Converting Sliding Rear Window to Power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Engineerlt, Dec 11, 2009.
  1. Dec 11, 2009 at 5:52 PM
    Engineerlt
    Engineerlt [OP] Member
    St. Petersburg, Fl
    PreRunner SR5, LB
    S/S Nerf Bars, S/S Bull Bar, Weather Tech Liners, Undercover Bed Cover, Bed extender, AVS bugflector, DynoLock Tailgate locking solenoid, Linear Actuator operated rear sliding window, rear suspension TSB, Interior light mod
    Hey I have a DBL Cab 2010 Prerunner and that manual rear window was just about useless. So I looked at the available window from CR Lawrence and didn't want to drop that amount of coin, plus when you pull out a glued in window you scratch the heck out of the window frame, so I found another way it only cost me $115.00 dollars. I bought a mini linear actuator with a 12 inch stroke and a momentary on/off/on switch. It just so happens that the slider glass only travels about 12.125 inches. The linear actuator was capable of moving 8lbs and the rate of travel was 1.5in/sec. So it opens and closes at a decent pace. The actuator isn't visible from inside the cab, it tucks behind the upper edge of the rear seat. it works like a champ.... The only issue is the actuator is a little noisy, but I figure I can handle it for about 8 seconds. Has anybody else came up with a way to open and close the rear window?
  2. Dec 11, 2009 at 5:56 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    ^^Pics ?
  3. Dec 11, 2009 at 6:00 PM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Nice first post. Welcome to TW! Pics or it didn't happen. :D
  4. Dec 12, 2009 at 6:13 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Nice!
    Definately....get some pictures and more info. Wish I had more time to do all these neat mods I'd love to have.
    How did you deal with the snapping mechanism? Not sure what you call it, but when the window snaps closed so you can't open it from the outside?
  5. Dec 12, 2009 at 6:32 AM
    MadeInMaine
    MadeInMaine MadeInMaine
    Owen
    Biloxi, MS
    2014 4Runner
    Agreed....
    nice mod.
    what did you do with the snapping mech?
  6. Dec 12, 2009 at 6:45 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Not really needed since the actuator would hold the window closed and would make it difficult to manually slide it open.
  7. Dec 12, 2009 at 7:25 AM
    Death_Stalker
    Death_Stalker " The Master Ninja"
    Talha
    Cypress, TX
    2018 4Runner LE
    TRD Pro Wheels BFG AT Tires
    definately need to see the picture of this ....
  8. Dec 12, 2009 at 7:46 AM
    atmotocrosser
    atmotocrosser Well-Known Member
    Greg
    Conroe, TX
    Interesting idea :cool:
  9. Dec 13, 2009 at 12:48 PM
    Engineerlt
    St. Petersburg, Fl
    PreRunner SR5, LB
    Here is the information for the actuator Mini Style 12" Stroke 8lbs Force Linear Actuators 12v [FA-MS-8-12-12"]$59.00 (on Sale), Mounting Bracket for all Mini Actuators (FA-MS SERIES ACTUATORS ONLY)[MB4] $12.00, Manual "Momentary" Rocker Switch [MAN-RS2] $18.00, Source of supply; www.firgelliauto.com. I had the wire and connectors on hand, I don't think it took more then about $115.00 to purchase everything and get it operational.
    Jbjamn, mojojojo78, Marc70 and 9 others like this.
  10. Dec 13, 2009 at 12:59 PM
    Afwrestler1986
    Johnstown, NY
    Looks nice man, i will have to see about it on a 1st gen.
  11. Dec 15, 2009 at 7:15 AM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    hello & welcome to TW
  12. Dec 15, 2009 at 7:19 AM
    Doc.SS
    Doc.SS ︻╦╤─
    Frank
    O'side
    T4R SR5
    great idea
  13. Dec 15, 2009 at 7:33 AM
    bigyetti
    bigyetti Well-Known Member
    mike
    asheville, nc
    08 taco dc 4x4 short bed
    sirius satilite radio, more on the way when i get more money. oh ya removed the secondary filter
    welcome to tw. awesome idea. i might have give this one a try
  14. Dec 15, 2009 at 7:37 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Very nice work.
  15. Dec 15, 2009 at 1:41 PM
    borderbrat
    borderbrat Watching Chris4x4 o.O
    Jeremy
    Victoria BC, Canada
    2012 DCLB, STOCK..But not for long
    (old truck 2008 AC ....PIAA fogs, led "puddle" lights, bed lights, in cab 115V, Toyota Devil emblem, Randy Ellis light bar with LED light bar, OME 885 and Dakar leaf springs OME shock all round, 2.5 Gal OBA system with air horns, iPod adapter, scangauge on blend mount, magnaflow catback, bike fork mounts, tinted 2009 tails.)
    i've been interested in something like this never looked into it though hmmmm next mod maybe?
  16. Dec 15, 2009 at 1:57 PM
    Fluffymonkey
    Fluffymonkey Token
    College Station, TX
    2013 Trd Sport DC, 07 DC sr5, 03 Prerunner
    2003: Stock 2007: Avid Offroad sliders, 30% front tint, bed mat, Truxedo low-pro qt tonneu cover, aero turbine 2525 muffler w/ 8'' tip, AR25 Resonator, 16x8 Dick Cepek DC-1 w/ 265/75 Goodyear Wrangler Duratracs, 2010 headlights, ome 884 coils with .5'' top plate spacer, OME sport front shocks, bilsten 5100s rear, 2'' aal, locking gas cap, LR ucas, Viper 2-way remote start, afe drop in filter, Rocky locking bike mounts, gear chest, scangauge, pop n lock tailgate lock 2013: most things transferred over from my 07, 5100s @ .85 + eibachs and Toytec tps for 3'' front lift, wheelers progressive aal w/ overload; compustar 2-way remote start; Antennex shorty antenna, pop n lock tailgate lock with programmable key, seat covers, Toyota's crappy all-weather floor mats (should have got Husky's or Weathertechs), TRD skid plate, led light pods mounted in front bumper valence w/ Eyourlife wireless harness and remote, led bed lights, light pods mounted in bed, Devil Horns emblem from Diaz Fabrications, rear facing pod lights in bed, under seat lights,
    Nice idea!
  17. Dec 15, 2009 at 2:06 PM
    trtripoli
    trtripoli lower management
    Denver, CO
    07 4,0 L, 6M, Dbl Cab, TRD Off Road
    Eclipse AVN6620 JL 500/1 amp JL 13TW5 sub JL 300/4 JL XR-650CSi Mr Marv Box Blu tooth XM radio Back Up camera, RAAMmat and Ensolite everywhere but ceiling
    any reason you chose to have the actuator extended when the window is open? seems like it would less obstrusive if it were retracted when the window was open.
    How do you deal with locking the window? I'm pretty sure you can force one of those actuators open when power isn't going to it. if power is going to it, it would kill your battery over night and then opening it would be just as easy.
  18. Dec 15, 2009 at 3:23 PM
    AzPrerunner05
    AzPrerunner05 Desert Rat
    Tucson
    2005 V-6 SR5 PreRunner Debadged
    De Badged, Flowmaster 50 Muffler & Dual Out Exhaust. K & N High Flow Filter. SP Racing Slotted Rotors
    Cool! Welcome to TW, way to get rep on your first post.
  19. Dec 15, 2009 at 3:23 PM
    AzPrerunner05
    Tucson
    oh wait, I broke that rule again...
    JanBoothius likes this.
  20. Dec 15, 2009 at 5:48 PM
    Engineerlt
    St. Petersburg, Fl
    PreRunner SR5, LB
    The actuator only has power going to it when the switch is depressed. The design of the actuator is an acme thread which is not easily forced; it would be easier to break the window. I chose to have the actuator fully closed when the window was closed due to the flexibility of the actuator when it’s fully extended (it is rigid but not as rigid as you might think). This way when I am out bouncing down the road the actuator isn't bouncing into the window. So if the window was open when the actuator is extended the bouncing around won't make any noise as the window is open and there is nothing for it to bounce against. Well that was my thought process; I looked at it both ways. All I can say is it was pretty easy, didn't break the bank and it actually works.
    COTaco16, ClemsonVet and Navy Goat like this.
