converting Sport Model to A-TRAC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by viperstd, Dec 7, 2010.
  1. Dec 7, 2010 at 11:38 AM
    viperstd
    viperstd [OP] Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    I haven't been able to find this info in the old threads. If I wanted to add A-TRAC to my sport truck, what parts (and part numbers) would I need?
    I know it will require a hydraulic brake booster instead of the vacuum booster I have. (part number?)
    Is there an offroad specific computer/VSC computer/etc?
    Different instrument cluster?
    Wiring changes?
    ABS sensors/computer?
    I am considering this a feasibility study. I would love having A-TRAC available. I will be adding F/R lockers and gears at some point, but If I can make minor mechanical changes for a under a thousand dollars, I am getting a huge capability increase for a small fraction of the cost.
    Cheers.
  2. Dec 7, 2010 at 2:53 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    I really don't know about the fesability, but a sport tacoma, with the cool look, A-TRAC equiped, would be NEAT!
  3. Dec 7, 2010 at 2:55 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    x2
  4. Dec 7, 2010 at 2:57 PM
    NWtacoma
    NWtacoma Well-Known Member
    Kent,WA
    2011 TRD Sport 4x4
    265/70/17 bfg AT
    just buy a trd offroad and get a new hood bumber and door handles.
  5. Dec 7, 2010 at 3:09 PM
    viperstd
    Maryland
    seriously guys... thanks for the useless replies x3. If I wanted an OR model, I would have bought one... I intended from the get go to install new gears and lockers F/R... so why pay for an OR model? ALSO, IT was MANDATORY that I get the bigger bed.
    We aren't talking about a 4x4 conversion... it is a brake booster and maybe a few sensors. I should be able to get all of the parts from a wrecked truck... if I knew what other parts I needed.
    I know the gurus out there with their wiring diagrams and service manuals can do a side by side comparison and come up with a part list... please!
    Voodoo mexican taco likes this.
  6. Dec 7, 2010 at 3:12 PM
    huckyourmeat
    huckyourmeat Well-Known Member
    Denver, CO
    19 TRD OR DC Silver
    Redline QL Plus hood struts, seatbelt chime off, cupholder mod, LED interior and license plate lights, Fumoto oil drain valve, Leer 100XR Mile High Edition, Kicker/tweeters, Kicker Key, Anytime + front camera, ECT anytime, 6112s (10/8), 5160s, Icon RXT (Stage 2, may drop to 1), Qi delete/dash pocket mod, TRD skid plate, alloy filter housing.
    sorry I don't have much to offer in the way of actual answers, but you might post this over in the tech forum as well. Some of those guys have the in-depth knowledge to answer your question.
    good luck!
  7. Dec 8, 2010 at 9:01 AM
    viperstd
    Maryland
    -daytime bump-
  8. Dec 8, 2010 at 9:36 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Just get lockers, you can not do this conversion under the $1K
    You need to replace whole ECM plus skidd computer and reprogram which alone is way over $1K
    Brake booster is another $600 - $1000 so you will be way above of price of two lockers. I think ABS sensors are the same since you have 09 which has VSC.
  9. Dec 8, 2010 at 9:57 AM
    viperstd
    Maryland
    1. To reiterate, please treat this as intended in my 1st post "I am considering this a feasibility study". This is a mental exercise.
    2. What is this warrenty you speak of? My truck is so far from stock that I will be very hard pressed to get anything covered. These lockers you speak of... are they covered under warrenty? the new gears? when I grenade something in my IFS will that be covered? The point is completely moot.
    3. I can worry about the cost and do my own cost/performance calculations.
    4. As I already stated, I will eventually be going to lockers Front and Rear.
    5. A-TRAC is a superior means to go somewhere >75% of the time. While lockers have a great place in offroading, they are not the be-all, end-all, mythical panacea people make them out to be.
    6. Let us please try to avoid the A-TRAC vs TRAC vs Auto-LSD vs Locker debate...
    So far on the list we have 'ECM, ''skidd'' computer', and brake booster.
    BlueT, when you said skidd computer, are you refering to a VSC module behind the dash? Do you have part numbers for an 09 Sport vs 09 OR?
    Can anyone confirm if the ECM has a different part number? Will new keys need to be coded for the ECM?
    Thank you for input so far guys. Keep it coming. :cheers:
    DistortedAxis likes this.
  10. Dec 8, 2010 at 10:29 AM
    BlueT
    NorthEast
    Dont have part numbers (behind the dash on pass side that would be 4wd ECU, I think skid is in the engine bay) , and yes everything needs to be reprogrammed. Also not sure if you can just buy junk computer and swapped in your truck. I think 09+ would need blank one.
    Plus do you know if you have all the wiring ?
    If you need to get new harness that would be costly and hard to replace.
    Honestly if you are so keen on getting A-Trac (not sure why :) ) easiest way would be to get Offroad truck and just swap hood and color coded items from the body
    Oh and I completely dont agree with your #5.
  11. Dec 8, 2010 at 10:30 AM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Actually the electric factory rear locker alone is worth the price difference of the OR TRD model.
    And I wasn't aware that the OR had a smaller bed then the Sport - that's news to me.
    Also, your question has been posted before (in the correct and appropriate technical chat area).. here
    Anyway I get your line of thinking.. ATRAC is wicked cool and I wish my 07 had it, and I have too much invested in mine to just trade it off for a model with ATRAC.. of course I think the best option is to get the lockers, or limited slips.. the front locker really binds up the steering/turning and a limited slip up front seems more practical to me. The rear locker is fantastic! I love mine, I did the mod so it can be engaged anytime I want. Really fun.
    Best wishes in your quest for answers..
  12. Dec 8, 2010 at 10:32 AM
    viperstd
    Maryland
    Agreed. I think that a new wiring harness would render this infeasible. However, wiring harnesses are usually very common across all models to save money... however on my first however, I have the biggest version of our trucks-being the 4dr, longer bed... which might mean it has a different harness.
  13. Dec 8, 2010 at 10:40 AM
    ser240z
    ser240z Well-Known Member
    Scott
    Monterey Park, CA
    '23 TRD Pro 6spd
    I have an '09, I thought the deciding factor for the long bed was the transmission not the model? I'm almost sure that I could've gotten the O/R with a longer bed if I got an automatic. Sorry off topic.
    As far as A-Trac goes, doesn't it only work when 4lo is engaged?
    Scott
  14. Dec 8, 2010 at 10:41 AM
    viperstd
    Maryland
    Good link. Thank you. The 4 door "Long" bed is not available in Off Road trim :(. If it had been, I would be driving that instead.
  15. Dec 8, 2010 at 10:42 AM
    BlueT
    NorthEast
    I have 07 DC LB and I know mine is not pre-wired. I was looking at the way to throw TPMS out so checked the harness and it does not have half of the cables required. But yours is 09 so who knows they may have put in but with Toyota being cheap on other stuff and copper wire being expensive I would think they would rather spend few dollars on labor in China then install $200 of extra copper that will never be used :D
  16. Dec 8, 2010 at 10:43 AM
    BlueT
    NorthEast
    Bed extender :D :notsure:
  17. Dec 8, 2010 at 11:09 AM
    jandrews
    '09 FourDubDee TRD OR
    Careful now...I came away pretty impressed with it. It walked that bowl on Dickey Bell without even thinking. I look forward to testing it more in the future and further forming my position on it.
    That said, everyone saying get lockers is ABSOLUTELY CORRECT. Lockers will be much less expensive than an A-TRAC conversion (in both dollars and time), allow you to regear at the same time, and put a compressor on board for OBA.
    A-TRAC is a great feature to consider if you're in the market for a new Tacoma already. If you're not, don't bother and look at locker options.
  18. Dec 8, 2010 at 11:11 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    That is correct...
    In H4 you have TRAC and that is awesome in high range... A-TRAC is the Low Range traction control and it does brake harder any loose tire for ĂĽber traction control, like lockers provide.
    To the OP: If you are going for front and rear lockers, then make sure they are selectable so you can turn them off for steering. The A-TRAC automatically locks/ unlocks loose tires so steering isn't affected, but because of that it makes quite a bit of noise when operating (only when there is slippage, not all the time it is activated).
    As much of a fan of A-TRAC that I am, I see no reason (at all) for doing this if it were possible. The after-market lockers you say you are going to get, will get you everywhere.
    You could have saved a fortune buying an Off Road as it has the rear locker and A-TRAC. But, if you had to have the longer bed and didn't want the bed extender, I see why the Sport... But surely not for the fake hood scoop and colored bumpers?
    If you succeed in installing the A-TRAC, then there is no need for the after-market lockers. A-TRAC provides the traction of lockers, but it makes noise... and isn't "smooth", which seems to bother some here who have front lockers.
    I kind of think changing your differentials will be easier than adding A-TRAC to a Sport... But, I would be curious to follow you on this. Maybe search to find if anyone in Japan or anywhere has done it already?
    Good luck!
  19. Dec 8, 2010 at 11:16 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    A-TRAC is great for when you can be on the gas (mud, sand, hills, loose rock. etc.), but it does nothing at crawl speeds (on the rocks).
    Conversion is not practical - I thought it through as well. For the money, you can put air lockers in and be better off.
  20. Dec 8, 2010 at 11:18 AM
    viperstd
    Maryland
    If you have the ability/knowledge, please start writing. BTW, this is nothing like asking for a list of parts for a v-8 pulled froma '69 chevy swap... it is more akin to asking, "hey the 09 in xyz trim came with heated, turn signal, curtesy light mirrors and my truck doesn't have them. What parts are required to add them in myself?".
    Based on the info here: http://www.tacomaworld.com/forum/at...76793371-ability-add-atrac-2008-2009brake.pdf
    It appears to be a Combination meter (if you want the lights), A-Trac switch (or any switch for that matter), Skid Control ECU, Hydraulic Brake Booster Module, rear-diff switch (any switch to simulate a rear diff), potential wiring harness modifications, and maybe an ECU.
    Do the O.R. models have have 100% hard lines?
