Convert 12v to 6v for OEM Camera
Discussion in 'Audio & Video' started by 1gr8ftoy, Mar 22, 2011.
  1. Mar 22, 2011 at 11:04 AM
    1gr8ftoy
    1gr8ftoy [OP] Member
    Riverside, CA
    06 4WD Access Cab TRD Off-Road
    I am looking at picking up the OEM tailgate camera and putting it in my 2006. I would then hookup the output to my AVIC-X920bt, not a backup mirror. Because of this, I need to step down from 12v to 6v for the camera power, can anybody give me any pointers on how they have done this? TIA
  2. Mar 22, 2011 at 2:05 PM
    1gr8ftoy
    Riverside, CA
  3. Mar 22, 2011 at 3:13 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    thanks for posting that. I'll eventually do this mod :)
  4. Mar 22, 2011 at 5:12 PM
    bookmonke
    bookmonke Well-Known Member
    Mark
    Jacksonville, FL
    2008 DC PreRunner Rugged Trail
    Been thinking of getting the oem camera, been looking to make a deal with someone with a fleet vehicle that doesn't really to get the mirror to make it work, gave you rep. for the great find.
  5. Mar 22, 2011 at 5:23 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    That writeup from TN is the way I would do it except I would also do something to support the pins of the 7806. Otherwise, they will break off due to normal road vibration. Maybe turn the 7806 around in the heat sink and use some caulk to glue the pins and wires to the heat sink.
  6. Mar 22, 2011 at 10:05 PM
    1gr8ftoy
    Riverside, CA
    Thanks for the tip, I will do that!
  7. Dec 14, 2017 at 5:38 AM
    tbird95
    tbird95 Well-Known Member
    British Columbia, Canada
    TRD sport SR5 V6 DC, LB, 4x4, Tow package
    4runner heated, signal, courtesy light side mirrors, rearview mirror w/compass, temp & backup cam w/ pop luck PL 5400, Interior lights/gauges, BHLM, grillcraft MX black. Third brake light LED swap, rear tail lights LED swap from 2011. 3" Toytec (Boss) Coil overs, rear TSB AAL Bilsteins, Light Racing UCA. TRD grill badge, VIPER Smart Start.
    I've got a 2011 Tacoma with existing camera and in mirror display with seperate compass and temp. What I'm wanting to do is use my factory wiring to connect a new mirror with compass and temp in the mirror display. The wires simply y-splice off the mirror harness in the headliner I already have the mirror it's a gentex 3320S w/o homelink. My problem is not wanting to fry my camera or mirror as it's 12v and the factory stuff is 6v. Any ideas where a guy could get the pinout for the mirror and if it's necessary to reduce the voltage
  8. Dec 14, 2017 at 12:51 PM
    Purpleman
    Purpleman Well-Known Member
    Anaheim
    15 PreRunner
