Cooking Hogs
Discussion in 'Food Talk' started by Brunes, Jul 9, 2011.
  1. Jul 9, 2011 at 8:24 AM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    So my wife is planning a party for her recent promotion (a wetting down for those who know what that is) and she wants to roast/grill/whatever a hog.
    So-Learn me about hog cooking. How much piggy do we need to buy (somewhere between 50-60 people)?? Recipes for spices/marinades?? Pits or other cooking styles?
    I'm open to any suggestions-so throw them out there!!
  2. Jul 9, 2011 at 3:33 PM
    toughtaco
    toughtaco Well-Known Member
    05 tacoma dbl cab short bed
    TRD CAI, MBRP dual exhaust, PIAA headlights and driving lights, 5% limo tint, 3 inch Skyjacker lift , AFE throttle body spacer, 285/70/17 BF Goodright AT TA KO, Grillcraft MX with PIAA's behind the grill, anytime fog light mod, reverse camera anytime mod, and PIAA fog lights on the rear bumper anytime mod light bar behind back window with truck lights for reverse assistance, Optima Red Top Battery, Onza 3x5" LEd reverse lights attached to light bar behind cab
    When you purchase the hog they will advise how big a pic you need. For a whole pig its usually 1 pound per person. It seems like a lot compared to the 8 oz per person but there is alot of waste on a whole pig.
  3. Jul 9, 2011 at 3:51 PM
    facemob
    facemob Well-Known Member
    Chase
    1st state
    03 V6 Manual, TRD
    OME 881, Nitrochargers front and rear, diff drop, Wheelers 3 Leaf AAL, Supertop, shitty brush guard and a hole in the muffler
    Toughtaco got it. roughly 1 lb per person. a 50-65 lb pig ( that is gutted and head on typically) will not yeild 50-65 lbs meat after cooking. i'm not positive how much it will yield but should be sufficient considering that is not the only food there.
    I cooked one last summer and am doing it again 2 weeks from now. used a big slow roaster, like a 55 gal cut in half with a rack in it..... worked great if you can get ahold of it.
    as far as a good recipe, heres mine.
    brine the whole hog in a large cooler the day before (65 lb hog is about 3 1/2 -4 ft long)
    5 gal apple juice
    5 gal water
    5 gal apple cider vinegar
    chopped onions
    crushed garlic
    black pepper
    cloves
    kosher salt
    mix it up well and put the pig in. rotate the pig in a few hours and let sit overnight (refrigerated or throw enough ice in the cooler to keep cold and safe)
    made a wet rub also as well as a spray
    wet rub is to be slathered on hog before cooking. cut slits in the skin and rub it up in there and all over that oinker
    orange juice, mustard (grain is possible), rosemary, thyme, garlic, mix well, dont want it to be soupy so start with a little oj and add as necessary
    Get a spray bottle and fill with 1/2 apple juice, 1/4 cider vin, and 1/4 white wine, mixed to spray on pig while cooking
    ok, to cook.... like i said, you need a grill or roaster big enough to fit it in there. mine was propane powered with a wood chip rack for some added flavor
    cooked the whole thing at 220 F, never messed with the temp
    started with the skin side down (touching rack) and went for 1 1/2 hrs, then flipped it and went for 7 1/2 more hours, every half hour or hour give it a spray. so cooking about 9 hours total at 220 F.
    Hope this helped
    and remember the cheek meat is the best part, seriously !
  4. Jul 9, 2011 at 9:01 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    any chinese or phillipino joints in your area? you can get a whole roasted pig, cheaper than DIY. at least in my area..
  5. Jul 9, 2011 at 9:08 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    ahh the old cochon de lait!
    Not sure about cooking it, but make sure you get an apple for the mouth! :D
  6. Jul 10, 2011 at 5:10 PM
    toughtaco
    cochon de lait........ is the literal translation pic from milk??? A little help please.
  7. Jul 10, 2011 at 5:40 PM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    That was a great primer all the way around..Thanks!!
    One question-The roaster...Covered or uncovered?? I'm thinking about building a fire pit in the back yard anyways...and I'm wondering if that'll cover it. I don't mind cooking over coals...
  8. Jul 10, 2011 at 6:03 PM
    Dilley
    Dilley Well-Known Member
    WA
    06 2.7L
    KN Cold air intake, Dynomax exaust, Husky liners
    You can go to the butcher and buy a whole hog and have them butterfly in for you and it will cook a lot faster and more evenly. 80 pound live hog will give you about 35 to 40 pounds of meat when cooked.
  9. Jul 11, 2011 at 4:53 AM
    facemob
    Chase
    1st state
    03 V6 Manual, TRD
    I did covered just because its easier to monitor the temp, and keeps the heat somewhat consistent all the way around, kind of like roasting.
    And yes, hogs are usually butterflied when purchased cleaned.
  10. Jul 11, 2011 at 5:22 AM
    TacoTabe
    TacoTabe Well-Known Member
    Kevin
    Northeast PA
    '93 pickup
    For the love of god, brunes- don't cook the pig alive. That's just cruel.
  11. Jul 11, 2011 at 5:54 AM
    kauaibuilt
    kauaibuilt U no kea but AINOFEA!
    LA/SGV
    2011 DCSB
    Check out my sig...
    Lechon Baboy. Mmmmmm............... :hungry:
    Dinuguan... eat at your own risk.
    http://www.pinoyrecipe.net/filipino-pork-dinuguan-recipe-pork-blood-stew/
    [​IMG]Pork Dinuguan (also called dinardaraan in Ilocano, or pork blood stew in English) is a Filipino savory stew of blood and meat simmered in a rich, spicy gravy of pig blood, garlic, chili and vinegar.
    The term dinuguan comes from the word dugo meaning “blood”. It is recognizably thick and dark, hence the Westernized euphemism “chocolate meat.” It is similar to the Singapore dish pig’s organ soup, differing in that it does not contain vegetables and has a characteristically thick gravy.
    Due to the offal it is frequently considered an unusual or alarming dish to those in Western culture, though it is rather similar to European-style blood sausage, or British black pudding in a saucy stew form. It is perhaps closer in appearance and preparation to the ancient Spartan dish known as black gruel whose primary ingredients were pork, vinegar and blood. Dinuguan is often served with white rice or a Filipino rice cake called puto.
    Estimated cooking time: 1 hour and 30 minutes
    Pork Dinuguan Ingredients:
    • 1 k. of pork belly, cut into small cubes
    • 350 g. of pork liver
    • 4 c. of pig’s blood
    • 3 chili peppers (siling haba)
    • 1 head of garlic, crushed and minced
    • 1 thumb-sized piece of ginger, minced
    • 3 onions, halved and sliced thinly
    • 1 pouch of sinigang mix good for 1 liter of broth
    • 1 bay leaf
    • salt
    • pepper (optional)
    • 1 tbsp. of cooking oil
    Pork Dinuguan Cooking Instructions:
    • [​IMG]Refrigerate the pig’s blood until needed.
    • Heat a heavy casserole.
    • Pour in the cooking oil. When the oil starts to smoke, add the garlic and ginger.
    • Saute until fragrant. Add the pork pieces and cook over high heat until the edges of the pork start to brown.
    • Add the onions, chili peppers, bay leaf and sinigang mix and continue cooking until the onions are transparent.
    • Season with salt and pepper, if using.
    • Pour in just enough water to cover. Bring to a boil, lower the heat, cover and simmer for 30-45 minutes or until the pork is very tender.
    • Add more water, a little at a time, if the liquid dries up before the pork is cooked.
    • Meanwhile, minced the liver.
    • Season with a little salt.
    • When the pork is tender and most of the liquid has evaporated, take the pig’s blood out of the refrigerator.
    • Transfer to a clean bowl. With you hands, mash solid masses to a pulp. Pour the mashed blood and the liquid into the casserole. Bring to a boil.
    • Cook over medium heat, stirring, for about 5 minutes. Add the minced liver and cook for another minute or two.
    • Add more salt if necessary.
      Serve the dinuguan hot with puto (sweet rice cakes) or steamed rice.
  12. Jul 16, 2011 at 11:35 AM
    facemob
    Chase
    1st state
    03 V6 Manual, TRD
    Brunes, did you track down a mass of pork yet? Got mine in today. 48.5lbs. cooking early next week, along with brisket, whole chickens, and broccoli rabe sausage . I'll be sure to share......pics that is
    :hungry:
    look at that cutie
  13. Jul 16, 2011 at 11:49 AM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian aka B-Lang
    San Luis Obispo, CA
    2010 Tundra
    welcome to come buy my hog.. its 202 right now :p
  14. Jul 16, 2011 at 12:05 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    I smoke a lot, but never a whole hog, although I had a good buddy from North Carloina that was a pro at it, his go to statement was "if you can hear him cooking, he's too hot".
  15. Jul 21, 2011 at 4:44 AM
    facemob
    Chase
    1st state
    03 V6 Manual, TRD
    Here she is
    8:30 am, just getting warmed up
    This is at about 3:30, almost there, went for about 2 more hours.
    Fucking delicious
  16. Jul 21, 2011 at 5:00 AM
    Brunes
    Brunes [OP] abides.
    Rotorhead
    Around
    Dude-That's a lot of meat!! I haven't yet...The wife is on the hook for some of this work as it is her party...and we have both been super busy. But this weekend and early next week I'm working on it. Still gotta figure out the pit too....I'm thinking I might do charcoal and wood.....
  17. Jul 21, 2011 at 5:54 AM
    facemob
    Chase
    1st state
    03 V6 Manual, TRD
    love the pit idea, just have to be able to cook it slow and low temp. i didnt go over 250, tried to hold it mostly around 220. used propane burners with wood chips in the barrel. as long as you can manage the temperature, the pit would be awesome!
  18. Jul 21, 2011 at 6:08 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Is that beer can chicken?? This thread is making me hungry!!
  19. Jul 21, 2011 at 6:23 AM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
  20. Jul 21, 2011 at 6:35 AM
    Namyo
    Namyo -
