Converting Clutch-Based LSD to Geared LSD on a Tacoma PreRunner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yoco07, Dec 20, 2024.
  1. Dec 20, 2024 at 8:10 AM
    Yoco07
    Yoco07 [OP] Well-Known Member
    Hello everyone,
    I’ve got a Toyota Tacoma PreRunner 2WD with a clutch-based LSD diff. Over the years, I’ve added a few upgrades like a 3-inch lift and some solid off-road tires with good tread. I mainly use it for camping trips, driving on gravel, and light off-roading on flat, dusty trails. So far, it’s been handling everything without a hitch.
    That said, I’ve been thinking about the possibility of tackling slightly more exciting off-road terrain (nothing extreme like rock crawling but perhaps steeper hills, uneven surfaces, or more challenging dirt trails).
    From what I’ve learned, a geared LSD does a better job transferring torque and is built to last longer, especially when things get tough on uneven terrain, compared to a clutch-based LSD.
    Now, before I go further, I know some might suggest trading it in for a 4WD or selling it and buying a 4WD. While I respect that opinion, I’d like to stick with this truck since I’m the first owner and have already invested a lot in off-road upgrades and accessories, etc.
    So, I’m reaching out to ask the forum for advice on this potential conversion.
    Specifically:
    Cost: What kind of budget should I expect for the swap, including parts and labor?
    Performance: I’m doing, like uneven dirt roads, steeper hills, uneven surfaces, or more challenging dirt trails (light to moderate trails, loose dirt, etc.)?
    Gas Mileage: Will swapping to a geared LSD mess with my fuel efficiency much?
    Future Problems: Are there any known issues with geared LSDs in the long term (maintenance, reliability, etc.)?
    Is it worth it?: Or is the clutch-based LSD already sufficient for my use case?
    I’d really appreciate hearing from anyone who has done this conversion or has experience with both types of LSD in a similar setup. Your insights will help me decide whether this upgrade is worth pursuing or if I should stick with my current setup. T
    Thanks in advance for your advice and suggestions.
    Cheers!
  2. Dec 20, 2024 at 8:16 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    I wouldn't go from one LSD to another if you are looking for better performance. It would probably be about the same cost to go with an actual locker, like an air locker. You'd have to turn it off and on, but I think it'd be your best bet for increased offroad performance.
    Barsoom and LOLLY like this.
  3. Dec 20, 2024 at 8:52 AM
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Maybe take a look at the Eaton Detroit Trutrac.
  4. Dec 20, 2024 at 10:25 AM
    TacoTuesday1
    FL
    I have a 4x4 TRD Sport 8.4.
    It came clutch LSD. Now has TrueTrac.
    A clutch LSD wears and was spec'd on the truck for 265 65 17 tires.
    Larger tires probably overpower it.
    jackn7 and Yoco07[OP] like this.
  5. Dec 20, 2024 at 11:37 AM
    Yoco07
    The downside to an air locker is that when it’s unlocked, it acts like an open differential, which can let one wheel spin freely while the other doesn’t. That can feel like a step down compared to the LSD, especially when driving on pavement.
  6. Dec 20, 2024 at 11:39 AM
    Yoco07
    Nice setup! BTW, is your TRD sport manual or automatic?
  7. Dec 20, 2024 at 11:44 AM
    YF_Ryan
    Kent, WA
    It's a trade off for sure, but one LSD to another is only going to marginally improve the offroad ability which sounded like the reason for the change. I never even turn the LSD on on my truck unless it's to screw around, I just let the traction control take care of things on the pavement. Does your truck have the LSD on all the time? Mine you have to actually turn it on. Are you sure you aren't confusing the LSD kicking in and the TCS kicking in? One is the clutch in the diff like you said, the other i believe runs off brake modulation at each corner and cutting engine power.
  8. Dec 20, 2024 at 3:56 PM
    Yoco07
    This truck came equipped with an LSD that's always on because it doesn’t have an on/off switch. It’s part of the base model. Toyota confirmed that my truck has a geared LSD, but I’m a bit confused about it. Geared LSD seems more relevant to clutch gearing, and my truck has an automatic transmission.
  9. Dec 20, 2024 at 9:46 PM
    YF_Ryan
    Kent, WA
    Interesting... So 05 to 08 had a mechanical LSD. Never knew that. After that they went to brake contolled auto-LSD. Not sure what kind of mechanical LSD it has, cant find if it's torsen or a clutch type, but the one post I saw mentioning it said it is probably clutch type. Most of what I could find is people arguing over the existence of the mechanical LSD, as most thought it was only ever the brake type auto lsd via traction control (TRAC). Interesting stuff. I can get now why you want to keep the LSD for the street since you must not have traction control like I was assuming.
  10. Dec 21, 2024 at 4:26 AM
    Clearwater Bill
    Billy
    Largo Florida
    Did I miss somewhere the year of your truck?
    I think things changed somewhere during the 2nd gen run
  11. Dec 21, 2024 at 5:11 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
  12. Dec 21, 2024 at 12:15 PM
    TacoTuesday1
    FL
    manual
  13. Dec 21, 2024 at 12:29 PM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    Eaton Truetrac helical Torsen (torque sensing) for the win. I had one on the rear axle in my 2G truck (which my son now has) that I put in when the factory mechanical LSD got tired. The Truetrac is fantastic in the real world. Seamless moving power to the wheel with traction on pavement/dirt/snow/wet.
    If you have been getting where you want with a tired factory clutch LSD in a 2WD truck then you already know how to use your truck and will like the upgrade.
    Lockers are nice for the 0.1% when you need one (and I have a rear locker in my current SUV). TrueTrac is nice 99% of the time. Mine was ~$1.1K installed pre-Covid.
  14. Dec 21, 2024 at 1:18 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    To answer one of your initially posted concerns, I think that a 2WD with something like a Truetrac, is really quite capable if you avoid certain situations. I put a Pwertrax unit in an F150 years back and it made a nice difference.
    I think you're on the right track and agree with the recommendation of the truetrac.
  15. Dec 22, 2024 at 6:37 AM
    Yoco07
    So it makes sense that the dealership's statement was 100% correct. My truck has an automatic transmission, so it should have a geared LSD.
  16. Dec 22, 2024 at 6:40 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    It's technically not a "geared" LSD. It's mechanical but uses a pre-loaded clutch pack that limits slip (like posi-traction). The clutch pack wears out over time and needs to be rebuilt.
  17. Dec 22, 2024 at 7:02 AM
    Yoco07
    So, does that mean my truck came with a clutch-based mechanical LSD? My interpretation of your statement about the 'pre-loaded clutch pack that limits slip (like posi-traction)' especially the word 'clutch' is that it typically applies to trucks with manual transmissions. Is that correct?
  18. Dec 22, 2024 at 7:13 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yes. Irrelevant of the transmission.
    Just for fun, manuals have a clutch to engage the engine. Automatics have internal clutch packs to transfer power as well
    Don't let the word clutch throw you
  19. Dec 22, 2024 at 8:32 AM
    TacoTuesday1
    FL
    Early models had a clutch type LSD that can be verified by getting underneath the truck to see if it has a red vertical sticker that says LSD.
    later years did not.
    the factory LSD is a clutch type. Meaning it is sensitive to fluid choice, can wear out, and can be overpowered by bigger tires.
    the truetrac LSD is not a clutch type. Not every LSD is clutch type. For example a helical LSD. That does not require maintenance by not having a clutch that wears. All clutches wear. Transmission clutches. AC compressor clutches. Etc.
  20. Dec 22, 2024 at 8:40 AM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    Truetrac does not fit the early 2nd Gen TRD OR PreRunners.
    Ask me how i know....
