conventional or synthetic
Discussion in 'Technical Chat' started by TacoBoss05, Feb 2, 2010.
  1. Feb 2, 2010 at 10:15 PM
    TacoBoss05
    TacoBoss05 [OP] Well-Known Member
    Julio
    Fayetteville,GA
    PreRunner SR5 Six speed
    Ipod converter on stock head unit, detachable fiberglass bedcover
    I would like to change to synthetic but I just want to know if I do will it harm the engine if I switch from conventional to synthetic
    I have the 1-GR-E engine
  2. Feb 2, 2010 at 10:45 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    No it will not harm your engine in any way, it will be better for your engine. There are a lot of myth's about synthetic oil that are all false. I would suggest doing a search on this site, using the search function at the top. You will find very good information on the subject and discussion. Most people on here use Mobil 1, I would suggest using that. And yes you can switch to a synthetic oil after using a Dino oil. And vise versa
  3. Feb 2, 2010 at 10:48 PM
    ILove2Drive
    ILove2Drive Well-Known Member
    Casey
    WV
    07 Tacoma 4X4 5 Speed Manual
    Halo headlights, Black tail light covers, dual exhaust, 5100s front and rear, eibach coils, wheelers 1.5 AAL, window tint, bow arrow antenna, bull bar, painted grille emblem, debadged, raceline rims, a few decals, CB radio, alpine HU, husky floor liners, tool box, mesh grill...and more to come eventually
    Is that the case even for high mileage? I have over 154,000 miles and as far as I know its never had synthetic in it. Would it hurt it? And would I see advantages to using it instead? Thanks!
  4. Feb 2, 2010 at 10:54 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yes, synthetic oil will rejuvenate old gaskets and seals. A high mileage synthetic oil will be great, will help clean out sludge. Will also provide better protection.
  5. Feb 2, 2010 at 10:56 PM
    ILove2Drive
    Casey
    WV
    Sweet :D I know what I'm goin for next oil change! Thanks man! And you'd say go Mobil 1?
  6. Feb 2, 2010 at 10:58 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    No problem, yep go with Mobil 1. :thumbsup:
  7. Feb 2, 2010 at 11:02 PM
    ILove2Drive
    Casey
    WV
    Thanks man :D. It may just be something normal but when I get on the gas in my truck I can hear something that sounds kinda like the valves are "chattering" maybe the synthetic will help that out, that'd be sweet :)
  8. Feb 2, 2010 at 11:09 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I would say that you can try using the synthetic, but also try running some fuel injector cleaner threw. That valve chattering could be a lot of different things. Is the chattering very loud, or quiet? Is it all the time, or when getting on the gas after start up?
  9. Feb 3, 2010 at 7:30 AM
    ILove2Drive
    Casey
    WV
    I will definitely give the synthetic a try first and just see if it helps anything. And excuse my ignorance, I'm trying to learn :eek: how would I run the cleaner through the engine? Its pretty quiet but its definitely noticeable if you have music down and listen for it. Its not all the time, pretty much just anytime you're really getting on the gas.
  10. Feb 3, 2010 at 7:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    I went form Castrol GTX to Amsoil at 130K on my 98 2.7L with no issues.
  11. Feb 3, 2010 at 12:59 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    I'll answer the valve question first, I think you should continue to listen to it and if it gets louder and happens more often then that would be a good time to take it in. They can take off the valve covers and inspect the rockers and other items and go from there for worse case.
    But It could be some deposits on the valves, and this was why I suggested cleaner and it is a good start. But like I said it could be a lot of different causes for this. I'm sure we will have others suggest other causes that will help you out, and I hope to see that. The more the better! But for now, I don't think you should worry too much.
    And to answer the cleaner question. There is a lot of different cleaners out there, and everyone has a suggestion. For the high amount of miles on your truck, I would HIGHLY suggest using Seafoam cleaner! However using this cleaner is a little more difficult than using a standard cleaner. Other companies products will have you put the cleaner into the gas tank before fill up, and that's it. With Seafoam, you put half of it into the gas tank like other products. But the other half can be put threw the brake booster line, and other vacuum lines.
    The company also recommends using 1/3 into the gas tank, 1/3 into the brake booster, and then putting the remaining 1/3 into the oil. This might be better for you, will help clean up the upper heads. But if you use it in the oil, drain the oil after a 50 miles or so, so I've heard. I have never used it in the oil yet, no reason too.
    Here is a link on this website to help explain it a little better, and It's for 1st Gen. And here is an old video from the seafoam company that explains it too.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/63790-seafoam.html
    http://www.youtube.com/watch?v=D11ZVYwj62w
    [​IMG] [​IMG]
    If you would not like to use seafoam, I would suggest Chevron Techron cleaner. Just put it in before filling it up, and that's it.
    I would also recommend changing the fuel filter out too before using these cleaners for now, but you don't have too and It's not a must. But if it was changed recently, then it will be fine. Hope that helps and good luck! :)
  12. Feb 3, 2010 at 3:20 PM
    ILove2Drive
    Casey
    WV
    Wow! Very helpful info, thank you very much man! +1 :D
  13. Feb 3, 2010 at 8:30 PM
    TacoBoss05
    Julio
    Fayetteville,GA
    so I really dont need to waste my time with starting with synthetic blend then switch to full synthetic
  14. Feb 3, 2010 at 8:34 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yep, It's fine.
  15. Feb 4, 2010 at 4:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    ^^What Dick said.
    :D
  16. Feb 4, 2010 at 5:19 AM
    sioux_hockey_guy
    sioux_hockey_guy Well-Known Member
    Bismarck, ND
    Black '08 TRD OR 2" Leveled
    Eibach front springs, Billstein 5100's set at .85" Rear blocks (1.5"?) w, TSB. To be replaced w/ AAL
  17. Apr 1, 2010 at 10:47 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Just came across this while doing a search. BUT my question: You can go back to dino after running synthetic? I've alway been told its ok to go from dyno to synthetic, but not ok to go synthetic back to dyno.
    Is that another myth? I've been hearing this for years regarding motorcycles. :confused:
    Thanks.
  18. Apr 1, 2010 at 10:58 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Yep, It's fine.
  19. Apr 23, 2010 at 3:02 PM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    On such a high mileage motor it's probably a good idea to make at least one change of the synthetic fill on a normal interval before trying to go to an extended OCI. That's because of what was said before: synthetics are great at cleaning out old sludge. The first change is almost like an engine oil flush so it's good to get the old gunk out as soon as you can.
  20. Apr 23, 2010 at 3:09 PM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    I use Mobil 1 and change the oil and filter every 5,000 miles
