Convince me not to use cheap conventional gear oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by smokn, Mar 3, 2015.
  1. Mar 12, 2015 at 4:23 PM
    #41
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    Why don't you get all new fill and drain plugs, with crush washers and be on the safe side...
    Howard
  2. Mar 12, 2015 at 4:52 PM
    #42
    smokn
    smokn [OP] Unsenior Member
    08 DCSB TRD SPORT SR5 4x4
    I am getting all new crush washers. No need for new drain/fill plugs unless I run into problems, though.
  3. Mar 13, 2015 at 11:30 AM
    #43
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I got mine when they had a sale. Valvoline is $10/qt and Mobile1 is $11/qt currently (no sale) at the major brand stores.
  4. Mar 13, 2015 at 11:53 AM
    #44
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    I use Mobil 1 only. I have taken engines apart that had conventional motor oil all their life. You chisel the carbon off the oil valley.
  5. Mar 14, 2015 at 7:32 PM
    #45
    smokn
    It wouldn't surprise me. For comparison, have you ever taken a Mobile1 engine apart?
    On an unrelated note, I changed everything today...after a couple trips to the stealership because they gave me the wrong washers...which I noticed after I had drained my tranny and T-case...
    Anyway, I also greased all my slips and U-joints. It certainly shifts smooth and there aren't any noises coming from the drivetrain, but I can't say that it's a definitive improvement over my pre-fluid change driving experience. I'd say the gears are "marginally" less notchy to get into. But then again, I didn't use the miracle MT-90 either. So, I guess I'd probably use synthetic again if I can get it cheap, but I wouldn't go out of my way for it.
