Cooks 1991 Toyota Supra Slow Build with Import Tuner BS
Discussion in 'Other Builds' started by BYJOSHCOOK, Jun 5, 2018.
  1. Jun 5, 2018 at 5:33 PM
    BYJOSHCOOK
    BYJOSHCOOK [OP] Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Whats going on guys! Some of you know that I've been looking for a DD for about a year so I can keep miles off the rig and get some maintenance done. Well without further ado!
    Currently:
    When I picked it up:
    Plan for this is strictly a DD until I can get it back into the proper "show" car look and get some major maintenance done on the rig. Once those are done I'll begin to slowly start doing some things.
    Some quick specs:
    -Chassis has 230,000 miles
    -Motor has less than that, PO had a 1JZ installed but was done poorly over 10 years ago so he threw another 7M-GTE in so around 180,000 miles on that.
    -5-speed turbo
    -Pop up headlights
    Current Mods:
    Engine:
    K&N air intake
    ARP HG studs torqued properly
    Driftmotion 3" Downpipe with elbow (Installed 6/4/20)
    Tanabe Medalion Touring Catback Exhaust (installed 11/10/20)
    3 Inch Test Pipe (Installed 6/12/20)
    Suspension:
    BC Coilovers (Installed 6/12/2020 244k)
    Fornari Traction arm (Installed 7/1/2020 244k)
    Agile Performance Toe Arm (Installed 2/19/21 244k)
    Battle Version Rear Endlinks (Installed 1/15/2021 245k)
    Wheels & Tires:
    First: Enkei T6S (installed 10/31/18)
    Second: Avid AV-06 (installed 11/10/20)
    Cooper Zeon RS3-S
    Front: 245/45R18
    Rear: 275/40R18
    Brakes:
    Mercedes S500 Calipers/Pads (Installed 6/10/20)
    Mercedes R350 Rotors (Installed 6/10/20)
    Driftmotion hardlines (Installed 6/10/20)
    Interior:
    Stock
    Suede Dashmat (installed 7/12/18)
    Clifford 10.5 X (3301x) Alarm
    Aftermarket headunit
    New leather shift boot and e-brake boot (installed 8/17/18)
    Exterior:
    LEDS everywhere - (installed 3/15)
    Hatch Visor - (installed)
    Blinker Covers - (waiting to be installed)
    Air Guide - (waiting to be installed)
    Autoextrude LED Foglights - (installed 8/18/22)
    Future Needs:
    -Needs new floor mats
    -Cruise control needs fixed
    -Driver side seat doesn't move (not a big issue as I fit perfectly in it (so far))
    -Fix leaky targa/new targa
    -Rear defrost switch
    -Replace radiator
    -Possibly all belts
    -Timing belt/water pump
    -New Plugs (waiting to be installed)
    -Fix cracked wing
    Future Mods:
    Engine:
    Built 7M
    New vacuum lines
    Exterior:
    Wrap Job
    New tint
    New head lights
    New front lip
    Folding mirrors
    Interior:
    Better sound system
    Maybe new seats
    New alarm system
    Double din head unit
    Maintenance:
    New hood struts: (6/5/2018 - 229,969)
    Oil change (no filter): (8/4/18 - 231,603)
    AC recharge and swapped to R134: (8/13/18 - 231,871)
    New tires: (10/31/18 - 234,024)
    Heat fixed: (1/11/19 - 235,163)
    Oil change (w/ filter): (2/9/19 - 235,545)
    Oil change (w/ filter): (8/4/19 - 240,242)
    New battery: (3/7/20 - 243,000)
    Hatch Struts: (4/16/20 - 244,000)
    Control Arm Bushings, Subframe Bushings, SS Brake Lines: (4/29/20 - 244,000)
    Oil Pan FIPG, Trans Fluid Flush, MC Trans Bushing: (5/1/20 - 244,000)
    Oil Change w/ Filter, New Fuel Filter: (5/1/20 - 244,000)
    Front/Rear Subframe bushings: (6/4/20 - 244,000)
    Brake Upgrade/Fluid: (6/10/20 - 244,000)
    Swaybar bushings (F/R), Front endlinks, Exhaust O2 Sensor: (6/12/20 - 244,000)
    New brakes: (6/22/20 - 244,000)
    New suspension links: (7/1/20 - 244,000)
    Pads/Rotors, steering rack rebuilt/fluid: (7/10/2020 - 244,000)
    New Exhaust, New wheels: (11/10/20 - 244,500)
    New front tires, steering rack bushings, alignment, rear endlinks: (1/15/21 - 245,500)
    Oil Change + Filter: (8/19/2022 - 246,543)
    Helpful Links:
    http://www.cygnusx1.net/Supra/
    http://www.supramania.com/forum/
    http://japan-parts.eu/toyota/us
    https://www.redlinegoods.com/
    http://yotamd.com/toyota/mk3_supra/shocks_springs.html
    https://www.toyodiy.com/
    If you have any questions be sure to ask and I'll try my best! Still learning about this thing so bare with my ignorance if you actually know a ton about these, wouldn't mind your input either! :cheers:
  2. Jun 5, 2018 at 5:33 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
  3. Jun 5, 2018 at 5:34 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Here's some more pics pics
    Good ol 7M-GTE! :burnrubber:
    Interior is pretty clean for an almost 30 year old car apart from the dash really
    First and third car owned! Toyotas all the way
  4. Jun 5, 2018 at 5:35 PM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Beauty
    I want one
    What did you pay?
    ChadsPride and BYJOSHCOOK[OP] like this.
  5. Jun 5, 2018 at 5:38 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Thanks! Probably too much but too late now. KBB said I got a good deal but I paid $8k for it. But I don't really care now because it's too damn fun to drive :burnrubber:
  6. Jun 5, 2018 at 6:37 PM
    PROseur
    Pussy
    I am going to sell my 93 MR2 turbo. Had it almost 16 years
    Want a Supra. Thus was curious
    Thanks !
  7. Jun 5, 2018 at 6:42 PM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    whyyyyy?????
    BYJOSHCOOK[OP] and ChadsPride like this.
  8. Jun 5, 2018 at 6:51 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    Suuuuuuuuuubd​
    BYJOSHCOOK[OP] likes this.
  9. Jun 5, 2018 at 7:17 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I’d keep it honestly unless you could trade for a Supra. I bet that thing is sweet. I’d wouldn’t mind an MR2 except no backseats. Granted neither does mine really but I can cram somebody back there
    ChadsPride likes this.
  10. Jun 5, 2018 at 8:33 PM
    PROseur
    Pussy
    I want a MK3 Supra due to the back seat
    Lost out on an Integra type R on bring a trailer . Bid $37,000 but got outbid
    I remember in 2001 my local dealer couldn’t give the Type R away for 21,000$
  11. Jun 5, 2018 at 8:33 PM
    PROseur
    Pussy
    16 years of ownership
    Have 4 other 2 seaters
    It’s the least valuable
  12. Jun 5, 2018 at 8:40 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    You have an Awesome car with a lot of potential. Not a toyota so I have its rival but its an 1987. Been in family since new but its not stock. Less than 70k original miles. Only comes out during summer months :pout:
    jpy09, b_r_o, Volksparts and 11 others like this.
  13. Jun 5, 2018 at 8:41 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Ah gotcha well that changes it.
    Damn that would’ve been sick! My buddy loves Type R’s but he sold his too, wishes he hadn’t. So I don’t plan on selling this as long as I can haha
    PROseur[QUOTED] likes this.
  14. Jun 5, 2018 at 8:42 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Still a beautiful car! So for only people who know what it is are hardcore enthusiasts or other late 80s car owners haha
    randd likes this.
  15. Jun 5, 2018 at 8:46 PM
    20tacoma17
    2017 DCLB Sport AT
    Yep, most people don't know what mine is either. Just has TURBO Z on it. Always liked the supras except for one or 2 years it was rounded body with big tail. You have a keeper.
  16. Jun 5, 2018 at 8:53 PM
    Sacrifice
    KS
    DCSB OR 4X4 LT
    type Rs are money now. i just built up my 93 integra woth a kswap.
    i want it, lol.
  17. Jun 6, 2018 at 1:58 PM
    PROseur
    Pussy
    Miss my DAs. Had a B17 92 GS-R, and a 91 RS back in the day.
    I won't sell my MR2, till I acquire a Supra first. If you are serious, I will PM you when I have it for sale. It has 37K original miles.
    BYJOSHCOOK[OP] and 20tacoma17 like this.
  18. Jun 6, 2018 at 3:05 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Damn! Only 37k miles that’s ridiculous haha
  19. Jun 12, 2018 at 7:45 PM
    Suprajim54
    Suprajim54 Unfamous Member
    Jimbo
    Irving, TX
    Silver 2015 Tacoma SR5 4x4 DCSB
    King ET Coilovers, SPC UCA's, 5160 Rears, Icon Progressive AAL, Method 701, STT Pro 285/75/16, SOS Offroad Skid and Sliders
    Sub'ed.
    Great car! Looks like it's in pretty good shape. Have you ever owned an MK3 before?
    My first car was an 89 Supra Turbo in white. I blew the HG and had to get rid of it. I always regretted it afterward and eventually bought another. I've had this one since 09. It's a 92 7MGTE Auto w/Sunroof. Currently, on my second 7M and pushing a little coolant when in the boost. For some insane reason, I'm rebuilding a third 7M with forged rods/pistons and hoping to make this one bulletproof. Head is currently at the machine shop so I can finish it up. Going to do an R154 swap when I put the new engine in, too. I've been through hell and back since I've owned this car and it's in much better shape than when I started. I'm glad to help out if you have any questions or need some advice with the car.
  20. Jun 12, 2018 at 7:48 PM
    20tacoma17
    2017 DCLB Sport AT
    Beautiful car.
    Suprajim54[QUOTED] likes this.
