Conventional Oil or Synthetic oil ??? what should I use ???
Discussion in 'New Members' started by Uncelou1980, Jan 11, 2011.
  1. Jan 11, 2011 at 2:13 PM
    Uncelou1980
    Uncelou1980 [OP] Active Member
    New Jersey
    2006 Toyota Tacoma Pre-runner 2WD Double Cab
    Hello everybody !!!!!
    I have a 2006 Toyota Tacoma Pre-runner 2WD and it only has 42560 miles ... I bought it brand new and ever since then i have always used conventional oil for every oil change ( I do it every 4000 miles ) ,, i only drive my truck from my house to work and on weekends a drive it to go out to the mall and other places ...i just used for normal driving ,, nothing crazy ...
    Should i change to synthetic oil ( Mobil 1 , Castrol Synthec, etc. ) our should I continue using conventional oil ????
    Thans for the help .....
    Uncelou1980
  2. Jan 11, 2011 at 2:22 PM
    CopDoctor
    CopDoctor Well-Known Member
    Trinidad, CO
    2018 Quicksand TRD Off-Road
    give it the good stuff. synthetic!
  3. Jan 11, 2011 at 2:33 PM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Lake Jackson TX
    00 Tundra
    xxTacocaTxx likes this.
  4. Jan 11, 2011 at 2:35 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  5. Jan 11, 2011 at 4:06 PM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    Extendo performance FTW.
  6. Jan 12, 2011 at 12:27 AM
    BartStar
    BartStar Well-Known Member
    pa
    2011 Tacoma 4X4 Double Cab, 6 speed man
    No,, I do not recommend to switch to synthetic after high mileage
    You're wasting your money cause the engine is already worn and the perpose of using synthetic is "0" engine wear
    synthetic is a much smaller molecule and switching to it may cause oil leaks
    synthetic has added extreme high detergent chemicals that will clean out the inside parts of your engine, and may get into the mains or rod bearings and may or may not cause problems or lack of oil pressure.
    The proper way of using a full synthetic is start with a new engine, wait till the engine breaks in (around 10-20K miles) then switch to the synthetic and have "0" internal engine wear for the life of the engine
    TRDPro916 likes this.
  7. Jan 13, 2011 at 2:23 PM
    Uncelou1980
    New Jersey
    hey buddy thanks for your info and your help ,,, i will continue using conventional oil until the car is worth nothing .... anyway is a 2006 model and it only has like around 43000 , not bad right for a 2006 model ...
    BajaTom likes this.
  8. Jan 13, 2011 at 2:53 PM
    CopDoctor
    Trinidad, CO
    i would switch. i made the switch at 75,000 on my 2006. most anybody here will tell you to run synthetic no matter the mileage
    BajaTom likes this.
  9. Jan 13, 2011 at 5:25 PM
    Uncelou1980
    New Jersey
    What brand of synthetic Oil would be the best one for my 2006 Tacoma , Mobil 1 ??? Royal Purple ??? or Castrol Synthec ?????
    Thanks for the help ????
  10. Jan 13, 2011 at 5:28 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    amsoil what.
  11. Jan 13, 2011 at 5:46 PM
    travelingman
    travelingman What would Scooby do?
    Brian
    Ohio
    07lb4x4DC
    ticking eng.mo,ventvisors,locking tailgate,wheelmasters ss spare tire inflation line,weathertech mats
    What the hell are you talking about?! The truck has less than 43k.You call that high mileage?
  12. Jan 13, 2011 at 5:50 PM
    sethr21785
    Seth
    Lake Jackson TX
    00 Tundra
    take all the information you read in this post and forget it! you can switch to synthentic and back to conventianal at any milage. it is not going to cause and leaking problems or any other problems..
  13. Jan 13, 2011 at 5:53 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    X2
  14. Jan 14, 2011 at 2:06 AM
    BartStar
    pa
    Just trying to use common sence, why pay $10 a quart for synthetic when it doesn't improve anything?
    The number 1 reason for using a full synthetic is "0" internal engine wear
    If the internal engine is already worn then synthetic won't help
    I am a big believer in a full synthetic, I have been using it since 1996, BUT you have to use it the right way, use it on a new, or rebuilt engine, right after the engine is broken in.
    When an engine is new its tight and its expected to loosen up and break in, you find this out after a sudden increase in fuel mileage, then thats the right time to switch to a full synthetic and the engine stopps wear, from now on you get NO "0" internal wear.
    I have seen too many people in the past make the mistake of switching to a full synthetic after high mileage and they experienced major engine oil leaks, exhaust smoking, poor perfomance, not saying this will happen to everybody, but I wouldn't take the chance!
    You need to understand the difference between a conventional oil and a synthetic oil, I explained that in another post.
  15. Jan 14, 2011 at 2:31 AM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    You should be fine continuing on with Dino.....save yourself some money..
  16. Jan 14, 2011 at 3:31 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    You may get away with switching between petroleum based & synthetic lubes, but I wouldn't go switching 1 synth. for another, remember its NOT PETROLEUM !! Some of those exotic syn blends have some wierd properties & react badly to other exotic syns, which gets acidic, I don't have to go further to tell you what happens... just my $.02
  17. Jan 14, 2011 at 3:36 AM
    moe1967
    moe1967 Well-Known Member
    2010 TRD DC Off-Road PreRunner
    Just made the switch to synthetic on my 04 4Runner with 67K miles. I can tell you that my engine seems to run smoother and quieter. Have not notice any leaks thus far.
    Let it be known that before the switch I religiously change the oil every 3K. My impression was that if an engine has been well maintained it is OK to switched to synthetic at anytime.
    Also, with the price of dino oil on the rise, why not start using synthetic and change every 5K. Overall, the price is about the same-at least in my situation it is.
  18. Jan 14, 2011 at 4:53 AM
    Jraugust
    Jraugust Well-Known Member
    Jeremie
    Eastern WA
    04 Tacoma SR5
    Fabtech 6" Suspension lift 17" XD wheels 35 in Toyo MT Black powder coated tool box.
    Ive always been a firm believer, if you treat your truck right it will treat you right! synthetic!
  19. Jan 14, 2011 at 6:46 AM
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    The oil debate will go on and on and on.........
    Yes Syn will clean your engine.
    46K is not High miles.......
    SYn will not sludge like Dyno oil..
    You can run SYn or Dyno oil to the Manufacturers recommended change interval, unless it is heavy use, then follow their intervals for that.
    Dyno should be changed every 6 mo's or at miles. Reason being is it becomes acidic with time due to its very nature.
    SYn can run the mileage regardless of time. It will not become acidic over time
    People who have problems when they switch are usually the ones that have not done regular oil changes when using dyno and have sludging and excessive wear due to poor oil quality over a long period of time. When they put syn in it does clean the built up crap out, and the engine may exhibit some of the symptoms listed above.
    On the other hand; If you have been doing regular maintenance there should be a nice clean engine to put SYn oil into with no ill effects.
    I started using Syn oil in my old 85 Jetta with 300K+ mile on it. I did regular maintenance always. There was no change in oil consumption, leaking, etc.. In fact the SYN oil with all its additives seemed to help the old seals on that motor and there was less dripping, although there was not much to begin with.
    Do your homework, make your own well informed decision, and drive happy.
    Paul
  20. Jan 14, 2011 at 1:32 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    Welcome!!!
