Conversions to TRD Off-Road
Discussion in '1st Gen. Tacomas (1995-2004)' started by TGurau, Apr 6, 2010.
  1. Apr 6, 2010 at 12:19 AM
    TGurau
    TGurau [OP] Well-Known Member
    Tibi
    Portland, OR
    '98 SR5 4x4
    3" OME Suspension lift. PEX motoring headlights.
    So the only regret I have about my truck is that it's not a TRD Off-Road. It crossed my mind to MAKE it one. If anyone here is thinking what I'm thinking or has already done it, please, do tell!
  2. Apr 6, 2010 at 1:14 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    x2. Thats the MAIN difference.
  3. Apr 6, 2010 at 6:28 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Get an ARB locker.
  4. Apr 6, 2010 at 6:33 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Thats it lock it.
  5. Apr 6, 2010 at 8:12 AM
    ntujyug
    ntujyug Member
    You can always place a TRD sticker on it to make it look cool.:)
    But if you have money than replace shocks, get off-road tires, and a factory e-locker.
  6. Apr 6, 2010 at 8:16 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Eff that-If you have the money get better than stockl gear. Set up a real OR rig
  7. Apr 6, 2010 at 8:23 AM
    misterquad
    misterquad Well-Known Member
    Shawnee, KS
    Progressive springs too!
  8. Apr 6, 2010 at 8:46 AM
    3.4PDM
    3.4PDM Well-Known Member
    What shocks are on the TRD?
  9. Apr 6, 2010 at 9:03 AM
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    Is this a job that can be done alone?
  10. Apr 6, 2010 at 12:02 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Which "this" are we talking about??
    To convert springs and shocks isn't really hard if you are handy with the right tools.
    The rear end swap to an E-locker rear end could be easy if you get an entire rear end.
    If you decide to get an ARB locker and/or a gear swap....You should probably have it done unless you know what you are doing already.
  11. Apr 6, 2010 at 6:50 PM
    pmbazus
    pmbazus Well-Known Member
    AZ
    2020 TRD Off Road
    Get a Powertrax No-Slip. Very good locker. I have one in my truck. Works great. You can also upgrade your shocks with Bilstein 5100's. You can do this by yourself.
  12. Apr 6, 2010 at 6:55 PM
    LILFURR
    LILFURR Well-Known Member
    Mitch
    Chesapeake, VA
    2005 4.0l 6speed sr5
    6 inch fabtech, 3 inch body lift spidertrax wheel spacers, grillcraft insert with black grill, black trex3 eyelids, custom VT emblem(not mounted) courtesy metalmiller, custom VT shifter courtesy pope953, bhlm, tinted fogs
    i wanna be a bm but the more and more i read brunes post the more i feel myself drifting to the aviation side:p
  13. Apr 6, 2010 at 7:14 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    True dat!! Lol.
  14. Apr 6, 2010 at 7:47 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Chances are...if he has to ask Is this a job that can be done alone? then he probably doesn't know.
    To add: An ARB should be done by a professional installer and preferably a person who has experience installing them.
    If you or they screw it up - that's $800 (cost of ARB approx), $$$ for gears/install, plus whatever it destroys in your differential (bearings, etc.) gone down the drain.
  15. Apr 6, 2010 at 7:52 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Chances are I knew that...but he left the question pretty open ended....so I covered all the bases.
    And I do not agree with needing a professional installer. It's not THAT hard to set up differential. You need the right tools and the right knowledge- but that professional started out somewhere doing his/her first diff build at some point.
    If you take the time and do it right with the testing/fit checks-You'll be just fine.
  16. Apr 6, 2010 at 10:54 PM
    RideFast
    RideFast on the flats.
    Jesse
    Albuquerque New Mexico
    Tacoma
    well you got to ask yourself, do you really wheel that much that you need a locker? If you do then have one put in.
  17. Apr 6, 2010 at 10:55 PM
    Schully
    Schully Well-Known Member
    Aaron
    Austin
    Black 09 2.7 AC 4x4
    not cool!
  18. Apr 6, 2010 at 11:21 PM
    Janster
    Jandy
    Lancaster, PA
    Doing gears are one thing and manageable for most DIY's.... but installing an ARB locker AND gears and trusting that you've done it properly and hoping you won't blow your $1000 investment?
    Uhhh....I wouldn't even trust myself doing that. That's WAY too much money to take an educated (but no experience) stab in the dark.
  19. Apr 7, 2010 at 8:12 AM
    RideFast
    Jesse
    Tacoma
    or you could save your $$$ and get a wicked front bumper and winch and install yourself.
  20. Apr 7, 2010 at 4:11 PM
    TGurau
    Tibi
    Portland, OR
    '98 SR5 4x4
    I worked on helicopters for about 4 years. There's a mechanism on this helicopter that allows the tail to fold for conservation of space. There's another mechanism called a pin puller that locks the tail in place during flight. It's hydraulicly actuated and it uses gears to pull/push the pins in place. If the pin puller is not installed properly, it can shear the pins and fold the tail in flight, dropping a 30 million dollar helicopter. I assure you, I've never installed this thing wrong. Now, I've never installed an ARB locker but how difficult can it be for a guy with my background? If I have the proper tools and instruction, I can save hundreds on paying some other guy to do it. Anyone agree!?
