Converting rear drum brakes to disc brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nwfisher, Jun 10, 2018.
  1. Jun 10, 2018 at 5:18 PM
    nwfisher
    nwfisher [OP] New Member
    2013 Silver Toyota Tacoma
    Performance chip, cold air intake, performance mass air flow sensor
    Has anyone converted rear drum brakes to disc brakes on 2013 Tacoma? Are there kits available? How hard is it to do? I have two floor jacks and a Sears Mechanic tool set along with torque wrenches and extensions.
  2. Jun 10, 2018 at 5:49 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Jun 12, 2018 at 9:40 AM
    nwfisher
    Does not answer my question. Thanks, anyway.
  4. Jun 12, 2018 at 10:56 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
  5. Jun 12, 2018 at 10:58 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Yes, there are kits avail.
    I wouldn't do it!
  6. Jun 12, 2018 at 11:00 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    You will not notice any great gains by doing this. It is possible yet not very practical. Learn to love the drums and only having to change them every 150k.
    Mademan925 and taco06 like this.
  7. Jun 12, 2018 at 11:01 AM
    stevotivo12
    stevotivo12 Well-Known Member
    Stephen
    2016 Silver Tacoma TRD Sport MT
    Front hellwig sway bar,All pro sway bar end links, Fox 2.5 Resi Coilovers and Shocks, Fox 2.5 Hydraulic Bumpstops, Budbuilt Traction bar, Total Chaos UCAs w/ heim joints, Icon AAL, AFE Power Intake with dynamic scoop, URD spec U, URD short shifter, Flossy weighted shift knob, michelin tires, black badges, black tailgate letters, black grill with custom Diaz Fab Devil horn yota logo, retrofit/morimoto HID conversion, red interior LED lights, Pioneer head unit, kenwood excelon door speakers, 2 10" pioneer subs,
    Yes people have done it. I did it on my 2016. Yes, there are also kits available. Its pretty difficult, its a very involved install requiring precise cutting, many different parts to be installed, and then there is the tuning aspect of getting everything to the point where it works as intended once again. You will eventually find that you need a new master cylinder out of a tundra/sequoia/other aftermarket MC in order to get it to work right. I am not trying to discourage you, but your attitude definitely will not help.
    FYI: A large portion of getting a mod like this exactly right is you having a go-getter/DIY attitude. Its hard work, and it does not end with the install of a rear disc brake kit. There will be other things you have to do to get it right beyond that. Not using the search function to find answers that are readily available in several different places on this site and the internet is a discouraging sign.
  8. Jun 12, 2018 at 11:08 AM
    stevotivo12
    Stephen
    That's also false. I can speak from experience in saying that the braking power upgrade is very significant, especially if your truck has added weight or you tow regularly. Not only that, once you get the aftermarket MC in there you get a much more natural feeling brake pedal without the weird jump in braking power around 1/3 to 1/2 pedal travel that you get from the drum/disc stock setup.
    They are more maintenance intensive, but for me I am already taking my wheels off all the time so it doesnt cost me much to swap pads out while I am in there.
  9. Jun 12, 2018 at 11:10 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    don't forget to get them cryo drilled and slotted rotors with new unicorn colors that change with temp so you know how much brake fade you have left before they melt off your axel
    JJ Customs, Maticuno and TacomaMike37 like this.
  10. Jun 12, 2018 at 11:10 AM
    stevotivo12
    Stephen
    I have to play devil's advocate here, being that I have gone through not only the rear disc conversion, but also upgrading the front rotors and calipers and then finally the MC as well :D
  11. Jun 12, 2018 at 12:24 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Total waste of money,but its your truck.
    JJ Customs likes this.
  12. Jun 12, 2018 at 12:30 PM
    parsonsjr
    parsonsjr "OFFICIAL" Moth Man |Free Folk have no King
    Sam
    Athens, Ga
    2014 DCSB TRD off road
  13. Jun 12, 2018 at 12:36 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Definitely do it.
    Your braking distance will improve from an all ready horrendous 158 ft all the way down to almost as horrendous 157 feet.
  14. Jun 12, 2018 at 1:10 PM
    JJ Customs
    Jay
    NV
    Did you quote my same post twice talking trash? LOL... You have the right to your opinion man, I am not hating on you for it but there are pro and cons on both ends. We can get into the whole issue of rear disc brake fade if you like when towing or in heavy braking scenarios. IT IS MY OPINION that it is a waste of money.
  15. Jun 12, 2018 at 1:17 PM
    stevotivo12
    Stephen
    Hey man not even talking trash I am just saying I speak from ample experience with both setups, in the same or similar vehicle.
    I haven't experienced said brake fade just yet but I will definitely be the first to post on here saying 'screw big brake kits and disc conversions' if I do ever experience that. I experienced a shitload of brake fade taking the stock drums on a track, give them about 2-3 laps and I was doubling my stopping distances because of how soft the pedal was getting. All I was trying to do is make sure everybody has the same info from a source with experience running both setups.
  16. Jun 12, 2018 at 1:18 PM
    JJ Customs
    Jay
    NV
    No worries, you do you man.
    stevotivo12[QUOTED] likes this.
