Converted to propane-knocks on lp
Discussion in 'Technical Chat' started by 05tacomalp, Jul 4, 2013.
  1. Jul 4, 2013 at 8:58 AM
    05tacomalp
    05tacomalp [OP] New Member
    Fl
    05 Tacoma 4x4
    Propane
    I can't seem to find the cure to this. It only knocks on LP. Can the timing be adjusted?
  2. Jul 4, 2013 at 2:13 PM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    The only way to cure a knock condition is if the ECU is programmed to LP conversion. The timing will all be based on assuming you are running gasoline.
  3. Jul 8, 2013 at 5:42 AM
    05tacomalp
    Fl
    05 Tacoma 4x4
    Propane
    Does the 05 have an octane sensor? Could Running premium gas advance the timing enough to stop the knock?
  4. Jul 8, 2013 at 7:38 AM
    BamaToy1997
    Bill
    Navarre, FL
    As I recall, they don't use octane sensors, but instead typically they ramp the timing up until it senses preignition, then backs it down. I am not sure how that would work when running LP.
  5. Jul 8, 2013 at 12:07 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Diff breather relocated, Grillcraft insert, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Inverter anytime mod, Bronze SCS F-5's, Icon RR's, Dakar leafs, Superbumps, Pelfreybilt front bumper, Pelfreybilt rear HC w/swingout, Retrofit headlamps
    Propane has an octane rating of 112, so it should be well above the level of premium gas. Could it be possible you are not running enough propane causing a lean knock?
  6. Jul 9, 2013 at 6:41 PM
    05tacomalp
    Fl
    05 Tacoma 4x4
    Propane
    I believe it should be getting ample propane. The exhaust trims were matched to the petrol trims. The system is a pretty pricey Prins VSI(Autogas) duel fuel system.
