Convert OE Kings to LT spec
Discussion in 'Suspension' started by Stagarm, Dec 3, 2022.
  1. Dec 6, 2022 at 6:29 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    :rofl: Did the OP really just ask for a free shock to verify his own claim?
    This idea sounds great and all until the shaft bottoms out internally because the body is too short. 7.5” of exposed shaft doesn’t mean 7.5” of travel in all scenarios.
  2. Dec 6, 2022 at 6:33 AM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    The fact that thousands of people aren't on this debunking it is sus. OP just broke kings market.
    whatstcp and Stagarm[OP] like this.
  3. Dec 6, 2022 at 5:39 PM
    Stagarm
    Stagarm [OP] Well-Known Member
    Trev
    Fj
    Me behind the wheel
    Like my first post stated I've already sold my oe's so im unable to test. The new owner of the oe's stated that they have been running this set up on there rig for years. Total choas +2 kit.
  4. Dec 7, 2022 at 11:25 AM
    AccuTune Offroad
    AccuTune Offroad Well-Known Member Vendor
    El Cajon, CA
    Ok, I got lucky and caught one of our assemblers in back revalving a 25001-119-EXT coilover. The facts are in!
    [below] Here is the entire piston rod assembly removed from the shock body. We then removed the long spacer thats on the shaft and reinstalled.
    [below] Shock assembled and compressed fully until bottom out internally with piston hitting top cap:
    [below]
    Spacer length next to shock fully compressed. Keep in mind its still missing the lower spring perch which takes up a small amount of space as well. This is all very precise so the shock does not bottom out internally with the piston hitting the top cap. This shock is built specifically for one application.
    [below]
    This is the top cap on these coilovers. They thread INTO the body, not over it. The bottom end of the top cap does not allow the piston rod assembly to pass through it. Deceiving, unless you are familiar with how these shock get assembled.
    ** I would highly recommend that no one removes this spacer **
  5. Dec 7, 2022 at 11:34 AM
    Stagarm
    Trev
    Fj
    Me behind the wheel
  6. Dec 7, 2022 at 11:37 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Just came to say the same.
    AccuTune Offroad likes this.
  7. Apr 22, 2024 at 9:36 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Are these accurate part names? Is it called a shaft spacer?
