Convince me to get a Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joepa150, Apr 2, 2012.
  1. Apr 2, 2012 at 10:59 AM
    joepa150
    joepa150 [OP] Member
    I have always loved the look and size of the Tacoma. Also I love Toyota. IMO fit, finish, and reliability are awesome.
    This fall I am getting a new vehicle. If gas prices continue to climb (which they probably will), I may not get a truck. I hope this doesn't happen because my last two vehicles have been sedans.
    My choices are these two trucks. Tacoma double cab 4x4 V6 short bed or F-150 Super crew 4x4 with 5.5' bed and Ecoboost engine.
    Tacoma Pros:
    Cheaper
    Toyota Quality
    Tacoma Cons:
    2nd gen has been around for awhile and a 3rd gen probably will come out within a couple of years which will make my new Taco seem and look old.
    Gas Mileage doesn't seem great for the size of truck
    May not be able to get as much off MSRP as Ford (not sure though)
    Ford F-150 Pros
    Cabin seems more luxurious than Taco
    More room inside than Taco
    Towing and payload probably higher than Taco
    Gas Mileage may be as good or better than Taco
    Seems like I should be able to get around 25% off MSRP
    F-150 Cons:
    Price
    Price
    Size
    Some report MPG with Ecoboost not consistent/low
    This F-150 setup I see most averaging 17-20 MPG mixed, with a few below 17mpg and a few above 20 MPG.
    Put is this way, if money was not an issue I would get the F-150. Since money is an issue, I was thinking of getting the Taco since it is cheaper.
    So should I get the Taco?
    How would MPG compare to the F0150 above?
    Does Toyota usually knock off 20-25% off MSRP?
    Thank you everyone for your help and hopefully this fall i will be a proud Taco owner.
  2. Apr 2, 2012 at 11:04 AM
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    Why? No one should have to Convince you. You should buy the TACOMA based on your research and final choice.
    I researched myself for months and understood my needs and wants. Finance and made that final decision. Truck or sports car.
    Good Luck on your purchase.
    Toyota will NOT knock off much from the MSRP. Top selling mid size truck that holds value. You have to haggle and search. I got mine for 4K off MSRP sticker price. Thats after I searched for months and haggled.
    Your New FORD F-150 is showing 23 MPG and thats IMPRESSIVE. However resale will TANK over the years. . .
    Plus, TACOMAS have a bunch of awesome people. Hence TW!
  3. Apr 2, 2012 at 11:05 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Get a 4 cylinder if you want decent MPG.
  4. Apr 2, 2012 at 11:06 AM
    medic2230
    Murph
    Bama! Roll Tide
    If you want to be awesome get the Tacoma.
  5. Apr 2, 2012 at 11:07 AM
    RAD
    Rad
    LAX & LOGAN
    ^ there is no fun in the 4 banger. The f-150 is impressive with the power and mpg it gets. . .
    However imho, I'd never buy a F-150. . .
  6. Apr 2, 2012 at 11:08 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    i didn't read his OP, but yeah, that ^^^^
  7. Apr 2, 2012 at 11:10 AM
    TacoRun
    TacoRun Subd for later..
    Luis
    Edinburg,Texas
    TRD off road, Magnetic Gray
    Pop Lock, Ranch Hand brush guard
    What are you going to be using this new truck for?
  8. Apr 2, 2012 at 11:17 AM
    YellowDog01
    YellowDog01 Well-Known Member
    04 4x4
    What do you tow? Or haul? That would be my deciding choice.
    And you're right, the gas mileage on the F150 is actually good. My dad had one for a work truck and with the smaller V8 it got 18-19 mpg on the highway...And sometimes that's towing a trailer.
    The tacoma is great for around town...Think about parking spots....The F150 was a pig to park.
    I hated the way that you couldn't see behind you in the F150 because the rear end was so high up in the air compared to the front. Backing a trailer was sometimes a pain.
    I'd have to say that the seats in the F150 are much more comfortable than my 1st Generation Tacoma. They support very well and I never got sore.
    After about 75-80k miles, the F150 got this driveline problem that was never fixed because we turned it in at 90k. My tacoma has never had problems like that.
    Those are some points that I see are important to me. If you're towing heavy trailers for extended periods of time: F150. If you're around town a lot, don't tow every day, and just need a good all around, versatile truck: Tacoma.
  9. Apr 2, 2012 at 11:37 AM
    bubbagumps
    bubbagumps Well-Known Member
    You didn't really mention what you will be using the truck for. If cosmetics and/or appeal is the main crtieria here, you can only answer this question for yourself.
    There are also other options. If you are considering either a fullsize or midsize, why limit yourself to these two? The Tacoma is obviously a great truck and you are going to obviously find we are biased here towards the model. But I would expand your selection a bit and do some test driving.
    If you want fullsize, you can also find much better deals--Tundra or Ram, for instance. In the end, its your truck and you are going to own it. Whatever you buy its not going to be cheap. You owe it to yourself to do some window shopping and test drives behind the wheel. Taking the suggestions of others will only take you so far when you are about to plop down $30K+ for a new ride. Take advice and suggestions but at least drive one before going down to a dealer and writing a check on the advice of others.
  10. Apr 2, 2012 at 11:42 AM
    dbn23
    dbn23 Active Member
    I just went through the same scenario. I chose the Tacoma because I don't tow much, and from what I've been reading the ecoboost haven't been getting the advertised mileage. There are also a lot of people complaining about misfires and hesitation with the Eco. Plus the Toyota holds its resale value better.
  11. Apr 2, 2012 at 11:46 AM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Resale value
  12. Apr 2, 2012 at 11:48 AM
    12Tac
    12Tac Well-Known Member
    Colorado
    2020 Double Cab, Long-bed TRD Off Road.
    SnugTop, FN Wheels, Meso Custom, Tacos4Cheap
    For what its worth I had a Ridgeline for about 5 years. Loved the truck and considered getting another one (long story why I got rid of it in the first place...wasn't problem related). I looked into the Tacoma at the time I was considering the Ridge...Toyota has come a long way in their fit and finish and reliability. Although I still hear engine seal problems. Nonetheless I just picked up an '12 double cab TRD and love it. So far its a much better truck that my Ridgeline.
  13. Apr 2, 2012 at 11:49 AM
    HammerHead
    HammerHead Well-Known Member
    Jake
    Georgia
    04 TRD OffRoad PreRunner SR5 DC
    ^^^This.
    Do your research and drive both options. Ford's are good truck for the first 100k, then they die. Muahahahahaha:D
  14. Apr 2, 2012 at 11:58 AM
    jtav2002
    jtav2002 Kenny Fuckin Powers
    Josh
    Reading, PA
    2013 Tundra DBL Cab TRD OR
    Buy whichever you like best and fits your needs best. Id probably get an F150 if i was getting a new truck. They do get pricey quick though. Youll typically be able to get much more in the way of incentives on full size trucks, especially the F150 and Silverado. Could end up making the prices similiar.
  15. Apr 2, 2012 at 11:59 AM
    joepa150
    I know someone with a new 4 door Silverado 1500 and he says it gets horrible gas mileage and I just wouldn't buy a Dodge for several reasons. I am going to test other vehicles Cars, SUVS, and Trucks before making a decision. I am 6 months away from making a decision so I guess I am starting early.
    I will be using my truck probably as follows. 90% as a daily driver. I will occasionally use it for carrying large things appliances, couches, mulch, pine straw, etc. I go off the beaten path maybe once a month to go target shooting and I drive long distances in snow a few times a year so I want 4x4.
    I really like that color.
    I don't know if Tacomas don't get discounted much but a I bought my wife a new 4runner a few years ago and I got it for $23k and the MSRP was 33k so that is about 10k off MSRP. Maybe 4runners are more negotiable. I don't know.
    What are people averaging on the 4 cylinder?
  16. Apr 2, 2012 at 12:12 PM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I don't know what others are getting, but my 4x4 AC with a 3" lift gets around 20 mpg hwy in the winter and 24 mpg hwy in the summer on stock 245/75/16 Dungflops (I only put on the 33"s when I go off road because I have a 280 mile/week commute). Mostly on cruise control set at 70 or 75 mph.
  17. Apr 2, 2012 at 12:34 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    you can do this:
  18. Apr 2, 2012 at 12:35 PM
    ToyotaKTMracing
    ToyotaKTMracing The Blue Warrior
    Shay
    West Virginia
    2008 DCSB Ink 4WD Auto
    285 BFG ATs, Custom dual exhaust system, 4" total lift (adjustable billies with 885 coils in front and AALs with 1" block in rear), interior LED lighting, LED reverse lights, LED license plate lights, fog light anytime mod, JVC KW-R500 stereo, 20" okledlightbars.com LED light bar, coverking seat covers
    This^ The fords with Eco boosts have problems. Get a Tacoma. Reliable and everything. If you want good mpg, get a 4 cyl 5 spd manual Tacoma. Or go all the way with a V6 :D V6 tacomas can get good mpg too. Depends how you drive.
  19. Apr 2, 2012 at 12:42 PM
    FLtaco
    FLtaco Well-Known Member
    Nick
    Cocoa beach, fl
    05 prerunner dc
    Painted stock wheels, bfg km2s, 5100s front and rear, tc spindles, add a leaf, 3" block, debaged, flowmaster exhaust, 2nd air filter removed, wheel spacers and k&n air filter
    I have 170,xxx miles and it still starts every morning. Plenty enough reason
  20. Apr 2, 2012 at 12:47 PM
    g35man
    g35man Discount Double Check
    League City, TX
    2012 MGM DC 4x4 OR
    Icon Stage II lift kit, LR uca's, Weather Tech floor mats, FX-R retrofit, Morimoto factory fit LED fogs, flyzeye designs cup holder lights, wet okole seat covers, upgraded Entune system
    Resale end of story.
