Convert to 2wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by slicnic81, Sep 19, 2019.
  1. Sep 19, 2019 at 4:20 PM
    slicnic81
    slicnic81 [OP] Member
    I have a 2014 mt OR Tacoma. I am curious if i am able to convert this to a 2wd by getting rid of the front driveshaft diff and front axles. i have 2wd knuckles from a friend so that wont be a problem. In my head this seems like it will work but i'm wondering if i will run into any problems anywhere.
    I know this seems kinda silly. All i see is people converting the other way around.
  2. Sep 19, 2019 at 4:22 PM
    rmorse
    rmorse Well-Known Member
    Bobby
    Bowie, MD
    2015 Blue Ribbon Metallic Access Cab TRD Sport
    One of the biggest issues you’re going to run into is your truck will no longer have 4x4....
  3. Sep 19, 2019 at 4:24 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Seriously... why?
    CygnusX191, MtnMan307 and bigmw like this.
  4. Sep 19, 2019 at 4:27 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    It's doable you don't need 2wd spindles unless they already have the bearings in them otherwise you just need to put 2wd bearings in your spindles. You'll have to keep your t-case unless you modify your trans x-member and stick a 2wd trans in it and a 2wd driveshaft. Essentially you'll be doing everything backwards of a 2wd to 4wd swap.
  5. Sep 19, 2019 at 4:29 PM
    eon_blue
    Azusa, CA
    Gonna greatly reduce it's resale value if you go through with this, if that's something that matters to you anyway.
    4x4s bring in better value in the first place, but I imagine a 4x4 --> 2wd conversion will hurt this truck's resale even more.
    What's the reasoning behind wanting to do this? Only one I've seen on here that did it was because they were building a custom turbo race truck out of it and the 4wd components were unnecessary weight/risk.
  6. Sep 19, 2019 at 4:30 PM
    dumontrider
    dumontrider Well-Known Member
    La Habra, CA
    14 GX460
    Mods please move this to 3rd gen forum. There's no way this can be anything but.
    Op: the only benefit I can think of is fuel & maintenance. But the drawback is loss of resell value, likely in great excess of what you'll save in maintenance nickel & dime expenses.
    Is it possible? Sure! :sawzall::welder:
  7. Sep 19, 2019 at 4:31 PM
    pnw.river.junkie
    pnw.river.junkie Well-Known Member
    PNW
    Stating the obvious but.... 4x4 trucks are worth more than 2wd trucks. Why not sell yours, buy a similar 2wd truck, pocket the extra cash and save the headache of doing a conversion?
  8. Sep 19, 2019 at 4:45 PM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    All you have to do is remove the CV's and let all the diff fluid drain out. Then remove 4X4 stickers and you now have a 2wd
  9. Sep 19, 2019 at 4:45 PM
    eon_blue
    Azusa, CA
    And a destroyed front differential lol
  10. Sep 19, 2019 at 4:46 PM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    He won't need it anymore lol
  11. Sep 19, 2019 at 4:47 PM
    baldridge
    baldridge War Eagle!!!!! KN4OYZ
    Bart
    Auburn, AL
    2015 MGM TRD Offroad and 2015 Black Prerunner SR5
    OME Lift with HD Dakar’s C4 Slim Line Bumper 4.88 ECGS Gears ARB Single Air Compressor ARB Rear Air Locker JBA UCA’s 285 BFG KO2’s Weather Tech Floor Mats Martin OffRoad Rack Console Vault KB Voodoo Cab Height Rack 23Zero RTT 23Zero Awning 23Zero Shower Tent Maxtrax Black MaxTrax amounting Pins Krazy Beaver Shovel Fiskers Axe Smittybilt ace and Shovel Mount Quickfists Rotopax 4 Gallon Rotopax Mounting Plate Rotopax Mounting Brackets Decked Storage System Alu Cab XL Tilt Fridge Slide ARB Elements Fridge OEM Skid Plate Local Sliders Uniden 510XL Cali Raised Tailgate Antenna Mount Fire Stick 3 foot Antenna PowerTray Fuse Panel Blue Seas Fuse Box Blue Seas Breaker Cali Raised Ditch Light Mounts Rigid Ditch Lights Alpha Rex Head Lights with LED bulbs Blue Ridge Overland Tacoma Attic Blue Ridge Overland Seat storage bags
    This thread is a day early this week. :facepalm:
    CygnusX191 and CouchlessPotato like this.
  12. Sep 19, 2019 at 4:49 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    STOOOPID
    Thuguon2.7 likes this.
  13. Sep 19, 2019 at 4:49 PM
    slicnic81
    Awesome guys. thanks for all the input.
    Thuguon2.7 and CouchlessPotato like this.
  14. Sep 19, 2019 at 4:49 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    I can almost bet some one on here will trade you their pre runner plus cash for your 4x4. Also lay off the acid
    PzTank, CygnusX191, bigmw and 5 others like this.
  15. Sep 19, 2019 at 4:50 PM
    pnw.river.junkie
    PNW
    How about a manual hub conversion so you can disengage the 4x4 stuff without totally diminishing the value of your truck?
  16. Sep 19, 2019 at 4:50 PM
    eon_blue
    Azusa, CA
    This and building a street/race truck are the only reasons I could see wanting to ditch the 4x4
  17. Sep 19, 2019 at 4:50 PM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Just never activate that 4wd switch. Boom!
    MtnMan307, Yann, Thuguon2.7 and 3 others like this.
  18. Sep 19, 2019 at 4:51 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Trade for a 2WD. You won't destroy a truck and you'll be able to upgrade to a much nicer truck since 2WD are worth less. And one of the wackos posting about converting their 2WD into 4WD will be saved a bunch of headaches. Everybody wins.
    TireFire likes this.
  19. Sep 19, 2019 at 4:52 PM
    slicnic81
    This is the reason
  20. Sep 19, 2019 at 4:52 PM
    eon_blue
    Azusa, CA
    ^^ this
    Hell probably half the people in this country with part time 4wd never use it and probably forgot it's even there, same difference really minus the work of having to take it out.
    If you never use it you'll likely never have to worry about all the maintenance associated with it
