Conversion to 4x4 and manual transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ap1991, Nov 5, 2023.
  1. Nov 5, 2023 at 3:08 PM
    ap1991
    ap1991 [OP] Member
    Anthony
    2011 Tacoma Prerunner
    I've looked up a bunch of stuff on both conversions for 4x4 and switching to a manuel transmission. Im just not sure if I need to switch wiring and the ecu for the transmission? Or just plug and play? I have a 2011 double cab 2.7 prerunner and Im taking the transfer case from a fj and taking the transmission and the other parts I need from a 2011 2.7 regular cab. I know Ill need to get my driveline modified. Any help or any good links would be appreciated thanks!
  2. Nov 5, 2023 at 3:15 PM
    E4x4
    E4x4 Active Member
    2015 TRDOR 6MT
    Just buy a manual 4x4 and done.
    Dbarffish likes this.
  3. Nov 5, 2023 at 3:17 PM
    ap1991
    ap1991 [OP] Member
    Anthony
    I got the prerunner for cheap with low miles and the parts truck for cheap. Much cheaper than buying a 4x4 tacoma
  4. Nov 5, 2023 at 3:35 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
  5. Nov 5, 2023 at 3:47 PM
    ap1991
    ap1991 [OP] Member
    Anthony
    I have not seen that post. This will help a ton thanks you so much!
    0xDEADBEEF likes this.
  6. Nov 5, 2023 at 4:55 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    If you do the work yourself, you'll just about break even. If you have to pay someone to do even part of the work you'll spend more on the conversion.
  7. Nov 5, 2023 at 5:04 PM
    ap1991
    ap1991 [OP] Member
    Anthony
    ill have around 10k in a double cab tacoma with 80k miles so ill be pretty happy once its all done. I know its not the v6 but i cant complain
