Convert needs help w suspension / wheels
Discussion in 'Tundras' started by Chain, Nov 19, 2013.
  1. Nov 19, 2013 at 3:43 PM
    Chain
    Chain [OP] New Member
    Central IL / Baja
    Tundra
    Camburg 2.5, Budbuilt skids, Toyo AT
    After looking a Toyotas from the Chevy side of the lot for a few years, I've decided to join your crew.
    Plan is to put together a 2014 Tundra 5.7 for DD and back country travel 5-6 trips a year.
    Truck will be used for work most days and to get off the beaten path on weekends. Plan on several trips to CO and WY each year to wander.
    Currently, I do these trips and trips to Mexico on an XR650r, so adventure travel in a truck is all new to me.
    So, that said, and after some research, here's my plan
    Before taking delivery, install
    Camburg 2.5 performance kit w/o leaf spring kit
    18" wheels (procomp??) any other preferences?
    Toyo 33" AT II tires
    Once I get it home and recover finances
    , install expedition one bumpers, warn m series and some sort of skid plate.
    Any wisdom from experience would be greatly appreciated
    Cheers!
    chain
  2. Nov 20, 2013 at 10:36 AM
    KayStrait
    KayStrait Camburg Girl
    Kayla
    Huntington Beach
    '98 Desert Dune SR5 4Runner
    Welcome! Not sure if you have had a chance to check out our website but I attached a few pictures of a new Tundra with our 2.5 Kit installed and Pro Comp wheels to give you an idea of what your truck could look like. Let me know if you have any questions and I'll help you out :)
  3. Nov 20, 2013 at 6:31 PM
    Chas of MRT
    Chas of MRT Total Automotive Performance
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    That sounds like an awesome setup! I am a big fan of Camburg and often recommend it to my customers.
    Check out this 2014 with full Camburg kit I saw at SEMA.
  4. Nov 20, 2013 at 6:31 PM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Here is another, a bit tamer.
  5. Nov 21, 2013 at 4:31 AM
    Chain
    Central IL / Baja
    Tundra
    Thanks for the photos Kay. That's even the same color.
    Nice shots from SEMA! The second truck looks real similar to the build I have in mind
    The dealer may have a set of of TRD Rock Warriors to throw in the deal.
    Any thoughts on those wheels. I personally like the looks of them, and they appear to be pretty robust.
    Also, I haven't done anything to the rear leafs yet. Is that necessary? Whatever I do back there, it's important that the truck still be able to haul a decent payload, and pull a tractor, or trailer full of motorcycles or a spaceship...
    Thanks again for the help!
  6. Nov 21, 2013 at 9:03 AM
    KayStrait
    Kayla
    Huntington Beach
    This one has our long travel kit on it. As far as deavers.... they are not intended to be used when you tow often unfortunately. What you can do is a 1.50 rear shackle.
  7. Nov 21, 2013 at 11:16 AM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    There are a few full length Toyota Tundra leaf spring expansion packs that will replace the factory secondary leafs while retaining the factory main and overload springs. This will allow you to increase ride comfort, obtain lift height, maintain load and towing capacities, and increase wheel travel slightly. Pair that with a set of 2.5" reservoir or bypass shocks and that should me more than good offroad, while keeping your payload carrying capability intact.
    As for the rock warrior wheels, they are pretty good size at 17x8 and are stout. If you like that look and the dealer is going to toss them in, go for it!
  8. Nov 22, 2013 at 4:23 AM
    Chain
    Central IL / Baja
    Tundra
    Good info on the rear suspension. Dealer sold the TRD rims to another customer, so for now going to use the stock rims w/ 33" Toyo AT II and then adding Budbuilt
    Spending way to much time researching / shopping for parts, kind of addictive...
  9. Nov 22, 2013 at 10:08 AM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Haha this is where the fun starts. Please let me know if I can be of any help - have built several Tundras so have a good idea of what works.
  10. Nov 22, 2013 at 11:39 PM
    gb42
    gb42 Well-Known Member
    Geoff
    WA State
    2016 MGM TRD OR DCSB MT
    How much for the pair? I want to make them hang like sleeve of wizard.
  11. Nov 23, 2013 at 8:55 AM
    Chas of MRT
    Chas
    Las Vegas, NV
    06 Tundra V8
    Airaid Bilstein
    Normally priced at MAP, we are having a killer black Friday special. I will give you a hookup price ;)
  12. Nov 23, 2013 at 11:07 PM
    BRYLONATOR
    BRYLONATOR I now own a RAM....shoot me
    Denver, Colorado
    Chillin in a 120!
    You should definitely consider replacing those shackles with a set from this guy called coachbuilder. Not only is he an amazing guy to work with but his products are awesome. And I am not a nut swinger....just a very satisfied customer!
  13. Dec 3, 2013 at 5:07 PM
    Chain
    Central IL / Baja
    Tundra
    Good call on the Shackles, called Kayla at Camburg today. Dealer should be adding them to the order.
    Now waiting on EX One to to get 2014 bumpers figured out.
    Next on the agenda is to figure out some sort of expedition rack/ sleeping accommodation that will work as a DD...
    May have to break out the pipe bender...
