Converting 2.7 from FI to carburated?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kayakingguy, May 23, 2017.
  1. May 23, 2017 at 4:19 PM
    kayakingguy
    kayakingguy [OP] Ask about my custom truck detailing!
    OutsidaTampa
    Sorry if this has been covered, but is there a good reference site for a build/conversion from EFI to carburation on the 3rz motors? Part of me wants to have the simplicity of being able to adjust everything myself, get rid of the computer and a lot of the extraneous stuff...
  2. May 23, 2017 at 4:20 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I highly doubt it considering everything involved with the ECM and electronics.
  3. May 23, 2017 at 5:14 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I'm betting that there is noplace for the distributer on a newer 2.7, but certainly if you want to go back to carburated I understand. It would involve pretty much ripping out all the electrics and I'm sure that some of the street rod suppliers could help you replace them.
  4. May 25, 2017 at 2:57 PM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Nope, because there is no good reason to go back to a carb over EFI. Go standalone ECU if you want to adjust everything.
    cruiserguy likes this.
  5. May 25, 2017 at 6:01 PM
    Indy
    Indy Master of all I survey.
    Simplicity is turning the key and driving off, day after day, regardless of temperature or elevation change. That's fuel injection.
    Spending thousands in cash and hundreds of hours trying to re-engineer a modern engine just to have to constantly adjust it and have it not perform as well is the opposite of simplicity.
