Conventional vs Synthetic Gear Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FireSavage, Mar 8, 2023.
  1. Mar 8, 2023 at 10:33 PM
    FireSavage
    FireSavage [OP] Salvage Tile Beater - Fixer Up!
    Paul
    Oakland
    2000 Tacoma V6
    Robnik likes this.
  2. Mar 8, 2023 at 10:45 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Robnik likes this.
  3. Mar 8, 2023 at 11:13 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Synthetic is fine. I'd suggest:
    Mobil 1 is good, also :)
    Taco 422 and Chuy like this.
  4. Mar 8, 2023 at 11:39 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Yes, syn is better. If you have a mechanical slip diff, you don't need to add lsd additive. And go for the squishy bags - you will not need a funnel.
  5. Mar 9, 2023 at 2:34 AM
    jlemmond
    jlemmond Well-Known Member
    josh
    Monroe, NC
    2006 GX470
    If you havnt done your diff oil in a long time, I suggest buying something cheap in the appropriate weight. Change it and run it for 5k miles. Think of it as flushing it out.
    Drain it again and go with something like Amsoil or Mobil 1 and resume regular intervals.
    Spif, Toms2Yotas and FishaRnekEd like this.
  6. Mar 9, 2023 at 2:41 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Always remove fills plugs before drain plugs.
    Its a bad day with a empty diff and no way to fill it.
    Taco 422, MSgt O, Squirt and 3 others like this.
  7. Mar 9, 2023 at 4:41 AM
    jlemmond
    josh
    Monroe, NC
    2006 GX470
    Also this!
    Squirt likes this.
  8. Mar 9, 2023 at 8:05 AM
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
  9. Mar 9, 2023 at 8:16 AM
    cfcarpenter
    cfcarpenter Well-Known Member
    Clint
    PNW
    2005 DCLB 4wd MT
    I did some reading on this the other night and changed my truck last night. I went with the Valvoline bags of synthetic 75/90 for the front diff and transfer case, Redline MTL for the transmission (manual) and conventional Valvoline 80/90 with CRC Trans-X limited slip additive.
  10. Mar 9, 2023 at 9:29 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    OP has a 2000. It’s a 1st Gen.
    He never said what components he is putting the gear oil in.
    He also didn’t say if he has an Open Diff, or LSD.
