Conversion of Oil housings
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bulldog, Nov 18, 2022.
  1. Nov 26, 2022 at 10:20 PM
    #61
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    I call bullshit on TCCN dude saying if the internal tube ever comes out of the housing, you just need to throw it away and that’s that, or you’re risking serious engine failure. I’m supposed to believe that little spring is calibrated so precisely for this bypass valve, that simply taking it out and putting it back in the same position (which is exactly what needs to be done to switch to an aluminum housing) somehow makes it not work anymore and will cause oil starvation. Hmmm, don’t think so.
    Not to mention, as a tech working on other people’s cars, we’re expected to believe he knows the history of everyone’s bypass valve springs? He inherently knows when someone removed and replaced it at some point in the past, and that caused engine damage at some point in the future? That’s pretty unbelievable.
  2. Nov 26, 2022 at 10:37 PM
    #62
    saint277
    saint277 Vigilo Confido
    That coil spring isn't the bypass valve, it just tensions and seals the drain valve. This flat clock spring locking thing is the bypass valve, and would not be harmed by removal. Alot of misinformation for someone who should know better.
    brian2sun[QUOTED] likes this.
