Convert Transfer Case to Manual Levers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BottleShark, Nov 23, 2022.
  1. Nov 23, 2022 at 5:22 PM
    BottleShark
    BottleShark [OP] Well-Known Member
    TJ
    Bullard, Tx
    2018 White TRD Offroad Long Bed
    2" lift, AAL Rear, Front bumper, 12k Winch
    So, has anyone ever made a kit to remove to electric controls on transfer case and switch it to manual levers?
  2. Nov 23, 2022 at 5:28 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
  3. Nov 23, 2022 at 5:30 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    People have done it on a 2nd gen by either swapping the transfer case or upconverting a 2WD with a donor FJ cruiser.
    I'm not sure of a successful 3rd gen example though. The electronics are... Finicky.
  4. Nov 23, 2022 at 6:07 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Why. I've had both and a dial is much much better. If you want a lot of maintenance and upkeep then keep up this dream.
    The guys who build the buggies and heavy off road trucks use manual levers because it's easiest, not because it's better. Plus they are using doublers and other stuff that would be a nightmare to electrify.
    LG888, TRD75, Junkhead and 4 others like this.
  5. Nov 23, 2022 at 6:10 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Having manual control is only part of the problem. I don't believe the FJ case gives you lower gearing and that is what we need.
    SH10151 likes this.
  6. Nov 24, 2022 at 6:39 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I’ve also had both. I’m not anti technology at all but I can’t think of one single benefit to choosing the knob. Even if I could think of one, I could think of far more benefits to the lever.
  7. Nov 24, 2022 at 6:52 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I’m curious what the numbers are. I’ve seen a lot of broken actuator posts on this site, and the electronics really aren’t that complicated.
    hiPSI[QUOTED] likes this.
  8. Nov 24, 2022 at 7:30 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Solenoids take the place of manual detents. There is really no advantage either way. I have had problems with both ways.
    TRD75 likes this.
  9. Nov 24, 2022 at 7:31 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Troubleshooting is easier with manual. That's it.
  10. Nov 24, 2022 at 7:44 PM
    0xDEADBEEF
    Solenoids seem to add potential failure points in that they require more seals, where as a manual case has one big seal on the top. Most of the fails I’ve seen are with water/mud intrusion to those solenoids.
    Junkhead and hiPSI[QUOTED] like this.
  11. Nov 24, 2022 at 8:24 PM
    Gatafly
    Gatafly Well-Known Member
    Shawn
    2020 TRD OR AT V6 MGM
    You mean when they are finicky and don't want to go into 4wd because everything isn't perfect and under no tension to allow the electronic actuators to work correctly and the manual you can grab and give a little stronger jerk and it goes into 4wd isn't a good reason? Yeah, that is a good run on sentence:). The issue rears its head if you end up in a situation where you have to put it into 4wd to get unstuck/out of your situation. I had this happen in a Ranger and was not fun. I would take a second lever in the cab any day.
    Junkhead, DJB1 and hiPSI[QUOTED] like this.
  12. Nov 24, 2022 at 8:27 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Until you have a second lever that wears out and vibrates and won't go into gear. There are advantages and there are disadvantages. You gotta live both.
    Junkhead likes this.
  13. Nov 24, 2022 at 8:42 PM
    Gatafly
    Shawn
    Never experienced that let alone heard of that except in old 70's Chevy trucks, but they still worked.
  14. Nov 24, 2022 at 8:45 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Jeeps. Enough said. Chevys too. Lived the dream both ways. I really see no advantage either way.
    Gatafly[QUOTED] likes this.
  15. Nov 24, 2022 at 8:47 PM
    BLtheP
    Plano, TX
    I don’t think either way is perfect but the physical shifter is far less likely to fail. And if it does, it’s usually a simple/cheap mechanical fix whereas with the fancy knob setup, you’re usually looking at a pricey control module or actuator. I don’t hate the knob in normal operation but when it fails, it’s a bad day. I also like that you get neutral with physical shifting cases.
    At the end of the day both do (mostly) work fine though.
    only issues I’ve seen on Jeeps is where the folks install a body lift which tweaks the linkage into not working. A cable shifter solves that for good. Never seen issues once a cable is in and working.
  16. Nov 24, 2022 at 9:17 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I have never met a 2nd or 3rd gen Tacoma that wasn't finicky to engage 4HI and 4LO. Once my 2nd gen got stuck in 4LO, only had 48,000 miles on it at the time, and I fought with it for an hour until it finally went back into high range. Of course I was 250 miles from home and out of cell range. I was about to kick the stupid plastic actuator motor off the T-case and try to pull the linkage out with a pair of channel locks. I thought it was just my 2nd gen until I spent time in others. Then I thought it was just a 2nd gen thing but my friend's 3rd gen he bought new is the same way. My first gen with the superior manual lever instantly engaged and disengaged every time. I've had several company Ford and Chevy full size pickups with electronic transfer cases, all of them worked quickly and flawlessly. Now I'm on the hunt for a new camping and off-roading truck, it was about to be a Heep Wrangler but I think I've come to my senses and I'm going to get an FJ Cruiser, the last Toyota 4X4 sold in the US with a manual transmission and manual transfer case.
    G8R_Taco, BLtheP and Gatafly like this.
  17. Nov 25, 2022 at 5:51 AM
    Kaptain_02
    Kaptain_02 2019 OR
    :confused:
    I don't think you understand how 'levers' work. There's nothing to wear out or fail (with exception of a shift bushing)
    Having a purely mechanical way of moving the shift forks in the transfer case is always better than relying on a electronic way to do so.
    TacoMike, hiPSI[QUOTED] and BLtheP like this.
  18. Nov 25, 2022 at 6:25 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Lol I had to tie my Jeep shifter to the dash with a string to keep it in 4wd so I beg to differ.
    You make the statement above that it is always better to have a mechanical interface. Why then, does just about every single auto manufacturer in the world use electronic controls for 4wd?
    Last one I had with two levers was a 4runner and it was just as much a pain in the ass to shift it as the old Jeeps were.
    I get the simplicity aspect for sure, but why make one thing simpler on a vehicle full of complexity? If we followed that logic we could go back to carburators instead of fuel injection, 8 track tape players instead of Spotify and... since this is a lever thread, let's go back to the days of vehicle HVAC operated by levers! And... Headlight dimmers that were a click button on the floor! And more levers... A manual choke! And let's get rid of automatics and make the Tacoma great by only offering manual transmissions!
    I say all this tongue in cheek but levers?
    Solenoids and electric motors last an awfully long time and work really well.
    Chew and Thatbassguy like this.
  19. Nov 25, 2022 at 6:38 AM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    To save space in the console? Or, because that's what most consumers (not enthusiasts) want?
    What year 4Runner? Mine's totally smooth at nearly 90K miles, as was the lever in my '94 with ~220K when I traded it in.
    I haven't noticed any threads about lever operated transfer cases failing to engage or disengage 4wd. However, I've heard of electronic actuators failing. I'd be more concerned about the actuator in my front differential failing than my transfer case.
    That said, the actuator failures are rare and usually seem to be caused by a lack of maintenance or exercise.
    I definitely don't think it's worth switching to a lever just for the sake of switching to a lever. But, given the choice, I'll take a lever.
    Kaptain_02 and hiPSI[QUOTED] like this.
  20. Nov 25, 2022 at 6:41 AM
    smithlaketaco
    smithlaketaco Well-Known Member
    Houston, Al
    95 TRD OR,2002 TRD OR,2020 AG PRO ALL MT
    I have both now. I prefer the 02 with levers way way way better than the 20 with its stupid knob. Entering 4WD on the 02 is instant and the 20 is hit or miss. And the 02 has 506K miles and it has never never had a problem with 4WD.
