Convenient switched +12v
Discussion in '3rd Gen. Tacomas (2016-2023)' started by imagineer, May 21, 2023.
  1. May 21, 2023 at 6:23 PM
    imagineer
    imagineer [OP] Well-Known Member
    2017 TRD Off Road
    None yet
    Any suggestions for where to pull a convenient switched +12v?
    I'm only 3 years behind schedule, but will be adding a lightbar behind the grill and a set of rear facing spot lights. Both will be powered via relays and I'd like to use switched +12v to power the coils on the relays. Only because they are convenient, I'd like to use an "add-a-circuit" fuse tap on one of the fuses in the box under the hood.
  2. May 22, 2023 at 4:47 AM
    caribe makaira
    Caribbean, Puerto Rico
    Inside the small box filled with relays is a good choice to tap fused IGN source. Towing battery relay or Inverter relay.
    Shellshock likes this.
  3. May 22, 2023 at 1:47 PM
    spamy
    spamy Truck guy
    NorCal
    2017 Tacoma Sport 4x4
  4. May 22, 2023 at 11:43 PM
    caribe makaira
  5. May 23, 2023 at 5:19 AM
    imagineer
    2017 TRD Off Road
    None yet
    I suppose the power for the relay coils can be un-switched, but I'd sleep better if it were.
    And Spam, that's probably the fuse I'll use.
  6. May 23, 2023 at 1:02 PM
    caribe makaira
    Switched = Ign (Ignition)...:burp:
