Convert 6" lift coil overs to standard?
Discussion in 'Suspension' started by reg0928, Feb 13, 2023.
  1. Feb 13, 2023 at 7:26 AM
    reg0928
    reg0928 [OP] Well-Known Member
    Ross
    Crestone, Colorado
    05 TRD OR Access Cab
    3"OME, 255/85R16
    So when I originally bought my truck it had a 6" drop bracket kit on it.
    I decided to make the 6" lift as "done right" as you can, and I bought full length 6" Fox coil overs and full custom leaf packs for it.
    In the end I still hated the drop bracket lift, though and I ended up having a shop fab me a crossmember and dropping back down to a 3" using OME nitrochargers.
    I still have the Fox full length 6" coil overs. Before I try to sell them I'm curious as to whether or not I can make use of them.
    My question is this... is there a way to convert the 6" lift coil overs to standard 2-3" coil overs? Different rod ends possibly?
    The travel is the same so it makes me think it might be possible...
    @AccuTune Offroad ???
  2. Feb 13, 2023 at 7:32 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Can't convert them, longer body, longer rod end, longer spring etc... You have to compare shock lengths, not travel.
    alwaysHI and reg0928[OP] like this.
  3. Feb 13, 2023 at 7:48 AM
    reg0928
    Ross
    Crestone, Colorado
    3"OME, 255/85R16
    Well that's dumb lol.
    Thanks for the info!
    AccuTune Offroad likes this.
  4. Feb 13, 2023 at 8:30 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Anything is possible with enough time and money!
    You will need to replace everything in between the upper and lower mount to convert to a shorter length shock. It's probably best to sell them and buy the correct shocks from accutune!
  5. Feb 13, 2023 at 8:40 AM
    reg0928
    Ross
    Crestone, Colorado
    3"OME, 255/85R16
    Yeah I was hoping it would just be a change of rod end and not a big deal. Definitely more efficient just to sell these and buy new ones once the nitrochargers go bad.
  6. Feb 13, 2023 at 9:23 AM
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    How many miles on them? Haha
    My full length bilsteins are about 5 1/2 years old
  7. Feb 13, 2023 at 10:48 AM
    reg0928
    Ross
    Crestone, Colorado
    3"OME, 255/85R16
    25k-ish? Not exactly sure. No leaks or squeaks then I took them off of the truck. I've got Fox 2.0 rears too...
    Shoot me a PM if you wanna work something out. I'll let em go for cheap since I can't use em
  8. Jun 20, 2023 at 3:05 PM
    kozy
    kozy Well-Known Member
    Tim
    Arizona
    2006 Access Cab 4x4/6MT
    Did you ever end up selling the front fox coilovers? If not, I might be interested.
  9. Jun 21, 2023 at 8:47 AM
    reg0928
    Ross
    Crestone, Colorado
    3"OME, 255/85R16
    Nope, I've still got them. Shoot me a PM and I'll give you a good price
