Convert to 2010 Tacoma Factory MP3 radio possible?
Discussion in 'Audio & Video' started by kalib0y, Jan 7, 2010.
  1. Jan 7, 2010 at 1:38 PM
    kalib0y
    kalib0y [OP] Well-Known Member
    2008 Toyota Tacoma Rugged Trail
    Hey Guys,
    I currently have a 2008 Tacoma with a factory 6 disc but I wanted to change it to the 2009/2010 factory MP3 playing 6 disc unit. I got a hold of the head unit and tried to swap them but the rear plugs are different.
    Is there a conversion kit out there? Do any of you guys have the wiring diagrams to both the pre-2009 and the 2009/2010 radios?
    I am going this route because I really like to keep my radios stock. Just the ability to play mp3 cds would be great.
    Thanks in advance!
  2. Jan 7, 2010 at 6:41 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    what is different? there was guy that stated he installed an 09 radio into his 08, all PNP??
    wiring diagram for the 2005 can be found at ncttora.com, havent found any 09+ info...
  3. Jan 7, 2010 at 10:59 PM
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Hey, I was wondering the same thing.
    How much did you pay for that new deck?
  4. Jan 7, 2010 at 11:14 PM
    billyjoe
    billyjoe Taco Fever - I've got it bad!
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    Extang Trifecta Tonneau
    I replaced my single-disc '05 non-JBL radio w/same from an '09. Plug-n-Play all the way. Plus I was able to add ASL and an AUX Jack. My guess is your connectors were different because one radio was a JBL unit and the other wasn't.
  5. Jan 7, 2010 at 11:24 PM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    ^ good info, thanks! what else was required to add ASL (auto sound leveling?) and an AUX Jack? reason i ask, i picked up an 09 radio that im going to offer to swap the LED and put up for sale here and i want to know all the options the 05-08 guys will have, thanks!
    i agree w/ the jbl, no jbl deal...i did an LED swap for a guy that had a JBL radio, i was not able to hook it up to my truck to test, the harnesses were different. i also have an 05-08 radio and an 09 radio, and all the connections in the back look exactly the same.
  6. Jan 8, 2010 at 12:06 AM
    billyjoe
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    yosh - Attached doc has details for ASL & AUX...
  7. Jan 8, 2010 at 6:50 AM
    yosh2000
    Denver, CO
    '17 Tundra CM 5.7
    sweet, thanks man! where did you get that? any more 09 stuff you have?
  8. Jan 8, 2010 at 9:47 AM
    billyjoe
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    Gleaned most info from FSM and a whole lota forum surfing, and when all else fails, buying specific components and tracing out the circuits myself.
    Toyota is bad about "black boxing" certain components in their schematics - leaving out critical details such as the switched parallel resistors inside the AUX IN jack. Without them, it won't work!
    Recently, I had to break down & pay $15 for two day access to Toyota's online service info website (TIS) to get the schematic for my current project: an '09 electro-chromatic rear view mirror w/rear camera display.
    There was too much mis-information on the forums and I needed to know for sure from an indisputable source since the risk factor was relatively high due to the cost of the components. Good thing too - turns out the real thing was quite different from all the guesswork going on in the forums.
  9. Jan 8, 2010 at 9:50 AM
    kalib0y
    yeah my stock changer is a non-JBL, and the 2010 radio is a JBL :(
    Are there any ways of converting to a JBL system, like adapting harnesses?
  10. Jan 8, 2010 at 6:48 PM
    billyjoe
    Bill
    Richmond, VA
    13 DCLB V6 4WD LTD
    Simple answer - NO. The difference is the non-JBL radios have a built-in amp. On the other hand, the JBL units require an external amp. So, in order to use your current JBL radio, you would need to aquire the matching amp, get the schematic so you know how to connect the two, then wire the whole thing.
    Personally, I would put the JBL up for sale and go shopping for a non-JBL unit or an aftermarket HU. Recently, a WTB post appeared where the OP was looking for a 09+ JBL 6-Disc OEM Radio. Here you go:
    http://www.tacomaworld.com/forum/buy-sell-trade/66942-looking-09-10-radio.html
  11. Jan 8, 2010 at 7:09 PM
    kalib0y
    thanks! I will reply and put up my own separate thread
