    Silverlogic
    Tyler
    If it works with the PC plugged in, the problem isn't likely the throttle body. It would either work or not. All the PC does is tell the truck you're pressing the gas harder than you actually are.
  19. Apr 30, 2021 at 10:12 PM
    Two4Runner
    LD
    Shreveport
    Agree, yes I can get a code reader when I get back to Shreveport Sunday. Thanks for y'all's help
    Skydvrr likes this.
  20. May 1, 2021 at 5:33 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I have 50k miles on OVTune no problems, there are others who have over 100k miles with their OVTune with no issues. Either way I don’t see how the throttle body would be damaged because of a pedal commander
    Big tall dave likes this.
