converting Sport Model to A-TRAC
Discussion in '2nd Gen. Tacomas (2005-2015)' started by viperstd, Dec 7, 2010.
  1. Dec 8, 2010 at 11:39 AM
    viperstd
    viperstd [OP] Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    Thanks for the great reply.
    The lockers will be ARBS with ECGS doing the install with 4.56s. There was never a question about that. I wouldn't dare put a non-selectable locker in a daily driver let alone an IFS!
    The Sport was because I considered 4 doors mandatory as well as the bigger bed. My truck is used as a truck AND a people carry. I had another truck with a longer bed and 2 seats that the Tacoma replaced. I regularly use the bed to haul and couldn't imagine it being any smaller than it already is!
    As far as bumpers go... I have a Line-X'd front and rear All-pro.
    This was me ...pretty stuck. Yay for winches and trees.
    I'm an engineer by education and trade, so this post was a fact gathering missions so that I might make a determination if it was possible. Obviously, with enough money and determination, you can do anything...
    :cheers:
    DistortedAxis likes this.
  2. Dec 8, 2010 at 11:43 AM
    jandrews
    '09 FourDubDee TRD OR
    Absolutely incorrect. I spent almost all of last Saturday with it on, and it ONLY needed to kick in in crawl sections where one wheel was losing traction, either from being off the ground or breaking loose...this was mostly over mud-slicked rocks in 4Lo 1st or 2nd gear.
    Absolutely correct.
  3. Dec 8, 2010 at 12:15 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Wow.... Thanks for making it clear why I must not give up my crusade to educate Tacoma owners (who don't have A-TRAC or don't understand their A-TRAC) on how it works.
    Seriously, we drive Toyotas because of how good they build trucks, right? Would Toyota put A-TRAC in the Tacoma unless it could perform?
    Well, the A-TRAC works at any speed you would want to drive in LOW RANGE... which is usually under 25 mph, because the low range is for crawaing over/ through, up or down difficult terrain... Get it:? CRAWLING...
    Who is on the gas in low range... except when climbing steep hills?! There's a video of me taking a run up a steep, dusty hill... and when my upward momentum came to a crawl... THAT, is when the A-TRAC took over and began transfering torque to the tires with traction... biting and biting with all fours until it pulled my truck to the top.
    In Baja, the Widowmaker grade near Mision Santa Maria is a rocky CRAWL grade... and A-TRAC performed flawlessly... Previous trips with my other Tacomas, I used the rear locker to climb the Widowmaker and other grades on that road.
    A-TRAC, it isn't just for breakfast anymore! :D
  4. Dec 8, 2010 at 12:16 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    It requires wheel slippage to activate.
    On the rocks (real rocks - boulders), spinning wheels is a great way to break things.
  5. Dec 8, 2010 at 12:21 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Thanks a lot mxpatriot :rolleyes: now you have done it...
    :D
    There goes the thread...
  6. Dec 8, 2010 at 12:28 PM
    Mxpatriot
    To get the brake to lock the wheel up and transfer power, it needs to detect slippage. When you're in a giant pile of boulders, wheel slippage causes the vehicle to bounce and abruptly crown boulders and slam the vehicle down on them. I'm talking big rocks here, rock crawling.
  7. Dec 8, 2010 at 12:34 PM
    David K
    That is the point... A-TRAC doesn't allow slippage, it matches wheel rotation across the axle so the loose tire rotates the same speed as the traction tire... as if it were a locker.
  8. Dec 8, 2010 at 12:40 PM
    Mxpatriot
    No it doesn't. It quickly pulses the brakes to stop one wheel from spinning, which transfers the power to the other wheel, which gives the vehicle more traction. That's not the same as forcing both wheels to turn with each other at the same speed and same time (mechanical locker).
    If you can explain to me how applying the brakes to one wheel makes both wheels rotate at the same speed, at the same time, under power, I'll send you a "Master of Defying Physics/Open Differentials" trophy.
    The brake pulsing action is enough to overcome most obstacles - but it does not compare to a mechanical locker for rock crawling applications. That's all I've ever said. 99% of guys on this forum, let alone general tacoma owners, will rock crawl their Tacoma so it's not even that big of an issue!
  9. Dec 8, 2010 at 12:48 PM
    jonny
    jonny Betty White Edition Heep ZJ
    disagree
    agree
  10. Dec 8, 2010 at 1:21 PM
    LouTaco
    LouTaco Well-Known Member
    Lou
    Des Moines, Iowa
    2018 T4R SR5 Premium
  11. Dec 8, 2010 at 2:27 PM
    jandrews
    No, it requires a difference in wheel speed rotation in the same differential. Difference.
    Which is why it stops that from happening.
    No, it doesn't pulse. It clamps. It uses the brakes to stop the wheel. I don't know that it will perform exactly like a locker in all situations, but it's pretty damn close on a slick muddy/rocky trail. I was skeptical of A-TRAC til' I used it.
    Have a comparison of two videos. The first is Namyo running the bowl on Dickie Bell with his rear diff locked (skip to 8:15 - Indigo Ink truck with topper):
    http://www.youtube.com/watch?v=_RzyYXS40yY&feature=player_detailpage#t=495s
    The second is me running the EXACT SAME BOWL about 2 minutes later with A-TRAC only, no locker. The sound you hear is A-TRAC kicking in:
    http://www.youtube.com/watch?v=Z_1Ii0WmA9s&feature=player_embedded
    Good call. But Hey...I like a good ol' shitstorm [​IMG]
  12. Dec 8, 2010 at 2:40 PM
    jandrews
    This debate needs to get AWAY FROM LOCKERS VS A-TRAC ANYWAY. It's a shitty comparison.
    Lockers are one approach to a problem. A-TRAC is a different approach to the same problem. They are BOTH very effective but need to be thought of in different terms.
    My recommendation: Lockers are lockers. A-TRAC is the *best* traction control system currently on the market. BOTH should be had if possible.
    I can think of situations where I would want one and not the other. I actually turned it off several times, most notably for a descent of a muddy, very steep hill that we essentially slid down one after the other.
  13. Dec 8, 2010 at 2:51 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    So I guess that when the rear locker is engaged, the 3MPH maximum speed for A-TRAC to be active is useless then?
    Try the thing before bashing it.
  14. Dec 8, 2010 at 2:57 PM
    jandrews
    In an attempt to get back to the OP's question...
    Just want to x2 this....we did all come to the same conclusion that if your truck doesn't already have A-TRAC, converting makes no sense. It's going to be expensive, time consuming, and will NOT offer enough advantages over lockers (such as steering control) to make it worth that extra price. Especially considering lockers are better in many ways and much less expensive.
    Lockers make far more sense if you're already working with an open diff or LSD truck.
    Converting for A-TRAC is a lot like converting to 4x4...it just plain makes more sense to trade your current vehicle in for one with the capability you're looking for.
  15. Dec 8, 2010 at 3:01 PM
    #35
    supralight
    Dan
    Earth
    AFAIK A-TRAC will become innactive, when the rear locker is engaged, when vehicle speed goes over 3 (maybe 5) MPH.
  16. Dec 8, 2010 at 3:08 PM
    #36
    Mxpatriot
    And that's a great application of A-TRAC. I've never said that A-TRAC doesn't have its place.
    But that's not rock crawling, so it doesn't address the point that I've made.
  17. Dec 8, 2010 at 3:09 PM
    #37
    Mxpatriot
    There is not a 3 MPH maximum for A-TRAC. See the videos of David_K climbing hills at a decent speed with it engaged.
  18. Dec 8, 2010 at 3:16 PM
    #38
    jandrews
    It addresses some points - you can clearly see the wheel stopped and matched to the opposite side by the brakes, you can clearly see the truck is crawling (I actually came to a complete stop in the bowl) - you can clearly see that it was smoother than the locker in this instance (there are variables...different suspension, different tires...I am not suggesting it's smoother than a locker every time).
    I have no reason to believe A-TRAC would make you ANY more likely to break something during rock crawling than any other device. It's actually going to be less stressful on the truck overall because the diff doesn't undergo the stresses a locked differential sees. At the same time it's being less stressful, it may not get you to the same places. I have yet to take this truck down a dedicated rock yard like Rausch or build a rock sluice in my back yard. Stay tuned for further developments.
    Anyway, can we all get back to the original topic and agree that converting to A-TRAC is not a good idea?
  19. Dec 8, 2010 at 3:24 PM
    #39
    jandrews
    + repped.
  20. Dec 8, 2010 at 3:28 PM
    #40
    Mxpatriot
    Again, I'm not talking about trails like the one you posted the video of. That's rough terrain and the A-TRAC can do very well there, but it's entirely different world than rock crawling.
    Just ask yourself why the guys who wheel hard on this site and have newer trucks still purchase air lockers, even though they have A-TRAC...
    I'm talking about situations like this:
    sub-0.5 MPH, large rocks, require the tires to climb the rocks. Wheel slippage, even minute amounts (like those required to activate A-TRAC), sucks in situations like this. Trust me, I abuse the hell out of my truck getting through stuff like that on the LSD.
