Converting Sliding Rear Window to Power
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Engineerlt, Dec 11, 2009.
  1. May 6, 2011 at 9:18 PM
    #101
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I need this mod...:cool:
  2. May 6, 2011 at 11:42 PM
    #102
    rcbs204
    rcbs204 Well-Known Member Vendor
    That high speed one is really cool, i may just buy him for the hell of it!!
  3. May 7, 2011 at 12:58 AM
    #103
    BenWA
    BenWA Well-Known Member
    Boston burbs
    '06 Double Cab TRD Off Road 4X4
    I'm gonna call them on Monday and see if they would be able to do a custom one that has a 4 or 6 inch/sec rate. They mention in that link above that custom options are available -- might as well get exactly what I want! They are in Victoria, BC which is just across the pond from me here in Seattle, so at least they are somewhat local for me.
    I also need to pick up one of your 4x4 illuminators!
  4. May 7, 2011 at 2:02 AM
    #104
    onesixseven
    onesixseven Well-Known Member
    Tyler
    Santa Clarita California
    02 Prerunner SR5
    3.5" Kind Coilovers Total Chaos UCA's 31" BFG A/T's 8000k hi/lo HID kit Flowmaster Super 44 5% tint all around exterior LED's Deck Plate Mod bedlined flares debadged Full Fosgate/JL Audio Stereo
    awesome idea, been looking for a way to do it on my 1st gen, jus never sene it done. u have now changed that... thank you sir...
  5. May 7, 2011 at 4:01 AM
    #105
    TacomaDad
    TacomaDad Member
    Ted
    Oxford, MA
    06 AC SR5 2.7
    oem style fog lights w/fj switch, remote lock chirp w/override switch in glovebox, heated mirrors w/highlander switch, lighted cup holders, center console, front cubby and glovebox, defroster w/o A/C mod, AFE Pro Dry S, removed secondary filter, USA Spec iPod interface, linear actuator driven power sliding rear window w/switch in overhead console, Tundra TRD 17" 5 split-spoke wheels
    I was also thinking of injecting some kind of sound deadening material into the square tubing, like silicone or something. I have a feeling most of the noise is coming from the accoustics inside the tubing amplifying the sound of the churning parts inside.[/QUOTE]
    I did this mod last fall. Absolutely the best mod I've done so far, now I can actually use that sliding window without having my kids with me to slide it for me. The noise from the motor is loud but in theory you would only open it once and close it once during a trip. I've been thinking about using a Dynamat alternative that you can buy fairly cheaply from Home Depot or Lowes, it's a roofing material called peel and stick. It would serve two purposes, one would be sound deadening and the other would be blacking out the motor so you don't have a big silver rectangular motor that is visible through your rear window. I think some guys that have done this mod actually painted the motor black to accomplish this anyway.
    Also, the key to this mod is getting the correct switch. Firgelli has two switched, a momentary and a sustaining. The sustaining switch model MAN-RS is the way to go. This way you don't have to keep your finger on the switch for the entire 10 minutes it takes to open the window and you can stop it at any point you wish so you don't have to open the window entirely. I found a cheaper alternative online but depending on where you can source it from the shipping charges bring the price right up. It's a switch manufactured by Cherry and the model# is WRG34F2BBBNN. It's almost exactly the same size as the switch from Firgelli.
  6. May 7, 2011 at 4:05 AM
    #106
    SPORT
    SPORT Well-Known Member
    Rick
    CA bred, currently living in York, PA
    TRD Off Road 4x4 V6
    3" level lift 1.25" Wheel Spacers
    Quite ingenious!
    I too will have to look into it.
    Thanks
  7. May 7, 2011 at 4:14 AM
    #107
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    X2 this shit really needs to be a stock option
  8. May 7, 2011 at 2:19 PM
    #108
    Engineerlt
    Engineerlt [OP] Member
    St. Petersburg, Fl
    PreRunner SR5, LB
    S/S Nerf Bars, S/S Bull Bar, Weather Tech Liners, Undercover Bed Cover, Bed extender, AVS bugflector, DynoLock Tailgate locking solenoid, Linear Actuator operated rear sliding window, rear suspension TSB, Interior light mod
    I like the idea of wrapping the actuator with a sound deadening material, I think it would definitely cut down the noise some. I am very interested to see if they could have a custom actuator made. I am glad you all are having a goodtime with the idea and improving upon it. Please keep posting your improvements it is giving me more ideas and somebody should put a kit together and offer it, might make a couple of bucks plus it would make it easier for everyone who wanted to do the mod. Thanks!
  9. May 7, 2011 at 2:37 PM
    #109
    rcbs204
    Cool, Sales of my item have been pretty slow, must be the summer. Everybody is out and about, and the daylight hours enable everybody to see the switch!!
  10. May 7, 2011 at 4:01 PM
    #110
    JHAirForce05
    JHAirForce05 I'm kinda a big deal
    Justin
    Tacoma, WA
    09 DC LB SP
    Kenwood DDX712 with Nav and rear view cam, Viper 5901 Security System, Kobalt Slim Line Compact Truck Tool Box
    Awesome mod! I will def be doing this when i get back home.
  11. May 17, 2011 at 5:39 PM
    #111
    jackrules
    jackrules Well-Known Member
    Jack
    San Diego
    10 PreRunner Double Cab SR5 TRD Sport LB
    just ordered up my parts!!!! Can't wait to do this!
  12. May 17, 2011 at 8:48 PM
    #112
    BenWA
    Boston burbs
    Which actuator did you end up ordering?
  13. Jul 15, 2011 at 11:38 AM
    #113
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    i will be hopefully ordering one next week...should be a nice mod to do :D great idea OP!! :thumbsup:
  14. Jul 15, 2011 at 11:56 AM
    #114
    BenWA
    Boston burbs
    FYI, I inquired about getting a custom made high-speed actuator from Firgelli and unfortunately at 2-1/8" diameter they are too fat to fit behind the seatback. Shame, because they are advertised to run quieter and smoother than the mini actuators.
    That's why I ended up doing my version of the power window mod with the Ridgeline regulator.
  15. Jul 15, 2011 at 12:03 PM
    #115
    Jerez
    Rod
    Ontario Ranch
    Estock
    hmmm...just saw ur thread, seems to be more hidden n flush to the truck. :cool::cool: decisions decisions lol
  16. Jul 19, 2011 at 5:23 PM
    #116
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    WANT! GREAT WORK :eek:
  17. Sep 27, 2011 at 6:09 AM
    #117
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Update,,, my Firgelli LA just bit the dust. It was sounding funny the last couple times I used it, then it made this nasty metalic grinding noise and has now quit working. I haven't taken the LA apart yet to see what happened, but suspect the screw doing the actual actuating has stripped out.
    Not sure if I am going to replace with another one or not. I would like to do BenWA's version instead, but I have a sub box/amp board right in the middle of the back wall.
    Just wanted to let everyone know that the LA may not be a long-term solution,,, or I have an outlier, since I haven't heard anyone else's going tits-up.
    BTW, LA didn't last quite a year, did it Nov, 2010 (post #79).
  18. Jan 2, 2012 at 11:33 AM
    #118
    dbbd1
    dbbd1 Well-Known Member
    Wow! Just came across this thread. Thanks for the mod idea, definitely on my list now to-do. Just ordered the stuff.
  19. Jan 2, 2012 at 11:42 AM
    #119
    GregLee98
    GregLee98 Well-Known Member
    Greg
    08 Tacoma TRD Sport
    TRD Cold Air Intake TRD Cat-back Exhaust URD MAF Calibrator 3 inch Top Gunz Customz Lift Spidertrax 1.25" Wheel Spacers Goodyear Wrangler MT/R w/Kevlar (275/75R/17) Tires Power Tailgate Lock linked to power door locks Back-up Sensors Bakflip F1 DIY Auto-dim Rearview Mirror Power Sliding Rear Window Mod by BenWA 4x4 Switch Light Mod 400W Inverter Anytime Mod 110V In Cab Mod with 25' Extension Cord Rear Differential Breather Relocation Mod Chirp on Lock Mod A/C Off with Defrost Mod Brighter Reverse Lights Mod Tailgate Theft Deterrence (Clamp) TRD Seat Covers Extra D-Rings in front of bed
    DBBD1,
    I got together with BenWA and did his mod. I love it. He used a Honda Ridgeline power window motor.
    Search his thread too before choosing.
  20. Oct 24, 2013 at 6:13 PM
    #120
    Hbr01
    Hbr01 Well-Known Member
    Brian
    Jax, FL
    12 DBC 4x4
    Tag just ordered my parts been wondering how to do this since I bought my truck!
